No device for temperature on Eurotronic spiritz thermostat Topic is solved
tlansbergen
Hi there,
I've added a Eurotronics Spritz z-wave thermostat. From the ozw panel I can see the thermostat reports the actual temperature. However domoticz created a lot of devices temperature is not one of them.
Is there a way to get a device for the temperature?
Re: No device for temperature on Eurotronic spiritz thermostat
What Domoticz version and ZWave version are you on, because I have another screen.
Currently I have 10 devices created.
Maxx
I have 3 eurotronics, the temperature device looks as follows:
4961 Zwave netwerk 0E01 1 TK_Eetkamer_Temp Temp LaCrosse TX3 20.1 C-
tlansbergen
Hi Maxx, that is what I expect to see. Was this device added automatically or did you add it some other way?
Maxx
It was added automatically,
I am running one of the latest beta's of domoticz. What version are you using?
All Zwave devices should be auto-created by Domoticz. How else should the Zwave system know which device to update.
It might take some time for every device to be created, even up to a day.
On beta version 12501 it should look like this. But the best way to help you is by knowing which version you are using.
tlansbergen
You were right, eventually the temperature device showed up. Probably triggered by a change of temperature large enough to sent a message out.EddyG wrote: Wednesday 28 October 2020 9:29 All Zwave devices should be auto-created by Domoticz. How else should the Zwave system know which device to update.
But the best way to help you is by knowing which version you are using.![]()
Maxx
Another question since you both use the eurotronic. How long do your batteries last. Mine about 6 weeks in the wintertime. I have a zigbee version wich lasts 5 months.
I really do not count month, but at least 6 month to close to a year.
I open and close some of those valves 2 times a day automatically and sometimes 1 or 2 times a day manually.
They are open and regulating the valve during 4 hours.
During summertime they always open on 28 degrees C. because the heating is off.
You can check the device Level and see how often and how much "Set level" is changed, that is an indication for how often the motor is actuated.
harrykausl
- Domoticz version: 2021.1
@transbergen : I had to reboot, then the device was visible.
@EddyG : In summertime or when my window sensor detects open window I set the heating mode of the Spiritz to off.
In summertime I open the thermostat only for technical reason.
My pump starts every week (random) for a short period to keep it from getting stuck, so I open the thermostats permanently to get the flow also thru the radiators.
