No device for temperature on Eurotronic spiritz thermostat Topic is solved
tlansbergen
Post by tlansbergen »
Hi there,
I've added a Eurotronics Spritz z-wave thermostat. From the ozw panel I can see the thermostat reports the actual temperature. However domoticz created a lot of devices temperature is not one of them.
Is there a way to get a device for the temperature?
OZW Panel
OZW Panel
EddyG
Re: No device for temperature on Eurotronic spiritz thermostat
Post by EddyG »
What Domoticz version and ZWave version are you on, because I have another screen.
Currently I have 10 devices created.
Maxx
Post by Maxx »
I have 3 eurotronics, the temperature device looks as follows:
	4961	Zwave netwerk	0E01	1	TK_Eetkamer_Temp	Temp	LaCrosse TX3	20.1 C
tlansbergen
Hi Maxx, that is what I expect to see. Was this device added automatically or did you add it some other way?
Maxx
Post by Maxx »
It was added automatically,
I am running one of the latest beta's of domoticz. What version are you using?
EddyG
Post by EddyG »
All Zwave devices should be auto-created by Domoticz. How else should the Zwave system know which device to update.
It might take some time for every device to be created, even up to a day.
On beta version 12501 it should look like this.
But the best way to help you is by knowing which version you are using. ;)
tlansbergen
EddyG wrote: Wednesday 28 October 2020 9:29 All Zwave devices should be auto-created by Domoticz. How else should the Zwave system know which device to update.
You were right, eventually the temperature device showed up. Probably triggered by a change of temperature large enough to sent a message out.
Maxx
Post by Maxx »
Another question since you both use the eurotronic. How long do your batteries last. Mine about 6 weeks in the wintertime. I have a zigbee version wich lasts 5 months.
EddyG
Post by EddyG »
I really do not count month, but at least 6 month to close to a year.
I open and close some of those valves 2 times a day automatically and sometimes 1 or 2 times a day manually.
They are open and regulating the valve during 4 hours.
During summertime they always open on 28 degrees C. because the heating is off.
You can check the device Level and see how often and how much "Set level" is changed, that is an indication for how often the motor is actuated.
harrykausl
Domoticz version: 2021.1
Post by harrykausl »
@transbergen : I had to reboot, then the device was visible.
@EddyG : In summertime or when my window sensor detects open window I set the heating mode of the Spiritz to off.
EddyG
Post by EddyG »
In summertime I open the thermostat only for technical reason.
My pump starts every week (random) for a short period to keep it from getting stuck, so I open the thermostats permanently to get the flow also thru the radiators.
