Zigate/zigbee heal function?
tjabas
Post by tjabas »
Hi!
i have some problems with my zigate, sometimes when i make a restart of Domoticz i notice that not all of my zigbee devices will connect, i have looked around alot on the web and this forum without any solutions, i have also tried different zigbee channels with no luck, it seems like for every reboot of the rpi i do i loose some nodes/devices in domoticz, the solution is to re pair the lost devices, that is not what i want to do, it takes some time to do it.
I also wonder if there is a heal function in the zigate plugin, like the one that z-wave uses?
Damsee
Domoticz version: 4.10717
Re: Zigate/zigbee heal function?
Post by Damsee »
Not aware of any heal function with Zigate or Zigate plugin but you should investigate the reason and root cause of devices loss...
From my experience, it's better to set a fixed channel.
Did you experience some changes in the channel used by Zigate upon DZ reboot ?
RPI3 Raspbian Buster + Domoticz v2020.1 stable + RFXtrx433E + Z-Stick Gen5 + Amazon Echo (alexicz)
x5 THGN810 / x5 ZMNHJD1 / x2 Flood sensor FGFS101 / x1 Smoke sensor FGSD002
x1 ZMNHAD1 / x2 FGS213 / x3 Wallplug FGWPE/F / NodOn Soft remote CRC-3-6-0
pipiche
Post by pipiche »
tjabas wrote: Sunday 19 January 2020 23:13 Hi!
Very strange .
(1) What is the firmware you are running on Zigate ? Firmware 3.0e has such issue, which is loosing devices after reboot
(2) After a reboot what does the logs said ? Maybe you are facing a configuration issue (like access right or something like that)
tjabas
Post by tjabas »
The logs dont give me any error codes during the start of the zigate plugin, i use the latest 3.1b, i think its called, Im at work now, i will look at the logs more when home.
pipiche
Post by pipiche »
If nothing in the log, and if you are able to pair other devices than this one, I beleive that is more that the Switch doesn't go in pairing mode.
tjabas
Post by tjabas »
Now i have checked the version and im on 3.1a, so i installed the latest 3.1b and changed to beta , but now my ikea fyrtur blinds doesnt work, and i cant seem to pair them again, aaah im getting frustrated.
