Over Domoticz
Version: 4.11605
Build Hash: 7de1f368f
Compile Date: 2020-01-08 23:12:15
dzVents Version: 2.5.5
Python Version: 3.7.3 (default, Apr 3 2019, 05:39:12) [GCC 8.2.0]
Hey
I am looking for a command to reset the text log of a switch / sensor via a script file.
I am looking for the command that is under the delete button (wissen).
Reset automatic Textlog sensors
- waaren
Re: Reset automatic Textlog sensors
Can you try this one ?JanAtHome wrote: Wednesday 15 January 2020 15:10 I am looking for a command to reset the text log of a switch / sensor via a script file.
read the comments in the script first. If anything is not clear please feel free to ask
local scriptVar = 'textClearAPI'
return
on =
devices =
'clearText', -- create as a virtual selector type switch. Levels 0 = 'Off',
-- 10, 20, etc.. like clear nameOfDevicetoClear log & text
-- name of the device to clear must be the second word in the level
httpResponses =
scriptVar,
logging =
level = domoticz.LOG_DEBUG, -- set to LOG_ERROR when tested and OK
marker = 'Clear text and log: ',
execute = function(dz, item)
local function getAndClearLightLog(idx)
local getTextURL = dz.settings['Domoticz url'] .. '/json.htm?type=textlog&idx=' .. idx
local deleteTextURL = dz.settings['Domoticz url'] .. '/json.htm?type=command¶m=clearlightlog&idx=' .. idx
dz.openURL(
url = getTextURL,
method = "GET",
callback = scriptVar,
dz.openURL(deleteTextURL).afterSec(3)
if item.isDevice and item.level ~= 0 then
clearDevice = dz.devices(dz.utils.stringSplit(item.levelName,' ')[2])
dz.log('current text: ' .. clearDevice.state)
if clearDevice.deviceSubType == 'Text' then clearDevice.updateText('').silent() end
getAndClearLightLog(clearDevice.id)
item.switchOff().silent()
elseif item.isHTTPResponse then
for index, record in ipairs( item.json.result) do
dz.log(record.Date .. ' ' .. record.Data)
}Debian buster, bullseye on RPI-4, Intel NUC.
JanAtHome
- Domoticz version: 38153
Waaren tks
I will convert the script.
What matters to me is that the logs of certain sensors are emptied every month.
Or maybe even better, save the last 50 or 100 (adjustable).
And automatically erase the rest.
Thanks in advance for this example.
- waaren
Is this not already a standard feature of domoticz that can be configured in [setup] [settings] [log history] ?
JanAtHome
That are all sensors.
- waaren
No. Also Switches / lights
JanAtHome
Hello Waaren
You misunderstand me.
I mean that I want to reset some sensors / switches / lights logs, not all. But only the item I have chosen.
- waaren
OK, understand now. Thx for clarifying.JanAtHome wrote: Thursday 16 January 2020 22:36 I mean that I want to reset some sensors / switches / lights logs, not all. But only the item I have chosen.
Users browsing this forum: Bing [Bot], JanJaap and 1 guest
