RFX-433EMC USB/Wifi/MQTT
Whit the new RFX-433EMC USB/Wifi/MQTT it is posible to operate the RFX by Wifi.
How can i add it to Domoticz via Wifi ????
- Domoticz version: 2026.3
Re: RFX-433EMC USB/Wifi/MQTT
Wifi is LAN so you probably can use one the RFX with LAN hardware gateways options. You have to know the IP adress of the RFX device and make sure it is fixed IP by your router.
b_weijenberg
- Target OS: -
See the RFX MQTT User Guide chapter 6.2
Install a MQTT broker,
Flash RFX433EMC_MQTT_WiFi in the RFX-433EMC. (chapter 3)
Configure WiFi in the RFX-433EMC (chapter 4.3)
Configure MQTT and the 433 protocols in the RFX-433EMC. (chapter 7)
RFX-433, RFX-433EMC, RFX-868
Ah, you are using MQTT Auto Discover, nice.
homeJLB
- Domoticz version: 2024.7
Is it only possible with MQTT ?
I have one connected with USB an the latest firmware
FWType = 47
FWVersion = 4055
and nothing is recieved.
Kind Regards
FWType = 47
FWVersion = 4055
subtype = Interface Response
Sequence nbr = 2
response on cmnd = Get Status
Transceiver type = 433.92MHz
Firmware version = 1055
Firmware type = ?
Noise Level: 0
Hardware version = 4.1
Undec off
X10 disabled
ARC disabled
AC disabled
HomeEasy EU disabled
Meiantech/Atlantic disabled
Oregon Scientific disabled
ATI/Cartelectronic disabled
Visonic disabled
Mertik disabled
AD disabled
Hideki disabled
La Crosse disabled
Legrand disabled
MSG4Reserved5 disabled
BlindsT0 enabled
BlindsT1 disabled
AE disabled
RUBiCSON disabled
FineOffset disabled
Lighting4 disabled
Conrad RSL disabled
ByronSX disabled
IMAGINTRONIX disabled
KEELOQ disabled
Home Confort disabled
Kind Regards
b_weijenberg
- Target OS: -
do not use BlindsT0 as this disables all other protocols.
See the RFX User Guide.pdf
homeJLB
Thank you for your responce.
I forgoy about that one.
But it still gives the Firmware type & version mismatch
FWVersion = 4055
FWType = 47
FWVersion = 4055
FWType = 47
Sequence nbr = 2
Firmware type = ?
Noise Level: 0
Undec off
X10 enabled
ARC enabled
AC enabled
HomeEasy EU enabled
Meiantech/Atlantic enabled
Oregon Scientific enabled
ATI/Cartelectronic enabled
Visonic enabled
Mertik enabled
AD enabled
Hideki enabled
La Crosse enabled
Legrand enabled
MSG4Reserved5 enabled
BlindsT0 disabled
BlindsT1 enabled
AE enabled
RUBiCSON enabled
FineOffset enabled
Lighting4 enabled
Conrad RSL enabled
ByronSX enabled
IMAGINTRONIX enabled
KEELOQ enabled
Home Confort enabled-
b_weijenberg
- Target OS: -
Enable only protocols you need to receive!!
Wrong Firmware and Version displaymust be solved in Domoticz but does not produce any functional problem.
