Hi!
i have some problems with my zigate, sometimes when i make a restart of Domoticz i notice that not all of my zigbee devices will connect, i have looked around alot on the web and this forum without any solutions, i have also tried different zigbee channels with no luck, it seems like for every reboot of the rpi i do i loose some nodes/devices in domoticz, the solution is to re pair the lost devices, that is not what i want to do, it takes some time to do it.
I also wonder if there is a heal function in the zigate plugin, like the one that z-wave uses?
Zigate/zigbee heal function?
Damsee
- Domoticz version: 4.10717
Re: Zigate/zigbee heal function?
Not aware of any heal function with Zigate or Zigate plugin but you should investigate the reason and root cause of devices loss...
From my experience, it's better to set a fixed channel.
Did you experience some changes in the channel used by Zigate upon DZ reboot ?
RPI3 Raspbian Buster + Domoticz v2020.1 stable + RFXtrx433E + Z-Stick Gen5 + Amazon Echo (alexicz)
x5 THGN810 / x5 ZMNHJD1 / x2 Flood sensor FGFS101 / x1 Smoke sensor FGSD002
x1 ZMNHAD1 / x2 FGS213 / x3 Wallplug FGWPE/F / NodOn Soft remote CRC-3-6-0
Very strange .tjabas wrote: Sunday 19 January 2020 23:13 Hi!
(1) What is the firmware you are running on Zigate ? Firmware 3.0e has such issue, which is loosing devices after reboot
(2) After a reboot what does the logs said ? Maybe you are facing a configuration issue (like access right or something like that)
tjabas
The logs dont give me any error codes during the start of the zigate plugin, i use the latest 3.1b, i think its called, Im at work now, i will look at the logs more when home.
If nothing in the log, and if you are able to pair other devices than this one, I beleive that is more that the Switch doesn't go in pairing mode.
tjabas
Now i have checked the version and im on 3.1a, so i installed the latest 3.1b and changed to beta , but now my ikea fyrtur blinds doesnt work, and i cant seem to pair them again, aaah im getting frustrated.
