Another noob question (toonInfo)
OedzesG
Post by OedzesG »
Hallo everyone..
working a view weeks now with dzvents and thanks to you guys its going very well..
Now its time to going next level.. :D
Today i recieved my new rooted Toon thermostat.
Every thing is working wel..
so now i can use: http://192.168.1.61/happ_thermstat?acti ... mostatInfo
this gives my the following info
result: "ok",
currentTemp: "2112",
currentSetpoint: "2100",
currentInternalBoilerSetpoint: "25",
programState: "0",
activeState: "-1",
nextProgram: "-1",
nextState: "-1",
nextTime: "0",
nextSetpoint: "0",
randomConfigId: "1804289383",
errorFound: "255",
connection: "0",
burnerInfo: "0",
otCommError: "0",
currentModulationLevel: "5"
Now i want for example bring the currentModulationLevel, to a custom sensor.
i tried everything but for me nothing then error's.
I hope one of you guys can please help me with an litle example.
thnx in advance!
emme
Domoticz version: latest
Re: Another noob question (toonInfo)
Post by emme »
did they came between { and } ?
because you have posted a json object, but the parethesis are missing....
you can work it out with a dzvents HTTP resquest and reply... but before continuing I would like to be sure about what you get in reply
"We always done this way"
OedzesG wrote: Saturday 28 September 2019 23:37 so now i can use: http://192.168.1.61/happ_thermstat?acti ... mostatInfo
Can you execute this one first and share the output?
local scriptVersion = '0.201909291100'
local scriptVar  =  'ToonInfo_' .. scriptVersion
this dzVents script is used to collect data from Rooted Toon
It uses a openURL call and interprets the returned JSON.
Before activating the script:
    please read the GETTING STARTED section of the dzVents wiki.
    change xxx.xxx.xxx.xxx in this script to the IP of your Toon
    define a dummy hardware in domoticz if not already done
    define virtual sensors this dummy hardware
    and change the name in the device declarations
return
    on =
        timer = { 'every 1 minutes' },
        httpResponses = { scriptVar },
    logging =
        level = domoticz.LOG_DEBUG,
        marker = scriptVar,
   execute = function(dz, item)
        local toonIP =  '192.168.1.125'
        local function getToonInfo()
            local url = 'http://' .. toonIP .. '/happ_thermstat?action=getThermostatInfo'
            dz.openURL({ url = url, callback = scriptVar })
       -- main
        if item.isTimer or item.isDevice then
            getToonInfo()
        elseif item.ok then -- statusCode == 2xx
            dz.log(item.data,dz.LOG_DEBUG)
            dz.log('Could not get (good) data from ' .. toonIP .. '\n' .. item.data ,dz.LOG_ERROR)
        dz.utils.dumpTable(item)
OedzesG
Post by OedzesG »
2019-09-29 22:56:00.284 Status: dzVents: Info: ToonInfo_0.201909291100: ------ Start internal script: Script #2:, trigger: every 1 minutes
2019-09-29 22:56:00.284 Status: dzVents: Debug: ToonInfo_0.201909291100: OpenURL: url = http://192.168.1.61/happ_thermstat?action=getThermostatInfo
2019-09-29 22:56:00.284 Status: dzVents: Debug: ToonInfo_0.201909291100: OpenURL: method = GET
2019-09-29 22:56:00.284 Status: dzVents: Debug: ToonInfo_0.201909291100: OpenURL: post data = nil
2019-09-29 22:56:00.284 Status: dzVents: Debug: ToonInfo_0.201909291100: OpenURL: headers = nil
2019-09-29 22:56:00.284 Status: dzVents: Debug: ToonInfo_0.201909291100: OpenURL: callback = ToonInfo_0.201909291100
2019-09-29 22:56:00.284 Status: dzVents: > isGroup: false
2019-09-29 22:56:00.284 Status: dzVents: > isVariable: false
2019-09-29 22:56:00.284 Status: dzVents: > isHTTPResponse: false
2019-09-29 22:56:00.284 Status: dzVents: > isScene: false
2019-09-29 22:56:00.284 Status: dzVents: > isSecurity: false
2019-09-29 22:56:00.284 Status: dzVents: > trigger: every 1 minutes
2019-09-29 22:56:00.284 Status: dzVents: > isTimer: true
2019-09-29 22:56:00.285 Status: dzVents: > baseType: timer
2019-09-29 22:56:00.285 Status: dzVents: > isDevice: false
2019-09-29 22:56:00.285 Status: dzVents: Info: ToonInfo_0.201909291100: ------ Finished Script #2
2019-09-29 22:56:00.285 Status: EventSystem: Script event triggered: /usr/local/domoticz/dzVents/runtime/dzVents.lua
2019-09-29 22:56:00.497 Status: dzVents: Info: Handling httpResponse-events for: "ToonInfo_0.201909291100
2019-09-29 22:56:00.497 Status: dzVents: Info: ToonInfo_0.201909291100: ------ Start internal script: Script #2: HTTPResponse: "ToonInfo_0.201909291100"
2019-09-29 22:56:00.497 Status: dzVents: Debug: ToonInfo_0.201909291100: {"result":"ok", "currentTemp":"2064", "currentSetpoint":"1500", "currentInternalBoilerSetpoint":"6", "programState":"2", "activeState":"3", "nextProgram":"1", "nextState":"2", "nextTime":"1569790800","nextSetpoint":"1600","randomConfigId":"1804289383","errorFound":"255","connection":"0","burnerInfo":"0","otCommError":"0","currentModulationLevel":"0"}
2019-09-29 22:56:00.497 Status: dzVents: > isGroup: false
2019-09-29 22:56:00.497 Status: dzVents: > ok: true
2019-09-29 22:56:00.497 Status: dzVents: > isVariable: false
2019-09-29 22:56:00.497 Status: dzVents: > callback: ToonInfo_0.201909291100
2019-09-29 22:56:00.497 Status: dzVents: > isHTTPResponse: true
2019-09-29 22:56:00.497 Status: dzVents: > isScene: false
2019-09-29 22:56:00.497 Status: dzVents: > _contentType: text/javascript; charset=utf-8
2019-09-29 22:56:00.497 Status: dzVents: > trigger: ToonInfo_0.201909291100
2019-09-29 22:56:00.497 Status: dzVents: > data: {"result":"ok", "currentTemp":"2064", "currentSetpoint":"1500", "currentInternalBoilerSetpoint":"6", "programState":"2", "activeState":"3", "nextProgram":"1", "nextState":"2", "nextTime":"1569790800","nextSetpoint":"1600","randomConfigId":"1804289383","errorFound":"255","connection":"0","burnerInfo":"0","otCommError":"0","currentModulationLevel":"0"}
2019-09-29 22:56:00.497 Status: dzVents: > statusCode: 200
2019-09-29 22:56:00.497 Status: dzVents: > isSecurity: false
2019-09-29 22:56:00.497 Status: dzVents: > isDevice: false
2019-09-29 22:56:00.497 Status: dzVents: > isJSON: false
2019-09-29 22:56:00.498 Status: dzVents: > protocol: HTTP/1.1
2019-09-29 22:56:00.498 Status: dzVents: > statusText: OK
2019-09-29 22:56:00.498 Status: dzVents: > isTimer: false
2019-09-29 22:56:00.498 Status: dzVents: > baseType: httpResponse
2019-09-29 22:56:00.498 Status: dzVents: > headers:
2019-09-29 22:56:00.498 Status: dzVents: > Content-Length: 352
2019-09-29 22:56:00.498 Status: dzVents: > Date: Sun, 29 Sep 2019 20:56:00 GMT
2019-09-29 22:56:00.498 Status: dzVents: > Content-Type: text/javascript; charset=utf-8
2019-09-29 22:56:00.498 Status: dzVents: > Server: lighttpd/1.4.35
2019-09-29 22:56:00.498 Status: dzVents: Info: ToonInfo_0.201909291100: ------ Finished Script #2
2019-09-29 22:56:02.481 (Synology DS218 monitor) Light/Switch (Synology DS218 status)
2019-09-29 22:56:02.528 (Synology DS118 monitor) Light/Switch (Synology DS118 status)
2019-09-29 22:56:02.476 Status: User: Admin initiated a switch command (1/Synology DS218 status/On)
2019-09-29 22:56:02.523 Status: User: Admin initiated a switch command (9/Synology DS118 status/On)
2019-09-29 22:57:00.240 Status: dzVents: Info: ------ Start internal script: Script #1:, trigger: every minute
2019-09-29 22:57:00.294 Status: dzVents: Info: Thermostaat = 15
2019-09-29 22:57:00.294 Status: dzVents: Info: Modulatie niveau = 0
2019-09-29 22:57:00.295 Status: dzVents: Info: Huidige woonkamer temp = 20.6
2019-09-29 22:57:00.295 Status: dzVents: Info: ------ Finished Script #1
2019-09-29 22:57:00.295 Status: dzVents: Info: ToonInfo_0.201909291100: ------ Start internal script: Script #2:, trigger: every 1 minutes
2019-09-29 22:57:00.295 Status: dzVents: Debug: ToonInfo_0.201909291100: OpenURL: url = http://192.168.1.61/happ_thermstat?action=getThermostatInfo
2019-09-29 22:57:00.295 Status: dzVents: Debug: ToonInfo_0.201909291100: OpenURL: method = GET
2019-09-29 22:57:00.295 Status: dzVents: Debug: ToonInfo_0.201909291100: OpenURL: post data = nil
2019-09-29 22:57:00.295 Status: dzVents: Debug: ToonInfo_0.201909291100: OpenURL: headers = nil
2019-09-29 22:57:00.295 Status: dzVents: Debug: ToonInfo_0.201909291100: OpenURL: callback = ToonInfo_0.201909291100
2019-09-29 22:57:00.295 Status: dzVents: > baseType: timer
2019-09-29 22:57:00.295 Status: dzVents: > isTimer: true
2019-09-29 22:57:00.295 Status: dzVents: > isScene: false
2019-09-29 22:57:00.295 Status: dzVents: > isDevice: false
2019-09-29 22:57:00.295 Status: dzVents: > trigger: every 1 minutes
2019-09-29 22:57:00.295 Status: dzVents: > isSecurity: false
2019-09-29 22:57:00.295 Status: dzVents: > isGroup: false
2019-09-29 22:57:00.295 Status: dzVents: > isVariable: false
2019-09-29 22:57:00.296 Status: dzVents: > isHTTPResponse: false
2019-09-29 22:57:00.296 Status: dzVents: Info: ToonInfo_0.201909291100: ------ Finished Script #2
2019-09-29 22:57:00.296 Status: EventSystem: Script event triggered: /usr/local/domoticz/dzVents/runtime/dzVents.lua
2019-09-29 22:57:00.415 Status: dzVents: Info: Handling httpResponse-events for: "ToonInfo_0.201909291100
2019-09-29 22:57:00.415 Status: dzVents: Info: ToonInfo_0.201909291100: ------ Start internal script: Script #2: HTTPResponse: "ToonInfo_0.201909291100"
2019-09-29 22:57:00.416 Status: dzVents: Debug: ToonInfo_0.201909291100: {"result":"ok", "currentTemp":"2063", "currentSetpoint":"1500", "currentInternalBoilerSetpoint":"6", "programState":"2", "activeState":"3", "nextProgram":"1", "nextState":"2", "nextTime":"1569790800","nextSetpoint":"1600","randomConfigId":"1804289383","errorFound":"255","connection":"0","burnerInfo":"0","otCommError":"0","currentModulationLevel":"0"}
2019-09-29 22:57:00.416 Status: dzVents: > headers:
2019-09-29 22:57:00.417 Status: dzVents: > Content-Length: 352
2019-09-29 22:57:00.417 Status: dzVents: > Content-Type: text/javascript; charset=utf-8
2019-09-29 22:57:00.417 Status: dzVents: > Server: lighttpd/1.4.35
2019-09-29 22:57:00.417 Status: dzVents: > Date: Sun, 29 Sep 2019 20:57:00 GMT
2019-09-29 22:57:00.417 Status: dzVents: > isTimer: false
2019-09-29 22:57:00.417 Status: dzVents: > isScene: false
2019-09-29 22:57:00.417 Status: dzVents: > isDevice: false
2019-09-29 22:57:00.417 Status: dzVents: > trigger: ToonInfo_0.201909291100
2019-09-29 22:57:00.417 Status: dzVents: > data: {"result":"ok", "currentTemp":"2063", "currentSetpoint":"1500", "currentInternalBoilerSetpoint":"6", "programState":"2", "activeState":"3", "nextProgram":"1", "nextState":"2", "nextTime":"1569790800","nextSetpoint":"1600","randomConfigId":"1804289383","errorFound":"255","connection":"0","burnerInfo":"0","otCommError":"0","currentModulationLevel":"0"}
2019-09-29 22:57:00.417 Status: dzVents: > isGroup: false
2019-09-29 22:57:00.417 Status: dzVents: > _contentType: text/javascript; charset=utf-8
2019-09-29 22:57:00.417 Status: dzVents: > baseType: httpResponse
2019-09-29 22:57:00.417 Status: dzVents: > ok: true
2019-09-29 22:57:00.417 Status: dzVents: > isHTTPResponse: true
2019-09-29 22:57:00.417 Status: dzVents: > protocol: HTTP/1.1
2019-09-29 22:57:00.417 Status: dzVents: > statusCode: 200
2019-09-29 22:57:00.417 Status: dzVents: > isVariable: false
2019-09-29 22:57:00.417 Status: dzVents: > statusText: OK
2019-09-29 22:57:00.417 Status: dzVents: > isJSON: false
2019-09-29 22:57:00.417 Status: dzVents: > callback: ToonInfo_0.201909291100
2019-09-29 22:57:00.417 Status: dzVents: > isSecurity: false
2019-09-29 22:57:00.417 Status: dzVents: Info: ToonInfo_0.201909291100: ------ Finished Script #2
OedzesG
Post by OedzesG »
But today i had some time to make some test...
I thought it would be good to check if everything is working correctly by bringing the data to the domoticz logfiles.
After a lot if reading on the internet i found a solution...
This is what i have so far..
	on = {timer = {'every minute'}},
	execute = function(domoticz)
	local ToonIP     						= '192.168.1.61'
	local json 							= assert(loadfile "/usr/local/domoticz/var/scripts/lua/JSON.lua")()
	local handle 						= assert(io.popen(string.format('curl http://%s/happ_thermstat?action=getThermostatInfo', ToonIP)))
	local ThermostatInfo					= handle:read('*all')
									  handle:close()
	local jsonThermostatInfo 				= json:decode(ThermostatInfo)
	if jsonThermostatInfo 				== nil then
	return
  --Ingestelde programma
	local hudige_programma   	            = tonumber(jsonThermostatInfo.activeState)
    if          hudige_programma              == -1 then domoticz.log ('Huidige programma = Handmatig')
    elseif      hudige_programma            == 0 then domoticz.log  ('Huidige programma = Comfort')
    elseif      hudige_programma            == 1 then domoticz.log  ('Huidige programma = Thuis')
    elseif      hudige_programma            == 2 then domoticz.log  ('Huidige programma = Slapen')
    elseif      hudige_programma            == 3 then domoticz.log  ('Huidige programma = Weg')
    elseif      hudige_programma            == 4 then domoticz.log  ('Huidige programma = Vakantie')
  --Automatich programma
	local automatisch_programma		= tonumber(jsonThermostatInfo.programState)
	if          automatisch_programma       == 0 then domoticz.log  ('Toon programma = Handmatig')
	elseif      automatisch_programma     == 1 then domoticz.log  ('Toon programma = Automatisch')
	elseif      automatisch_programma     == 2 then domoticz.log  ('Toon programma = Automatisch met tijdelijk afwijkend programma')
   	elseif      automatisch_programma     == 8 then domoticz.log  ('Toon programma = Automatisch met continu afwijkend programma')
  --Huidige thermostaat waarde
	local waarde_thermostaat				= tonumber(jsonThermostatInfo.currentSetpoint) / 100
	domoticz.log('Thermostaat	 		= ' .. tostring(waarde_thermostaat), domoticz.LOG_INFO)
  --Modulatie niveau
	local modulatie_niveau       			= tonumber(jsonThermostatInfo.currentModulationLevel)
	domoticz.log('Modulatie niveau 			= ' .. tostring(modulatie_niveau), domoticz.LOG_INFO)
  --Temperatuur woonkamer
	local woonkamer_temperatuur			= domoticz.utils.round(tonumber(jsonThermostatInfo.currentTemp) / 100,1)
	domoticz.log('Huidige woonkamer temp 	= ' .. tostring(woonkamer_temperatuur), domoticz.LOG_INFO)
2019-09-29 23:53:00.203 Status: dzVents: Info: ------ Start internal script: Script #1:, trigger: every minute
2019-09-29 23:53:00.254 Status: dzVents: Info: Huidige programma = Slapen
2019-09-29 23:53:00.254 Status: dzVents: Info: Toon programma = Automatisch
2019-09-29 23:53:00.254 Status: dzVents: Info: Thermostaat = 16
2019-09-29 23:53:00.255 Status: dzVents: Info: Modulatie niveau = 0
2019-09-29 23:53:00.255 Status: dzVents: Info: Huidige woonkamer temp = 20.3
2019-09-29 23:53:00.255 Status: dzVents: Info: ------ Finished Script #1
OedzesG wrote: Sunday 29 September 2019 23:54 But today i had some time to make some test...
Good start !
Have a look at the attached where the curl command is replaced by the async openURL command. This will prevent the domoticz event system to come to a stand still when the Toon does not react timely.
local scriptVersion = '0.201909300100'
return
    on =
    logging =
        marker = scriptVar,
        local toonIP =  '192.168.1.61'
        local function processResult(jsonThermostatInfo)
            local domoticz = dz -- I always use dz to abbreviate domoticz
          --Modulatie niveau
       -- main
            getToonInfo()
           local toonInfo = dz.utils.fromJSON(item.data )
           processResult(toonInfo)
EdwinK
Post by EdwinK »
Thanks. So far this seems to work for me, onwards to the next step, controlling the toon :), and adding sensors/switches
OedzesG
Post by OedzesG »
Thnx Waaren!! youre knowledge is amazing!
by EdwinK » Monday 30 September 2019 9:30
Good to hear EdwinK... My idea is to let this script run trough Domoticz API, so youre free to call the devices whatever you want..
This morning i make a test to update my selector switch when Toon is changed.
So far.. so good..
	local DomoticzIpPoort					= '192.168.1.24:8085'
	local IDX_ToonProgramma					= '48'
	local IDX_ToonProgrammaVerloop			= ''
											  handle:close()
	return
	-- ACTIEVE PROGRAMMA --
	local actieve_programma   	            = tonumber(jsonThermostatInfo.activeState)
    if          actieve_programma            == -1 then domoticz.log ('Actieve programma = Handmatig')
    elseif      actieve_programma            == 0  then domoticz.log  ('Actieve programma = Comfort')
    elseif      actieve_programma            == 1  then domoticz.log  ('Actieve programma = Thuis')
    elseif      actieve_programma            == 2  then domoticz.log  ('Actieve programma = Slapen')
    elseif      actieve_programma            == 3  then domoticz.log  ('Actieve programma = Weg')
    elseif      actieve_programma            == 4  then domoticz.log  ('Actieve programma = Vakantie')
	if          actieve_programma            == -1 then actieve_programma		= 0
    elseif      actieve_programma            == 0  then actieve_programma 		= 10
    elseif      actieve_programma            == 1  then actieve_programma 		= 20
    elseif      actieve_programma            == 2  then actieve_programma 		= 30
    elseif      actieve_programma            == 3  then actieve_programma 		= 40
    elseif      actieve_programma            == 4  then actieve_programma 		= 50
	domoticz.openURL({
	url = 'http://'..
	DomoticzIpPoort ..
	'/json.htm?type=command&param=switchlight&idx=' ..
	IDX_ToonProgramma ..
	'&switchcmd=Set%20Level&level=' ..
	tostring(actieve_programma),
	method = 'GET',
    -- PROGRAMMA VERLOOP --
  	local programma_verloop					= tonumber(jsonThermostatInfo.programState)
	if          programma_verloop	       == 0 then domoticz.log  ('Toon programma verloop = Handmatig')
	elseif      programma_verloop	       == 1 then domoticz.log  ('Toon programma verloop = Automatisch')
	elseif      programma_verloop	       == 2 then domoticz.log  ('Toon programma verloop = Automatisch met tijdelijk afwijkend programma')
   	elseif      programma_verloop	       == 8 then domoticz.log  ('Toon programma verloop = Automatisch met continu afwijkend programma')
  --Modulatie niveau
OedzesG
Post by OedzesG »
I think i almoast finisching my script: ToonToDomoticz.
What do you think about it?
	dit dzVents-script wordt gebruikt om gegevens van Rooted Toon te verzamelen
	Het gebruikt een openURL-aanroep en interpreteert de geretourneerde JSON.
	Voordat u het script activeert:
    lees het gedeelte AAN DE SLAG van de dzVents-wiki.
    wijzig xxx.xxx.xxx.xxx in dit script in het IP-adres van uw Toon
    definieer een dummy hardware in domoticz als dit nog niet is gebeurd
    definieer virtuele sensoren deze dummy hardware
    en wijzig de naam in de apparaatverklaringen
	return
		on =
		{	timer = { 'every 1 minutes' },httpResponses = { scriptVar },
			logging =
			marker 		= scriptVar,
			-- INSTELLINGEN NAAR EIGEN SITUATIE --
			local toonIP 						= '192.168.1.61'			-- Toon thermostaat IP adres
			local DomoticzIpPoort				= '192.168.1.24:8085'		-- Domoticz IP adres + poort
			local IDX_ToonThermostaatProgramma	= '48'					-- IDX nummer Toon thermostaat programma keuze-schakelaar
			local IDX_ToonAutoProgramma			= '49'					-- IDX nummer Toon auto programma keuze-schakelaar
			local IDX_ToonThermostaat			= '50' 				-- IDX nummer toon thermostaat
			local IDX_KamerTemperatuur			= '51'					-- IDX nummer kamer tamperatuur
			local IDX_ModulatieNiveau				= '52'					-- IDX nummer modulatie niveau custom sensor
			local IDX_ToonActiviteit				= '53'					-- IDX nummer Toon activiteit keuze-schakelaar
			-- HIERONDER NIETS MEER VERANDEREN !! --
            		dz.openURL								({ url = url, callback = scriptVar })
			local domoticz 							= dz
			-- TOON THERMOSTAAT PROGRAMMA --
			local thermostaat_programma   	  = tonumber(jsonThermostatInfo.activeState)
			if            thermostaat_programma       == -1 then domoticz.log  ('Programma Toon thermostaat 	= Handmatig')
			elseif      thermostaat_programma       == 0  then domoticz.log  ('Programma Toon thermostaat 	= Comfort')
			elseif      thermostaat_programma       == 1  then domoticz.log  ('Programma Toon thermostaat 	= Thuis')
			elseif      thermostaat_programma       == 2  then domoticz.log  ('Programma Toon thermostaat 	= Slapen')
			elseif      thermostaat_programma       == 3  then domoticz.log  ('Programma Toon thermostaat 	= Weg')
			elseif      thermostaat_programma       == 4  then domoticz.log  ('Programma Toon thermostaat 	= Vakantie')
			if            thermostaat_programma       == -1 then thermostaat_programma			= 0
			elseif      thermostaat_programma       == 0  then thermostaat_programma 		= 10
			elseif      thermostaat_programma       == 1  then thermostaat_programma 		= 20
			elseif      thermostaat_programma       == 2  then thermostaat_programma 		= 30
			elseif      thermostaat_programma       == 3  then thermostaat_programma 		= 40
			elseif      thermostaat_programma       == 4  then thermostaat_programma 		= 50
			domoticz.openURL({
			url = 'http://'..
			DomoticzIpPoort ..
			IDX_ToonThermostaatProgramma ..
			tostring(thermostaat_programma),
			method = 'GET',
			-- TOON AUTO PROGRAMMA --
			local auto_programma			= tonumber(jsonThermostatInfo.programState)
			if          auto_programma		== 0 then domoticz.log  ('Toon automatisch programma = Uit')
			elseif      auto_programma		== 1 then domoticz.log  ('Toon automatisch programma = Aan')
			elseif      auto_programma		== 2 then domoticz.log  ('Toon automatisch programma = Aan met tijdelijk afwijkend programma')
			elseif      auto_programma	       	== 8 then domoticz.log  ('Toon automatisch programma = Aan met continu afwijkend programma')
			if          auto_programma	       		== 0 then auto_programma 	= 0
			elseif      auto_programma	       		== 1 then auto_programma 	= 10
			elseif      auto_programma	       		== 2 then auto_programma 	= 20
			elseif      auto_programma	      		== 8 then auto_programma 	= 30
			domoticz.openURL({
			url = 'http://'..
			DomoticzIpPoort ..
			IDX_ToonAutoProgramma ..
			tostring(auto_programma),
			method = 'GET',
			-- TOON THERMOSTAAT --
			domoticz.openURL({
			url = 'http://'..
			DomoticzIpPoort ..
			'/json.htm?type=command&param=setsetpoint&idx=' ..
			IDX_ToonThermostaat ..
			'&setpoint=' ..
			method = 'GET',
			-- HUIDIGE KAMER TEMPERATUUR --
			local kamer_temperatuur					= domoticz.utils.round(tonumber(jsonThermostatInfo.currentTemp) / 100,1)
			domoticz.log('Huidige woonkamer temp. 		= ' .. tostring(kamer_temperatuur), domoticz.LOG_INFO)
			domoticz.openURL({
			url = 'http://'..
			DomoticzIpPoort ..
			'/json.htm?type=command&param=udevice&idx=' ..
			IDX_KamerTemperatuur ..
			'&nvalue=0&svalue=' ..
			method = 'GET',
		    -- MODULATIE NIVEAU --
			domoticz.openURL({
			url = 'http://'..
			DomoticzIpPoort ..
			IDX_ModulatieNiveau ..
			method = 'GET',
			-- TOON ACTIVITEIT --
			local toon_activiteit = tonumber(jsonThermostatInfo.burnerInfo)
			if          toon_activiteit       		== 0 then domoticz.log   ('Momenteel geen activiteit')
			elseif      toon_activiteit       		== 1  then domoticz.log  ('Verwarmen CV')
			elseif      toon_activiteit      		== 2  then domoticz.log  ('Verwarmen water')
			if          toon_activiteit	      		== 0 then toon_activiteit 	= 0
			elseif      toon_activiteit	       		== 1 then toon_activiteit 	= 10
			elseif      toon_activiteit	       		== 2 then toon_activiteit	= 20
			domoticz.openURL({
			url = 'http://'..
			DomoticzIpPoort ..
			IDX_ToonActiviteit ..
			tostring(toon_activiteit),
			method = 'GET',
       -- main
			getToonInfo()
OedzesG
Post by OedzesG »
I think i needed some help guys!
I made another small script to set my setpoint:
    devices = {'Toon thermostaat'}
    local ToonIp 			    = '192.168.1.61'
	local ThermostaatWaarde		= device.setPoint*100
	domoticz.log('Ingestelde temperatuur. 	= ' .. tostring(ThermostaatWaarde/100), domoticz.LOG_INFO)
	domoticz.openURL({
	url = 'http://'..
	ToonIp ..
	'/happ_thermstat?action=setSetpoint&Setpoint=' ..
	tostring(ThermostaatWaarde),
	method = 'GET',
The problem is that when my script: ToonToDomoticz is running (every minute) this script also is triggered.. so the url is send en then Toon api is thinking that the temperature is manualy changed and set the program to Manualy.
So how do i prefent that this script is triggered trough my other script?
Thnx! (hope you understand my broblem! :oops: )
OedzesG
Post by OedzesG »
This is my fully ToonToDomoticz script...
   	wijzig: INSTELLINGEN NAAR EIGEN SITUATIE in dit script, overeenkomstig met uw
    	eigen Domoticz installatie.
    	definieer een dummy hardware in domoticz als dit nog niet is gebeurd en registreer
    	hun unieke IDX nummers.
	return
		{on =
			logging =
		{	level 		= domoticz.LOG_DEBUG,
			marker 		= scriptVar,
			local IDX_ToonScene             		= '48'					-- IDX nummer Toon thermostaat scene keuze-schakelaar
			local IDX_ToonKamerTemperatuur	= '51'					-- IDX nummer kamer tamperatuur
			local IDX_ToonModulatieNiveau		= '52'					-- IDX nummer modulatie niveau custom sensor
			local domoticz 							= dz
			-- TOON SCENE --
			local toon_scene   	                   = tonumber(jsonThermostatInfo.activeState)
			if          toon_scene                    == -1 then domoticz.log  ('Programma Toon thermostaat 	= Handmatig')
			elseif      toon_scene                  == 0  then domoticz.log  ('Programma Toon thermostaat 	= Comfort')
			elseif      toon_scene                  == 1  then domoticz.log  ('Programma Toon thermostaat 	= Thuis')
			elseif      toon_scene                  == 2  then domoticz.log  ('Programma Toon thermostaat 	= Slapen')
			elseif      toon_scene                  == 3  then domoticz.log  ('Programma Toon thermostaat 	= Weg')
			elseif      toon_scene                  == 4  then domoticz.log  ('Programma Toon thermostaat 	= Vakantie')
			if          toon_scene                  == -1 then toon_scene		= 0
			elseif      toon_scene                  == 0  then toon_scene 		= 10
			elseif      toon_scene                  == 1  then toon_scene 		= 20
			elseif      toon_scene                  == 2  then toon_scene 		= 30
			elseif      toon_scene                  == 3  then toon_scene 		= 40
			elseif      toon_scene                  == 4  then toon_scene 		= 50
			domoticz.openURL({
			url = 'http://'..
			DomoticzIpPoort ..
			IDX_ToonScene ..
			tostring(toon_scene),
			method = 'GET',
			domoticz.openURL({
			url = 'http://'..
			DomoticzIpPoort ..
			method = 'GET',
			domoticz.openURL({
			url = 'http://'..
			DomoticzIpPoort ..
			'&setpoint=' ..
			method = 'GET',
			domoticz.openURL({
			url = 'http://'..
			DomoticzIpPoort ..
			IDX_ToonKamerTemperatuur ..
			method = 'GET',
			domoticz.openURL({
			url = 'http://'..
			DomoticzIpPoort ..
			IDX_ToonModulatieNiveau ..
			method = 'GET',
			domoticz.openURL({
			url = 'http://'..
			DomoticzIpPoort ..
			method = 'GET',
            -- main
			getToonInfo()
OedzesG wrote: Monday 30 September 2019 12:39 I think i almost finished my script: ToonToDomoticz.
I am not sure I quite understand why you use the domoticz.openURL call for setting the switches in domoticz.
Is there a reason why you don't' use
domoticz.devices(IDX_ToonThermostaatProgramma).setLevel(thermostaat_programma)
and similar commands in the other places where you now use domoticz openURL ?
OedzesG
Post by OedzesG »
No special reason for URL, just becouse i know how to handle.
For now i changed everything.. but the same problem.
Domoticz triggers the ToonThermostaat script when updating the setpoint and after that when te temerature is changed by selecting a scene, Toon API is thinking that the temerature is changed manualy by setpoint.. en then changing the scene to manual..
ToonToDomoticz:
return
httpResponses = { scriptVar }},
logging =
{level = domoticz.LOG_DEBUG,
marker = scriptVar,},
execute = function(dz, item, devices)
local IDX_ToonScene = 48 -- IDX nummer Toon thermostaat scene keuze-schakelaar
local IDX_ToonAutoProgramma = 49 -- IDX nummer Toon auto programma keuze-schakelaar
local IDX_ToonThermostaat = 50 -- IDX nummer toon thermostaat
local IDX_ToonKamerTemperatuur = 51 -- IDX nummer kamer tamperatuur
local IDX_ToonModulatieNiveau = 52 -- IDX nummer modulatie niveau custom sensor
local IDX_ToonActiviteit = 53 -- IDX nummer Toon activiteit keuze-schakelaar
local domoticz = dz
-- TOON SCENE --
domoticz.devices(IDX_ToonScene).switchSelector(toon_scene)
domoticz.devices(IDX_ToonAutoProgramma).switchSelector(auto_programma)
domoticz.devices(IDX_ToonThermostaat).updateSetPoint(waarde_thermostaat)
domoticz.devices(IDX_ToonKamerTemperatuur).updateTemperature(kamer_temperatuur)
domoticz.devices(IDX_ToonModulatieNiveau).updateCustomSensor(modulatie_niveau)
domoticz.devices(IDX_ToonActiviteit).switchSelector(toon_activiteit)
-- main
getToonInfo()
ToonThermostaat
domoticz.openURL({
url = 'http://'..
ToonIp ..
method = 'GET',
OedzesG
Post by OedzesG »
domoticz.devices(IDX_ToonThermostaat).updateSetPoint(waarde_thermostaat).silent()
Is not working on setpoints... :roll: is ther another way?
OedzesG wrote: Monday 30 September 2019 19:58
Try to search for toon rooted in the search window of this forum. There are already quite a number of scripts (Lua end dzVents) to interact between a rooted Toon and domoticz
EdwinK
Post by EdwinK »
OedzesG wrote: Monday 30 September 2019 12:39 I think i almoast finisching my script: ToonToDomoticz.
return
logging =
local toonIP                    = '192.168.0.4' -- Toon thermostaat IP adres
local IDX_ToonScene             = 332 -- IDX nummer Toon thermostaat scene keuze-schakelaar
local IDX_ToonAutoProgramma     = 333 -- IDX nummer Toon auto programma keuze-schakelaar
local IDX_ToonThermostaat       = 334 -- IDX nummer toon thermostaat
local IDX_ToonKamerTemperatuur  = 335 -- IDX nummer kamer tamperatuur
local IDX_ToonModulatieNiveau   = 336 -- IDX nummer modulatie niveau custom sensor
local IDX_ToonActiviteit        = 337 -- IDX nummer Toon activiteit keuze-schakelaar
local domoticz = dz
-- TOON SCENE --
-- main
getToonInfo()
Using this script now. Next to do is the make the switches giving the switches the right names and such.
