Dashticz - ANWB traffic info
It seems ANWB traffic info is not working anymore. ANWB currently is not providing traffic info anymore via the API that was used by Dashticz.
Let's wait a few days: maybe it returns.
Otherwise we could switch for instance to the RSS feed of verkeerplaza.nl.
Other suggestions are welcome as well.
Re: Dashticz - ANWB traffic info
As I did the ANWB trafficinfo part I've looked into why its not working anymore. Seems ANWB switched to an other API.
Not so difficult to change to the new API but there are no trafficjams to test on
- Domoticz version: 2020.1
@BoelShit How to change to the new API?
It is being worked on atm. It's not just changing the url of the API, they've changed the structure of the data a bit.
The ANWB traffic info has been fixed in latest beta. (thanks to @BoelShit!)
I still have an issue with ANWB traffic. Even on the latest beta version V3.4.5.
cors-anywhere.herokuapp.com/https://api.anwb.nl/v1/incidents?apikey=xxxx Failed to load resource: the server responded with a status of 400 (Bad Request)
When i run it on the demo site of cors-anywhere i get the following message:
GET https://cors-anywhere.herokuapp.com/htt ... pikey=xxxx
400 Bad Request
{"errors": [{"title":"Bad Request","message":"Invalid origin.", "code":9}]}
400 Bad Request
Try to use the Dashticz internal CORS proxy.
I do use the internal CORS proxy.
config['default_cors_url'] = 'http://cors-anywhere.herokuapp.com/';
or should it be different?
That is the external CORS proxy.Brinkie wrote: ↑Thursday 30 April 2020 14:08I do use the internal CORS proxy.
You can remove the default_cors_url setting from CONFIG.js. The default CORS url will then be used automatically.
If you've installed PHP according the installation instructions, the internal PHP based CORS proxy will be used.
Thanks! I had PHP installed, but did’t set the option OpenSSL. It works now.Lokonli wrote: ↑Thursday 30 April 2020 15:53That is the external CORS proxy.Brinkie wrote: ↑Thursday 30 April 2020 14:08I do use the internal CORS proxy.
The anwb traffic info works fine, but the predefined block 'traffic' doesn't show any information either. Has this the same cause?
What do you mean with predefined block traffic. I use this in my config.js file
var trafficinfo = {}
trafficinfo.anwba1 = {
key:'anwba28',
provider: 'anwb',
road:'A1',
trafficJams: true,
roadWorks: true,
radars: true,
show_lastupdate:true,
icon: 'fas fa-car',
width:12,
results: 10 };
- HansieNL
- Spoiler: show
Blah blah blah
Yes, that's right. As far as I know you can't configure anything for the 'traffic' block, so it hardly can't be a configuration issue
I've looked at the traffic block for you and the whole source (http://www.vid.nl/VI/_rss) of information isn't available anymore. So if there is no other similar source I think it will be hard to fix. Can't recall what it showed when it did work.
It showed this:BoelShit wrote: ↑Wednesday 13 May 2020 16:45 I've looked at the traffic block for you and the whole source (http://www.vid.nl/VI/_rss) of information isn't available anymore. So if there is no other similar source I think it will be hard to fix. Can't recall what it showed when it did work.
The first block is the traffic block, the second one the train block.
It was just one line of text, and a clickable button, which opens the Rijkswaterstaat traffic info.
For instance this link:
https://rwsverkeersinfo.nl/actuele-verkeersinfo
I see no update on this topic. If it can't be fixed I suppose that the documentation should be updated (https://dashticz.readthedocs.io/_/downl ... /beta/pdf/)
- HansieNL
@BoelShit Can we use the following url for traffic block: https://api.rwsverkeersinfo.nl/api/traffic/
Blah blah blah
