HansieNL
Posts: 969 Joined: Monday 28 September 2015 15:13
Post
by HansieNL » Monday 01 August 2022 11:11
Can you try the following settings for Local Networks (no username/password):
Blah blah blah
Jeroentje76
Posts: 5 Joined: Wednesday 31 August 2022 16:27
Post
by Jeroentje76 » Wednesday 31 August 2022 16:33
I've got same error and don't understand the mentioned solution.
Domoticz on a Raspberry and Dashticz on Synology NAS.
Please help
Screenshot 2022-08-31 163048.jpg (93.47 KiB) Viewed 698 times
HansieNL
Post
by HansieNL » Wednesday 31 August 2022 18:06
The mentioned solution is a Domoticz setting.
Settings - System Setup - Local Networks
Blah blah blah
Jeroentje76
Post
by Jeroentje76 » Friday 02 September 2022 15:22
Added the IP's in the settings of Domoticz, but didn't work.
Any suggestions?
Screenshot 2022-09-02 152106.png (13.79 KiB) Viewed 671 times
Jeroentje76
Post
by Jeroentje76 » Monday 05 September 2022 19:56
I've tried today to install Dashticz on a other Raspberry and got the same error.
Does somebody have a clue?
HansieNL
Post
by HansieNL » Monday 05 September 2022 23:21
Which installation did you try? Manual or Automatic.
Automatic install will help you with the correct setting. Installed it last weekend on a raspberry pi without any problem.
Blah blah blah
Jeroentje76
Post
by Jeroentje76 » Tuesday 06 September 2022 16:12
Both times Manual installation.
I'll try the coming day the Automatic installation on a new Raspberry/Debian.
Jeroentje76
Post
by Jeroentje76 » Wednesday 07 September 2022 9:53
@HansieNL I did the automatic installation and it is working, Thanks.
Still the question, why does the manual setup not work?
Has it to do with the Docker part because I don't see that in the manual installation.
Regards,
Jeroen
HansieNL
Post
by HansieNL » Wednesday 07 September 2022 18:06
Good to hear it is working now.
Hard to say where it goes wrong at your side.
If you manual install you have to be sure that the webserver and all additional packages are correctly installed and configured.
Now you have a working version you can configure and play with your Dashticz.
You can always copy your Dashticz configuration files later to a manual version if you solved the problem.
Docker is not needed for a manual installation.
Blah blah blah
