Garbage collector deafvalapp doesn't work anymore
johnnie
Domoticz version: 4.10717
Post by johnnie »
Hello guru's,
Since a day or 2 the afvalapp in Garbage collector isn't showing any data anymore.
When I visit the site: deafvalapp.nl it does work.
Any ideas?
Tia, Johnnie
Raspi 3B+; Razberry zwave; zigbee; lots and lots of sensors
Lokonli
Re: Garbage collector deafvalapp doesn't work anymore
Post by Lokonli »
On my system de afvalapp is working.
What is your Dashticz version? try latest beta.
What is your zipcode? Then I'll test.
jvdz
Post by jvdz »
Maybe because they don't allow http:// anymore and you need to use https:// ?
I had the same in my scripts.
Jos
Lokonli
Post by Lokonli »
Thanks for the feedback Jos.
I noticed the http request was redirected to https, which worked on my system, but can give issues on other systems.
In the latest beta I've changed the http request for deafvalapp into https.
johnnie
Post by johnnie »
Hi All,
Sorry for the late response, Im running v30 production. Ill send zip with pm.
Ill try this week the latest beta, and will let know.
Tia Johnnie
johnnie
Post by johnnie »
Hi Lokonli,
I downloaded the latest beta (I'm running it on a Synology NAS), no luck.
See config and picture for the output.
var config = {}
config['domoticz_ip'] = 'http://192.168.1.3:8084';
config['app_title'] = 'Dashticz V3';
var publictransport = {}
publictransport.ovinfobus = { show_via: false, station: 'son-en-breugel/bushalte-penseelkever', provider: '9292-bus', icon: 'bus', width:5, results: 6 }
var tvguide = {}
tvguide.dutch = { key:'dutch', icon: 'fas fa-tv', width:7, channels: [1,3,4,31,46,92], maxitems: 5 }
var _STREAMPLAYER_TRACKS = [
{"track":1,"name":"Q-music","file":"http://icecast-qmusic.cdp.triple-it.nl/ ... ive_96.mp3"},
{"track":2,"name":"538 Hitzone","file":"http://vip-icecast.538.lw.triple-it.nl/WEB11_MP3"},
{"track":3,"name":"Slam! NonStop","file":"http://stream.radiocorp.nl/web10_mp3"},
{"track":4,"name":"100%NL","file":"http://stream.100p.nl/100pctnl.mp3"},
var buttons = {}
buttons.nunl = {key: 'nunl', width:12, icon: 'fa-newspaper-o', title: 'Nu.nl', newwindow:true, url: 'http://www.nu.nl'}
buttons.nos = {key: 'nos', width:12, icon: 'fa-newspaper-o', title: 'Nos', url: 'http://www.nos.nl'}
var blocks = {}
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['key'] = 'blocktitle_1';
blocks['blocktitle_1']['title'] = 'Example';
blocks['mygarbage'] = {
company: 'deafvalapp',
zipcode: 'zip',
street: 'straat',
housenumber: 1,
maxitems: 12,
width: 12
var columns = {}
columns['bar'] = {}
columns[1] = {}
columns[1]['blocks'] = ['currentweather_big','weather']
columns[1]['width'] = 5;
columns[2] = {}
columns[2]['blocks'] = ['blocktitle_1',tvguide.dutch,publictransport.ovinfobus]
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = ['mygarbage'] //'sunrise','streamplayer', ,buttons.nunl,buttons.nos
columns[3]['width'] = 2;
var columns_standby = {}
columns_standby[1] = {}
columns_standby[1]['blocks'] = ['clock','weather']
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg2.jpg';
The output :
Any ideas?
Tia Johnnie
Lokonli
Post by Lokonli »
johnnie wrote: Wednesday 02 December 2020 18:34 Hi Lokonli,
The output :garbage_beta_deafvalapp.jpg
Any ideas?
Tia Johnnie
I tried the afvalkalender gemeente Zalbommel:
https://www.afvalinfo.nl/afvalkalender/ ... zaltbommel
Also there your zipcode doesn't work.
So it seems that for your zipcode the afvalapp doesn't work at the moment.
If you can find a working website where you can retrieve your garbage collection data then let me know.
Lokonli
Post by Lokonli »
Lokonli wrote: Wednesday 02 December 2020 20:36
Any ideas?
Tia Johnnie
Via avri it works:
https://www.avri.nl/inwoners/afval/afvalkalender/
I'll check whether I can fix this in Dashticz as well.
johnnie
Post by johnnie »
Hi Lokonli,
Thanks for you"re effort, I just tried: http://www.deafvalapp.nl/, see screenshot.
Maybe this helps?
Tia Johnnie
Lokonli
Post by Lokonli »
I see Zaltbommel uses avri, and avri uses Ximmio as data provider. Luckily Ximmio is supported by Dashticz already.
I'm in the middle of a small garbage update. I'll add avri as garbage provider in that update as well.
johnnie
Post by johnnie »
Lokonli wrote: Wednesday 02 December 2020 20:53 I see Zaltbommel uses avri, and avri uses Ximmio as data provider. Luckily Ximmio is supported by Dashticz already.
Great! Johnnie
Lokonli
Post by Lokonli »
Done. I've added 'avri' as garbage company to latest beta.
johnnie
Post by johnnie »
Lokonli wrote: Wednesday 02 December 2020 22:48 Done. I've added 'avri' as garbage company to latest beta.
Ow wouw that’s quick, hopefully I can test it this evening!
Johnnie
johnnie
Post by johnnie »
Hi Lokonli,
Yesss works!
Johnnie
Lokonli
Post by Lokonli »
Good! Thanks for the feedback :)
johnnie
Post by johnnie »
Hi Lokonli,
Herewith an impresion of the integration of AVRI in the recently made Dashticz frontend. Works fine again.
Thanks for the quick fix, Johnnie
Lokonli
Post by Lokonli »
Nice layout!
