Usually the p1 smart meter data, show the power sent to the grid, minus the power used and that very moment.
Recently I saw that the widget on the Utility page shows both,
and the counter on the dashboard switches between the two, every now and then (can't quite count seconds/minutes of it switching but when if f5 the page it FIRST shows usage, and then switches to kwh sent)
Anyway: i was wondering if anybody has ever seen that behaviour, and what might be done about it.
P1 smart meter doesn't add up
- Rolandet
- Domoticz version: 2021.1
Custodes Septentrionum
- Domoticz version: 2025.1
Re: P1 smart meter doesn't add up
Did you update to the latest Domoticz version 2022.1? Your signature says you are using an old version 2021.1
- Rolandet
Ah yeah, need to adjust my sig
2022.1 indeed.
I got a 2nd installment (this one is at my mother's ) which is showing correct figures
2022.1 indeed.
Perhaps check the Decimals setting for P1 meter as it introduces some issues:Rolandet wrote: Thursday 01 September 2022 23:43 Ah yeah, need to adjust my sig
2022.1 indeed.
https://www.domoticz.com/wiki/Applicati ... r_Dividers
willemd
- Domoticz version: 2024.1
My P1 meter works still normal as before, no problem. Mine is updated with the HTTP poller from a Homewizard WIFI meter API page.Anyway: i was wondering if anybody has ever seen that behaviour, and what might be done about it.
- Rolandet
TNxwillemd wrote: Saturday 03 September 2022 16:08My P1 meter works still normal as before, no problem. Mine is updated with the HTTP poller from a Homewizard WIFI meter API page.Anyway: i was wondering if anybody has ever seen that behaviour, and what might be done about it.
My p1 meter works fine, no issues
The issue is in the presentation layer of domoticz.
@waltervl: i've checked the settings. Fiddled around with it, but no change yet.
I can confirm that on latest beta I see the same behaviour, only one of the usage/return values are mentioned. In mobile layout I see both values....
Does your mother also has a recent version?
- Rolandet
I must admit I haven't checked for an update for a while, but both Pi's havewaltervl wrote: Saturday 03 September 2022 23:19 I can confirm that on latest beta I see the same behaviour, only one of the usage/return values are mentioned. In mobile layout I see both values....
Version: 2022.1
Build Hash: c9526851b
