Who can help me install a conbee2 stick.
I already created a deconz in docker and it works.
but i can't get it to work in domoticz docker.
conbee2 in docker Topic is solved
Thorgal789
- Target OS: -
Re: conbee2 in docker
Hello this url is working for you
If yes you have inside the port and the ip to use in the configuration plugin.
Do you have an api key ? https://github.com/Smanar/Domoticz-deCONZ#configuration
https://phoscon.de/discoverDo you have an api key ? https://github.com/Smanar/Domoticz-deCONZ#configuration
smaus
no is not working for me
i have to get a api key bu i dont no how
Thorgal789
- Target OS: -
I already created a deconz in docker and it works.So you have installed this docker ? https://github.com/deconz-community/deconz-docker
If you have access to phoscon can you share the used URL (I need the local ip and the port used by your setting)
smaus
Thanks its working now
