Excessive logging of P1 Smart Meter with LAN interface
eelco
Post by eelco »
I've installed a "P1 Smart Meter with LAN interface" but, it's filling up my log with constant message. They look like this:
2021-09-23 19:23:41.485 (P1 Elektra/Gas) P1 Smart Meter (Elektra)
2021-09-23 19:23:41.487 (P1 Elektra/Gas) General/Voltage (Voltage L1)
2021-09-23 19:23:41.489 (P1 Elektra/Gas) General/Voltage (Voltage L2)
2021-09-23 19:23:41.491 (P1 Elektra/Gas) General/Voltage (Voltage L3)
2021-09-23 19:23:41.492 (P1 Elektra/Gas) Usage (Usage L1)
2021-09-23 19:23:41.494 (P1 Elektra/Gas) Usage (Usage L2)
2021-09-23 19:23:41.495 (P1 Elektra/Gas) Usage (Usage L3)
2021-09-23 19:23:41.497 (P1 Elektra/Gas) Usage (Delivery L1)
2021-09-23 19:23:41.498 (P1 Elektra/Gas) Usage (Delivery L2)
2021-09-23 19:23:41.500 (P1 Elektra/Gas) Usage (Delivery L3)
2021-09-23 19:23:42.488 (P1 Elektra/Gas) P1 Smart Meter (Elektra)
2021-09-23 19:23:42.490 (P1 Elektra/Gas) General/Voltage (Voltage L1)
2021-09-23 19:23:42.491 (P1 Elektra/Gas) General/Voltage (Voltage L2)
2021-09-23 19:23:42.493 (P1 Elektra/Gas) General/Voltage (Voltage L3)
Any idea how to disable these?
Thanks,
Eelco
Jan Jansen
Domoticz version: Stable
Re: Excessive logging of P1 Smart Meter with LAN interface
Post by Jan Jansen »
Take a closer look at the settings of the hardware for the P1 meter (rate limit)
erem
Domoticz version: 2021.1
Post by erem »
to disable these messages, switch off info logging in the hardware tab
like this
24-09-2021 12-25-55.jpg (39.33 KiB) Viewed 1061 times
Regards,
Rob
EddyG
Post by EddyG »
That is hide the messages. They still come every second now and that seems to me a little bit to much.
My P1 meter sends every 10 seconds a telegram with data and that looks good to me.
In a normal household environment 10 seconds is adequate.
Every second is flooding Domoticz.
erem
Post by erem »
if the message comes every second, you have a DSMR5 meter, IMHO
DSMR4.x sends every 10 seconds.
take Jan Janssen's advice and see if you can limit the sending at the P1 interface
if that is not an option, learn to live with it.
domoticz can handle this just fine.
Regards,
Rob
eelco
Post by eelco »
erem wrote: Friday 24 September 2021 12:27 to disable these messages, switch off info logging in the hardware tab
like this
This is what I was looking for but I do not see the option. Has this been recently added? I’m using a 2020.2 build.
erem
Post by erem »
@eelco
yes, this is new in the last stable (2021.1).
worth the upgrade, IMHO
Regards,
Rob
eelco
Post by eelco »
Thanks will do this as I just removed a 26g logfile 😂
EddyG
Post by EddyG »
If you have logfiles of 26Gb, try using logrotate. ;)
