P1 smart meter doesn't add up
Rolandet
Domoticz version: 2021.1
Post by Rolandet »
Usually the p1 smart meter data, show the power sent to the grid, minus the power used and that very moment.
Recently I saw that the widget on the Utility page shows both,
and the counter on the dashboard switches between the two, every now and then (can't quite count seconds/minutes of it switching but when if f5 the page it FIRST shows usage, and then switches to kwh sent)
stroom 2.JPG (18.08 KiB) Viewed 722 times
stroom 1.JPG (15.37 KiB) Viewed 722 times
Anyway: i was wondering if anybody has ever seen that behaviour, and what might be done about it.
Custodes Septentrionum
Domoticz version: 2025.1
Re: P1 smart meter doesn't add up
Did you update to the latest Domoticz version 2022.1? Your signature says you are using an old version 2021.1
Rolandet
Post by Rolandet »
Ah yeah, need to adjust my sig
2022.1 indeed.
I got a 2nd installment (this one is at my mother's ) which is showing correct figures
Rolandet wrote: Thursday 01 September 2022 23:43 Ah yeah, need to adjust my sig
2022.1 indeed.
Perhaps check the Decimals setting for P1 meter as it introduces some issues:
https://www.domoticz.com/wiki/Applicati ... r_Dividers
willemd
Domoticz version: 2024.1
Post by willemd »
My P1 meter works still normal as before, no problem. Mine is updated with the HTTP poller from a Homewizard WIFI meter API page.
Rolandet
Post by Rolandet »
willemd wrote: Saturday 03 September 2022 16:08
TNx
My p1 meter works fine, no issues
The issue is in the presentation layer of domoticz.
@waltervl: i've checked the settings. Fiddled around with it, but no change yet.
I can confirm that on latest beta I see the same behaviour, only one of the usage/return values are mentioned. In mobile layout I see both values....
Does your mother also has a recent version?
Rolandet
Post by Rolandet »
waltervl wrote: Saturday 03 September 2022 23:19 I can confirm that on latest beta I see the same behaviour, only one of the usage/return values are mentioned. In mobile layout I see both values....
I must admit I haven't checked for an update for a while, but both Pi's have
Version: 2022.1
Build Hash: c9526851b
