Whit the new RFX-433EMC USB/Wifi/MQTT it is posible to operate the RFX by Wifi.
How can i add it to Domoticz via Wifi ????
- Domoticz version: 2025.1
Re: RFX-433EMC USB/Wifi/MQTT
Wifi is LAN so you probably can use one the RFX with LAN hardware gateways options. You have to know the IP adress of the RFX device and make sure it is fixed IP by your router.
b_weijenberg
- Target OS: -
See the RFX MQTT User Guide chapter 6.2
Install a MQTT broker,
Flash RFX433EMC_MQTT_WiFi in the RFX-433EMC. (chapter 3)
Configure WiFi in the RFX-433EMC (chapter 4.3)
Configure MQTT and the 433 protocols in the RFX-433EMC. (chapter 7)
RFX-433, RFX-433EMC, RFX-868
Ah, you are using MQTT Auto Discover, nice.
