Water leakage sensor for RFXtrx433E
niclasc
Domoticz version: 4.10854
Post by niclasc »
I'm looking for at water leakage sensor that works with my RFXtrx433E
I'd like to have it behind my dishwasher
Is there a sensor for that?
alfred_j_kwak
Domoticz version: 2.3530
Re: Water leakage sensor for RFXtrx433E
Post by alfred_j_kwak »
What kind of looking have you done?
viewtopic.php?f=17&t=1027
niclasc
Post by niclasc »
alfred_j_kwak wrote:What kind of looking have you done?
Why so rude?
I dont want to build a sensor. I was hoping to find one to just buy and connect to Domoticz
b_weijenberg
Post by b_weijenberg »
The 433.92MHz version of this sensor is supported by the RFXtrx433(E)
http://www.visonic.com/Products/Wireles ... or-mct-550
Maybe this one can be used as Lighting4 device.
The oscillator resistor must be configured to 3M3
http://www.banggood.com/433MHz-Wireless ... 69573.html
Note that this sensor does not transmit an alive signal or battery empty!
RFX-433, RFX-433EMC, RFX-868
alfred_j_kwak
Why so rude?
Was I rude? If so then I'm sorry. On the other hand you said that you were looking. So looking to buy, build or just find? I suppose that you need info about those devices and that is what I tried to offer. Obviously my mistake, but now you have found.
markk
Post by markk »
b_weijenberg wrote: Maybe this one can be used as Lighting4 device.
Hi. I got one of these to try. Can you explain what you mean by "configured to 3M3 please"?
b_weijenberg
You can configure the oscillator with a 1.5M, 3.3M or 4.7M.
Select 3.3M
markk
Post by markk »
Sorry to be so stupid, but how do I configure it please?
gertlind1
Post by gertlind1 »
b_weijenberg wrote:Maybe this one can be used as Lighting4 device.
Bought two of these, see if i can get them to work.
Gert
albinsson
Post by albinsson »
I use this : http://www.nexa.se/vara-produkter/syste ... re/wbt-912
Skickat från min SM-G900F via Tapatalk
Scoobydoo
Post by Scoobydoo »
Any luck with getting these working?. Looking for a simple sensor i can put under my bath.
gertlind1
Post by gertlind1 »
Havent received them yet.
Gert
Scoobydoo
Post by Scoobydoo »
Ok thanks, if you could keep me updated as im interested in installing a couple of these in my property.
gertlind1
Post by gertlind1 »
Received the stuff today.
Looks good for the price.
Have done some testing.
Enabled the Lightning4 protocol.
Added the battery and dipped the water sensing part in a glass of water, no cigarr.
Made the changes suggested by b_weijenberg a few posts up.
Now i can get it in as Lightning4 switch :-)
However, the switch in Domoticz stays always on (lit) and can't turn it off.
When i dip it water i can see in the logs that it transmits.
2016-03-05 12:18:32.279 (RFXCOM) Lighting 4 (Vattenlarm)
How do i see what kind of message it sends so i can make a LUA script taking care off the alarms.
Or, maybe it should be added as some other kind if switch??
Gert
b_weijenberg
This type of sensor transmit only the ON packet if the sensor is triggered. The state must be changed to OFF by software. Set the state back to OFF after a delay of a few seconds.
gertlind1
Post by gertlind1 »
Ok, got it to work.
Created a dummy switch that the sensor switch can turn on.
I hided the sensor switch with the $ sign.
A lua turns on the dummy switch the a leakage is detected and sens an Prowl message.
if (devicechanged['$Vattenlarm']) then
    print "VattenLarm AKUT"
    commandArray['Läcka Kök']='On'
Works as a charm.
Well worth the money.
Thanks for bringing this up in the first place :-)
Gert
saarwh
Domoticz version: 2024.7
Post by saarwh »
Hello dear experts,
Sorry to bother you in this old post but I couldn't find solutions in other topics (I am a just starting newby).
I have the very same problem as markk (03 feb 2016); configuring the oscillator I take it means remove the solder connection of 4.7M and solder a bridge to 3.3M, I made a dummy switch, but I cannot find the complete code to send a message and set the state of the sensor to OFF?
Please can anybody direct me to solve this issue?
Thanks a lot (and forgive me my lousy English)
pvklink
Domoticz version: latest b
Post by pvklink »
I also bought the waterflood sensor:
https://nl.aliexpress.com/item/1-stks-D ... DID%7D&acn
I think this version is already fixed for 433. Does anybody know which battery this devices needs?
There is no description added...
Jablotron connection, Ikea
