Dashticz is not working after install on rbp or synology nas
HansieNL
Re: Dashticz is not working after install on rbp or synology nas
Post by HansieNL »
Can you try the following settings for Local Networks (no username/password):
127.0.0.*;192.168.1.*;::1
Blah blah blah
Jeroentje76
Post by Jeroentje76 »
I've got same error and don't understand the mentioned solution.
Domoticz on a Raspberry and Dashticz on Synology NAS.
Please help
Screenshot 2022-08-31 163048.jpg (93.47 KiB) Viewed 681 times
HansieNL
Post by HansieNL »
The mentioned solution is a Domoticz setting.
Settings - System Setup - Local Networks
Blah blah blah
Jeroentje76
Added the IP's in the settings of Domoticz, but didn't work.
Any suggestions? ;)
Screenshot 2022-09-02 152106.png (13.79 KiB) Viewed 654 times
Jeroentje76
I've tried today to install Dashticz on a other Raspberry and got the same error.
Does somebody have a clue?
HansieNL
Post by HansieNL »
Which installation did you try? Manual or Automatic.
Automatic install will help you with the correct setting. Installed it last weekend on a raspberry pi without any problem.
Blah blah blah
Jeroentje76
Both times Manual installation.
I'll try the coming day the Automatic installation on a new Raspberry/Debian.
Jeroentje76
@HansieNL I did the automatic installation and it is working, Thanks.
Still the question, why does the manual setup not work?
Has it to do with the Docker part because I don't see that in the manual installation.
Regards,
Jeroen
HansieNL
Post by HansieNL »
Good to hear it is working now.
Hard to say where it goes wrong at your side.
If you manual install you have to be sure that the webserver and all additional packages are correctly installed and configured.
Now you have a working version you can configure and play with your Dashticz.
You can always copy your Dashticz configuration files later to a manual version if you solved the problem.
Docker is not needed for a manual installation.
Blah blah blah
