Fibaro RGBW module Configuration
rickiewickie
Post by rickiewickie »
Hi All,
I struggling to configure a RGBW module, and perhaps you guys can help me..
My goal is to measure 4 soil moisture sensors (0-10v) for my garden, but to do this i need to change parameter 14.
According to the manual and the page below i need to change parameter 14 to : 34952
https://manuals.fibaro.com/rgbw/
Now the strange part kicks in...
I doesn't allow me to save this value... Further investigation in the source code of the OpenZwave page (http://DOMOTICZIP:8080/ozwcp/cp.html) shows me a max allowable value of 32767, see printscreen below..
Can anyone help to configure the RGBW module to 4x 0-10 volt input?
Thanks in advance.
ksacca
Re: Fibaro RGBW module Configuration
Post by ksacca »
According to what is explained in https://www.domoticz.com/forum/viewtopi ... 905#p81295, it should be set to -30582.
rickiewickie
Thanks! It looks like it works now.
Would not have came up with myself..
Now i'm finally able to continue my project :)
uschuga
Domoticz version: 2023.2
Post by uschuga »
Thanks for the groundwork. I had the same problem with the configuration. To activate the 4 inputs I used the value -65534 + 34952 = -30582, which was also accepted by the device. So far OK.
Unfortunately I don't see the 4 expected 0-10V sensors in the device list, only switches.
What has to be considered?
Thank you in advance...
Used Z-Wave devices: EUR_SPIRITZ, FGBS001, FGR223, FGS223, FGBS222, ZMNHYD1 Smart Plug 16A, ZWA009 AërQ Sensor, NAS-WR01Z Power plug 12A, ZME_WALLC-S, FGD212, ST812 Flood Detector, PAN04-1 Double Relay Switch, ZMNHND1 Flush 1D relay, ZME_UZB1 USB Stick
uschuga
Post by uschuga »
Find below corresponding screen shots
awierda
Post by awierda »
Hi uschuga,
I have the same issue. Did you find a solution?
Thanks in advance.
uschuga
Post by uschuga »
Hi awierda,
Good to know, that I am still not alone with the problem of configuring the RGBW module ;).
Actually, I am still waiting for somebody who can report about successfully installation - and how!
Any news?
