RFX-433EMC USB/Wifi/MQTT
NvBgm
Post by NvBgm »
Whit the new RFX-433EMC USB/Wifi/MQTT it is posible to operate the RFX by Wifi.
How can i add it to Domoticz via Wifi ????
Re: RFX-433EMC USB/Wifi/MQTT
Wifi is LAN so you probably can use one the RFX with LAN hardware gateways options. You have to know the IP adress of the RFX device and make sure it is fixed IP by your router.
b_weijenberg
Post by b_weijenberg »
See the RFX MQTT User Guide chapter 6.2
Install a MQTT broker,
Flash RFX433EMC_MQTT_WiFi in the RFX-433EMC. (chapter 3)
Configure WiFi in the RFX-433EMC (chapter 4.3)
Configure MQTT and the 433 protocols in the RFX-433EMC. (chapter 7)
RFX-433, RFX-433EMC, RFX-868
b_weijenberg wrote: Monday 26 January 2026 21:08 See the RFX MQTT User Guide chapter 6.2
Ah, you are using MQTT Auto Discover, nice.
homeJLB
Domoticz version: 2024.7
Post by homeJLB »
Is it only possible with MQTT ?
I have one connected with USB an the latest firmware
FWType = 47
FWVersion = 4055
subtype           = Interface Response
Sequence nbr      = 2
response on cmnd  = Get Status
Transceiver type  = 433.92MHz
Firmware version  = 1055
Firmware type     = ?
Noise Level: 0
Hardware version  = 4.1
Undec             off
X10               disabled
ARC               disabled
AC                disabled
HomeEasy EU       disabled
Meiantech/Atlantic disabled
Oregon Scientific disabled
ATI/Cartelectronic disabled
Visonic           disabled
Mertik            disabled
AD                disabled
Hideki            disabled
La Crosse         disabled
Legrand           disabled
MSG4Reserved5     disabled
BlindsT0          enabled
BlindsT1          disabled
AE                disabled
RUBiCSON          disabled
FineOffset        disabled
Lighting4         disabled
Conrad RSL        disabled
ByronSX           disabled
IMAGINTRONIX      disabled
KEELOQ            disabled
Home Confort      disabled
and nothing is recieved.
Kind Regards
b_weijenberg
do not use BlindsT0 as this disables all other protocols.
See the RFX User Guide.pdf
homeJLB
Post by homeJLB »
Thank you for your responce.
I forgoy about that one.
But it still gives the Firmware type & version mismatch
FWVersion = 4055
FWType = 47
Sequence nbr      = 2
Firmware type     = ?
Noise Level: 0
Undec             off
X10               enabled
ARC               enabled
AC                enabled
HomeEasy EU       enabled
Meiantech/Atlantic enabled
Oregon Scientific enabled
ATI/Cartelectronic enabled
Visonic           enabled
Mertik            enabled
AD                enabled
Hideki            enabled
La Crosse         enabled
Legrand           enabled
MSG4Reserved5     enabled
BlindsT0          disabled
BlindsT1          enabled
AE                enabled
RUBiCSON          enabled
FineOffset        enabled
Lighting4         enabled
Conrad RSL        enabled
ByronSX           enabled
IMAGINTRONIX      enabled
KEELOQ            enabled
Home Confort      enabled
b_weijenberg
Enable only protocols you need to receive!!
Wrong Firmware and Version displaymust be solved in Domoticz but does not produce any functional problem.
