arkoko
Post by arkoko »
Not (yet?) I hope and think @corbin will comment this.
corbin
Post by corbin »
paszczus wrote:Thank you @arkoko, i thought it will be added to Switches automatically. After manually adding it to Switches i can turn it off and on!
Is there a way to see power consumption too?
the plug should update automatically to the korrekt type when detekted, so a problem there.
no power consumption available, if/when it is, I will add to Domoticz
deennoo
Post by deennoo »
I think paszczus didn't know that we have to add device after detection to saw it on switch tab. Everything looks to work.
@paszczus can you confirm that plug status is update when switch from MiHome app ?
http://domo-attitude.fr
paszczus
Post by paszczus »
Yes, the plug status is updating when i change if from Xiaomi Mi app and vice versa.
Zrzut ekranu 2017-01-15 o 14.24.21.png (220.22 KiB) Viewed 2506 times
It will be awesome if there will be power consumption status. I have ordered 3 more plugs ;)
deennoo
Post by deennoo »
Can you share with us plug message (text on log tab) ?
StasDemydiuk
Post by StasDemydiuk »
I found this repository with some documentation for Xiaomi devices:
https://github.com/louisZL/lumi-gateway-local-api
It looks like plug power consumption can be taken:
https://github.com/louisZL/lumi-gateway ... er/plug.md
corbin
Post by corbin »
power consumption is not reported
from the docs - https://github.com/louisZL/lumi-gateway ... i/issues/5
paszczus
Post by paszczus »
deennoo wrote:Can you share with us plug message (text on log tab) ?
Do you mean this?
Zrzut ekranu 2017-01-15 o 20.23.26.png (331.02 KiB) Viewed 2453 times
deennoo
Post by deennoo »
No this : Image
But with plug message...Corbin just confirme that message doesn't looks to be provied.
paszczus
Post by paszczus »
Ahh, right:
2017-01-15 13:22:59.726 (Xiaomi Gateway) Light/Switch (Xiaomi Smart Plug)
2017-01-15 13:22:59.791 (Xiaomi Gateway) Light/Switch (Xiaomi Smart Plug)
2017-01-15 13:22:59.794 {"cmd":"report","model":"plug","sid":"158d000110470d","short_id":42409,"data":"{\"status\":\"on\"}"}
2017-01-15 13:22:59.814 (Xiaomi Gateway) Light/Switch (Xiaomi Smart Plug)
2017-01-15 13:22:59.816 {"cmd":"report","model":"plug","sid":"158d000110470d","short_id":42409,"data":"{\"status\":\"on\"}"}
2017-01-15 13:22:59.822 (Xiaomi Gateway) Light/Switch (Xiaomi Smart Plug)
2017-01-15 13:22:59.824 {"cmd":"report","model":"plug","sid":"158d000110470d","short_id":42409,"data":"{\"status\":\"on\"}"}
2017-01-15 13:23:01.924 (Xiaomi Gateway) Light/Switch (Xiaomi Smart Plug)
2017-01-15 13:23:01.926 {"cmd":"report","model":"plug","sid":"158d000110470d","short_id":42409,"data":"{\"status\":\"on\"}"}
2017-01-15 13:23:01.945 (Xiaomi Gateway) Light/Switch (Xiaomi Smart Plug)
2017-01-15 13:23:01.947 {"cmd":"report","model":"plug","sid":"158d000110470d","short_id":42409,"data":"{\"status\":\"on\"}"}
deennoo
Post by deennoo »
Cmd bla bla bla is the message send by the gateway, domoticz "just" hear it and translate to his language.
As you can read their no power information, did you get it on MiHome app ?
paszczus
Post by paszczus »
Yes, it works pretty nice:
deennoo
Post by deennoo »
Ok cool, just have to be aware of a futur fw update !
Mat2Vence
Domoticz version: 3.7449
Post by Mat2Vence »
One quick question regarding the door sensor. There is a behaviour I am not understanding. In domoticz, it looks like when the door is open, it is considered as closed in the status 1 minute after it has been open, whatever the case. I the mean time, if I am looking at the status on the xiaomi app, it is still open.
Any chance to know where it can come from?
I am using those sensor to know whether my velux are open or not... so that a bit painful to see there are closed when they are not ;)
If you have any idea on where to investigate?? thnaks a lot!
Mat2Vence
Post by Mat2Vence »
I have just uploaded the last beta version and it seems it has been fixed. I now have the same status on both Domoticz and xiaomi app.
murtadin
Re: RE: Re: RE: Re: Xiaomi Smart Home Suite (very cheap) compatibilty?
Post by murtadin »
corbin wrote:
murtadin wrote: you can try compile from source for the start.
I tried "emerge -v git", and it didn't work:
First check /usr/bin/emerge if file exists. Check permitions. You are trying it under root user? If not -
looks like you have to install stage 3. Just download it and unzip to the system root.
I have installed missing liveusb library, required by precompiled binaries - now i can start ./domoticz, but still no luck. No device appear in device menu. Still need help to debug this case.
arkoko
Post by arkoko »
Mat2Vence wrote:In domoticz, it looks like when the door is open, it is considered as closed in the status 1 minute after it has been open, whatever the case.
Yes, it is (beta v3.6367). Domoticz "close the door" on this signal:
{"cmd":"report","model":"magnet","sid":"158d00011854aa","short_id":1082,"data":"{\"no_close\":\"60\"}"}
This behavior appeared after last firmware upgrade on the gateway.
deennoo
Post by deennoo »
Be patient solution is here, corbin is working hard on it, just give him time to provid a full release with all devices aviable
corbin
Post by corbin »
How about you create a VM of your setup that I can test with?
corbin
Post by corbin »
deennoo wrote: Be patient solution is here, corbin is working hard on it, just give him time to provid a full release with all devices aviable
This is already fixed after the last firmware update. Gateway LED control and Aqara switch support will be coming next. I got delayed on the weekend when friends turned up.
