Garbage collector deafvalapp doesn't work anymore
johnnie
- Domoticz version: 4.10717
Hello guru's,
Since a day or 2 the afvalapp in Garbage collector isn't showing any data anymore.
When I visit the site: deafvalapp.nl it does work.
Any ideas?
Tia, Johnnie
Any ideas?
Tia, Johnnie
Raspi 3B+; Razberry zwave; zigbee; lots and lots of sensors
Lokonli
Re: Garbage collector deafvalapp doesn't work anymore
On my system de afvalapp is working.
What is your Dashticz version? try latest beta.
What is your zipcode? Then I'll test.
- jvdz
Maybe because they don't allow http:// anymore and you need to use https:// ?
I had the same in my scripts.
Jos
Jos
Lokonli
Thanks for the feedback Jos.
I noticed the http request was redirected to https, which worked on my system, but can give issues on other systems.
In the latest beta I've changed the http request for deafvalapp into https.
johnnie
Hi All,
Sorry for the late response, Im running v30 production. Ill send zip with pm.
Ill try this week the latest beta, and will let know.
Tia Johnnie
Tia Johnnie
johnnie
Hi Lokonli,
I downloaded the latest beta (I'm running it on a Synology NAS), no luck.
See config and picture for the output.
Tia Johnnie
- Spoiler: show
Tia Johnnie
Lokonli
I tried the afvalkalender gemeente Zalbommel:johnnie wrote: Wednesday 02 December 2020 18:34 Hi Lokonli,
The output :garbage_beta_deafvalapp.jpg
Any ideas?
Tia Johnnie
https://www.afvalinfo.nl/afvalkalender/ ... zaltbommel
Also there your zipcode doesn't work.
So it seems that for your zipcode the afvalapp doesn't work at the moment.
If you can find a working website where you can retrieve your garbage collection data then let me know.
Lokonli
Via avri it works:Lokonli wrote: Wednesday 02 December 2020 20:36I tried the afvalkalender gemeente Zalbommel:johnnie wrote: Wednesday 02 December 2020 18:34 Hi Lokonli,
Any ideas?
Tia Johnnie
https://www.avri.nl/inwoners/afval/afvalkalender/
I'll check whether I can fix this in Dashticz as well.
johnnie
Hi Lokonli,
Thanks for you"re effort, I just tried: http://www.deafvalapp.nl/, see screenshot.
Maybe this helps?
Tia Johnnie
Maybe this helps?
Tia Johnnie
Lokonli
I see Zaltbommel uses avri, and avri uses Ximmio as data provider. Luckily Ximmio is supported by Dashticz already.
I'm in the middle of a small garbage update. I'll add avri as garbage provider in that update as well.
johnnie
Great! JohnnieLokonli wrote: Wednesday 02 December 2020 20:53 I see Zaltbommel uses avri, and avri uses Ximmio as data provider. Luckily Ximmio is supported by Dashticz already.
Lokonli
Done. I've added 'avri' as garbage company to latest beta.
johnnie
Ow wouw that’s quick, hopefully I can test it this evening!Lokonli wrote: Wednesday 02 December 2020 22:48 Done. I've added 'avri' as garbage company to latest beta.
Johnnie
johnnie
Hi Lokonli,
Yesss works!
Johnnie
Yesss works!
Johnnie
Lokonli
Good! Thanks for the feedback
johnnie
Hi Lokonli,
Herewith an impresion of the integration of AVRI in the recently made Dashticz frontend. Works fine again. Thanks for the quick fix, Johnnie
Lokonli
Nice layout!
