Who can help me install a conbee2 stick.
I already created a deconz in docker and it works.
but i can't get it to work in domoticz docker.
conbee2 in docker Topic is solved
- Target OS: -
Re: conbee2 in docker
Hello this url is working for you
If yes you have inside the port and the ip to use in the configuration plugin.
Do you have an api key ? https://github.com/Smanar/Domoticz-deCONZ#configuration
https://phoscon.de/discover
no is not working for me
i have to get a api key bu i dont no how
- Target OS: -
So you have installed this docker ? https://github.com/deconz-community/deconz-docker
If you have access to phoscon can you share the used URL (I need the local ip and the port used by your setting)
Thanks its working now
