Dashticz - ANWB traffic info
Lokonli
It seems ANWB traffic info is not working anymore. ANWB currently is not providing traffic info anymore via the API that was used by Dashticz.
Let's wait a few days: maybe it returns.
Otherwise we could switch for instance to the RSS feed of verkeerplaza.nl.
Other suggestions are welcome as well.
BoelShit
Re: Dashticz - ANWB traffic info
As I did the ANWB trafficinfo part I've looked into why its not working anymore. Seems ANWB switched to an other API.
Not so difficult to change to the new API but there are no trafficjams to test on
Franzie
- Domoticz version: 2020.1
@BoelShit How to change to the new API?
BoelShit
It is being worked on atm. It's not just changing the url of the API, they've changed the structure of the data a bit.
Franzie
Top!!BoelShit wrote: Tuesday 28 April 2020 19:58 It is being worked on atm. It's not just changing the url of the API, they've changed the structure of the data a bit.
Lokonli
The ANWB traffic info has been fixed in latest beta. (thanks to @BoelShit!)
Brinkie
I still have an issue with ANWB traffic. Even on the latest beta version V3.4.5.
cors-anywhere.herokuapp.com/https://api.anwb.nl/v1/incidents?apikey=xxxx Failed to load resource: the server responded with a status of 400 (Bad Request)
When i run it on the demo site of cors-anywhere i get the following message:
GET https://cors-anywhere.herokuapp.com/htt ... pikey=xxxx
400 Bad Request
{"errors": [{"title":"Bad Request","message":"Invalid origin.", "code":9}]}
400 Bad Request
Lokonli
Try to use the Dashticz internal CORS proxy.
Brinkie
I do use the internal CORS proxy.
config['default_cors_url'] = 'http://cors-anywhere.herokuapp.com/';
or should it be different?
Lokonli
That is the external CORS proxy.Brinkie wrote: Thursday 30 April 2020 14:08I do use the internal CORS proxy.
You can remove the default_cors_url setting from CONFIG.js. The default CORS url will then be used automatically.
If you've installed PHP according the installation instructions, the internal PHP based CORS proxy will be used.
Brinkie
Thanks! I had PHP installed, but did’t set the option OpenSSL. It works now.Lokonli wrote: Thursday 30 April 2020 15:53That is the external CORS proxy.Brinkie wrote: Thursday 30 April 2020 14:08I do use the internal CORS proxy.
JanvdW
The anwb traffic info works fine, but the predefined block 'traffic' doesn't show any information either. Has this the same cause?
Brinkie
What do you mean with predefined block traffic. I use this in my config.js fileJanvdW wrote: Friday 01 May 2020 17:57 The anwb traffic info works fine, but the predefined block 'traffic' doesn't show any information either. Has this the same cause?
var trafficinfo = {}
trafficinfo.anwba1 = {
key:'anwba28',
provider: 'anwb',
road:'A1',
trafficJams: true,
roadWorks: true,
radars: true,
show_lastupdate:true,
icon: 'fas fa-car',
width:12,
results: 10 };
- HansieNL
- Spoiler: show
Blah blah blah
JanvdW
Yes, that's right. As far as I know you can't configure anything for the 'traffic' block, so it hardly can't be a configuration issue
JanvdW
Do you know if this problem is applicable for the predefined block 'traffic' as well? If so,who is able to fix that?Lokonli wrote: Wednesday 29 April 2020 10:05 The ANWB traffic info has been fixed in latest beta. (thanks to @BoelShit!)
BoelShit
I've looked at the traffic block for you and the whole source (http://www.vid.nl/VI/_rss) of information isn't available anymore. So if there is no other similar source I think it will be hard to fix. Can't recall what it showed when it did work.
Lokonli
It showed this:BoelShit wrote: Wednesday 13 May 2020 16:45 I've looked at the traffic block for you and the whole source (http://www.vid.nl/VI/_rss) of information isn't available anymore. So if there is no other similar source I think it will be hard to fix. Can't recall what it showed when it did work.
The first block is the traffic block, the second one the train block.
It was just one line of text, and a clickable button, which opens the Rijkswaterstaat traffic info.
For instance this link:
https://rwsverkeersinfo.nl/actuele-verkeersinfo
JanvdW
I see no update on this topic. If it can't be fixed I suppose that the documentation should be updated (https://dashticz.readthedocs.io/_/downl ... /beta/pdf/)
- HansieNL
@BoelShit Can we use the following url for traffic block: https://api.rwsverkeersinfo.nl/api/traffic/
Blah blah blah
