Reset automatic Textlog sensors
JanAtHome
Domoticz version: 38153
Post by JanAtHome »
Over Domoticz
Version: 4.11605
Build Hash: 7de1f368f
Compile Date: 2020-01-08 23:12:15
dzVents Version: 2.5.5
Python Version: 3.7.3 (default, Apr 3 2019, 05:39:12) [GCC 8.2.0]
Hey
I am looking for a command to reset the text log of a switch / sensor via a script file.
I am looking for the command that is under the delete button (wissen).
Re: Reset automatic Textlog sensors
JanAtHome wrote: Wednesday 15 January 2020 15:10 I am looking for a command to reset the text log of a switch / sensor via a script file.
Can you try this one ?
read the comments in the script first. If anything is not clear please feel free to ask
local scriptVar = 'textClearAPI'
return
    on =
        devices =
            'clearText',    -- create as a virtual selector type switch. Levels 0 = 'Off',
                            -- 10, 20, etc.. like clear nameOfDevicetoClear log & text
                            -- name of the device to clear must be the second word in the level
        httpResponses =
            scriptVar,
    logging =
        level = domoticz.LOG_DEBUG, -- set to LOG_ERROR when tested and OK
        marker = 'Clear text and log: ',
    execute = function(dz, item)
        local function getAndClearLightLog(idx)
            local getTextURL =  dz.settings['Domoticz url'] .. '/json.htm?type=textlog&idx=' .. idx
            local deleteTextURL = dz.settings['Domoticz url'] .. '/json.htm?type=command&param=clearlightlog&idx=' .. idx
            dz.openURL(
                url = getTextURL,
                method = "GET",
                callback = scriptVar,
            dz.openURL(deleteTextURL).afterSec(3)
        if item.isDevice and item.level ~= 0 then
            clearDevice = dz.devices(dz.utils.stringSplit(item.levelName,' ')[2])
            dz.log('current text: ' .. clearDevice.state)
            if clearDevice.deviceSubType == 'Text' then clearDevice.updateText('').silent() end
            getAndClearLightLog(clearDevice.id)
            item.switchOff().silent()
        elseif item.isHTTPResponse then
            for index, record in ipairs( item.json.result) do
                dz.log(record.Date .. ' ' .. record.Data)
JanAtHome
Post by JanAtHome »
Waaren tks
I will convert the script.
What matters to me is that the logs of certain sensors are emptied every month.
Or maybe even better, save the last 50 or 100 (adjustable).
And automatically erase the rest.
Thanks in advance for this example.
JanAtHome wrote: Wednesday 15 January 2020 22:59 ... a nd automatically erase the rest.
Is this not already a standard feature of domoticz that can be configured in [setup] [settings] [log history] ?
JanAtHome
Post by JanAtHome »
That are all sensors.
JanAtHome wrote: Thursday 16 January 2020 9:47 That are all sensors.
No. Also Switches / lights
JanAtHome
Post by JanAtHome »
Hello Waaren
You misunderstand me.
I mean that I want to reset some sensors / switches / lights logs, not all. But only the item I have chosen.
JanAtHome wrote: Thursday 16 January 2020 22:36 I mean that I want to reset some sensors / switches / lights logs, not all. But only the item I have chosen.
OK, understand now. Thx for clarifying.
