Water leakage sensor for RFXtrx433E
niclasc
- Domoticz version: 4.10854
I'm looking for at water leakage sensor that works with my RFXtrx433E
I'd like to have it behind my dishwasher
Is there a sensor for that?
alfred_j_kwak
- Domoticz version: 2.3530
niclasc
Re: Water leakage sensor for RFXtrx433E
Why so rude?
I dont want to build a sensor. I was hoping to find one to just buy and connect to Domoticz
b_weijenberg
- Target OS: -
The 433.92MHz version of this sensor is supported by the RFXtrx433(E)
http://www.visonic.com/Products/Wireles ... or-mct-550
Maybe this one can be used as Lighting4 device.
The oscillator resistor must be configured to 3M3
http://www.banggood.com/433MHz-Wireless ... 69573.html
Note that this sensor does not transmit an alive signal or battery empty!
RFX-433, RFX-433EMC, RFX-868
alfred_j_kwak
Was I rude? If so then I'm sorry. On the other hand you said that you were looking. So looking to buy, build or just find? I suppose that you need info about those devices and that is what I tried to offer. Obviously my mistake, but now you have found.niclasc wrote:
Why so rude?
markk
Hi. I got one of these to try. Can you explain what you mean by "configured to 3M3 please"?b_weijenberg wrote: Maybe this one can be used as Lighting4 device.
b_weijenberg
- Target OS: -
You can configure the oscillator with a 1.5M, 3.3M or 4.7M.
Select 3.3M
Select 3.3M
markk
Sorry to be so stupid, but how do I configure it please?
gertlind1
Bought two of these, see if i can get them to work.b_weijenberg wrote:Maybe this one can be used as Lighting4 device.
Gert
Gert
albinsson
I use this : http://www.nexa.se/vara-produkter/syste ... re/wbt-912
Skickat från min SM-G900F via Tapatalk
Any luck with getting these working?. Looking for a simple sensor i can put under my bath.gertlind1 wrote:Bought two of these, see if i can get them to work.b_weijenberg wrote:Maybe this one can be used as Lighting4 device.
gertlind1
Havent received them yet.Scoobydoo wrote:Any luck with getting these working?. Looking for a simple sensor i can put under my bath.gertlind1 wrote:Bought two of these, see if i can get them to work.b_weijenberg wrote:Maybe this one can be used as Lighting4 device.
Gert
Gert
Ok thanks, if you could keep me updated as im interested in installing a couple of these in my property.gertlind1 wrote:Havent received them yet.Scoobydoo wrote:Any luck with getting these working?. Looking for a simple sensor i can put under my bath.gertlind1 wrote:
gertlind1
Received the stuff today.
Looks good for the price.
Have done some testing.
Enabled the Lightning4 protocol.
Added the battery and dipped the water sensing part in a glass of water, no cigarr.
Made the changes suggested by b_weijenberg a few posts up.
Now i can get it in as Lightning4 switch
However, the switch in Domoticz stays always on (lit) and can't turn it off.
When i dip it water i can see in the logs that it transmits.
How do i see what kind of message it sends so i can make a LUA script taking care off the alarms.
Or, maybe it should be added as some other kind if switch??
2016-03-05 12:18:32.279 (RFXCOM) Lighting 4 (Vattenlarm)Or, maybe it should be added as some other kind if switch??
Gert
Gert
b_weijenberg
- Target OS: -
This type of sensor transmit only the ON packet if the sensor is triggered. The state must be changed to OFF by software. Set the state back to OFF after a delay of a few seconds.
gertlind1
Ok, got it to work.
Created a dummy switch that the sensor switch can turn on.
I hided the sensor switch with the $ sign.
A lua turns on the dummy switch the a leakage is detected and sens an Prowl message.
Works as a charm.
Well worth the money.
Thanks for bringing this up in the first place
if (devicechanged['$Vattenlarm']) then
print "VattenLarm AKUT"
commandArray['Läcka Kök']='On'
endWell worth the money.
Gert
Gert
saarwh
- Domoticz version: 2024.7
Hello dear experts,
Sorry to bother you in this old post but I couldn't find solutions in other topics (I am a just starting newby).
I have the very same problem as markk (03 feb 2016); configuring the oscillator I take it means remove the solder connection of 4.7M and solder a bridge to 3.3M, I made a dummy switch, but I cannot find the complete code to send a message and set the state of the sensor to OFF?
Please can anybody direct me to solve this issue?
Thanks a lot (and forgive me my lousy English)
pvklink
- Domoticz version: latest b
I also bought the waterflood sensor:
https://nl.aliexpress.com/item/1-stks-D ... DID%7D&acn
I think this version is already fixed for 433. Does anybody know which battery this devices needs?
There is no description added...
Jablotron connection, Ikea
