conbee2 in docker Topic is solved
smaus
conbee2 in docker
Post by smaus »
Who can help me install a conbee2 stick.
I already created a deconz in docker and it works.
but i can't get it to work in domoticz docker.
Thorgal789
Re: conbee2 in docker
Post by Thorgal789 »
Hello this url is working for you
https://phoscon.de/discover
If yes you have inside the port and the ip to use in the configuration plugin.
Do you have an api key ? https://github.com/Smanar/Domoticz-deCONZ#configuration
smaus
Post by smaus »
no is not working for me
i have to get a api key bu i dont no how
Thorgal789
How you know it's working ? You have access to phoscon, because strange deconz is working and not he previous URL (but can happen according to firewall rule)
So you have installed this docker ? https://github.com/deconz-community/deconz-docker
If you have access to phoscon can you share the used URL (I need the local ip and the port used by your setting)
smaus
Post by smaus »
Thanks its working now
