blockly script, but the time option does not work ?
TheCub3
Post by TheCub3 »
i'am not really handy with Blockly (yet) and i hope maybe u can help me with a blockly script
But it dus not work ?, or better it works to good. becourse i dussent matter when i open the door i wil allways get a push message and e-mail
what am I doing wrong ?
Tnx
-A
Denny64
Domoticz version: 2023.1
Re: blockly script, but the time option does not work ?
Post by Denny64 »
First of all you don't need to use two IF statements.
IF voordeur = Open AND Time > 22:30 AND Time < 07:00
To prevent Domoticz sending repeating messages, with blockly you must use a user variable. Make one and call it "Door" using "Open" and "Closed" like string.
Now you can blockly in this way:
IF voordeur = Open AND Door = Closed AND Time > 22:30 AND Time < 07:00
DO Door = Open
Send camera snapshot...
Send notification with subject...
Else IF voordeur = Closed AND Door = Open AND Time > 22:30 AND Time < 07:00
Do Door = Closed
StanHD
Post by StanHD »
Because the day ends at midnight and then resets , your time statement should contain "Or", not "And".
Example: Time >21:00 Or Time <07:00
Python:- Broadlink RM2, Sonos
Denny64
Post by Denny64 »
Of course, I forget it...
But this does not solve the recursive sending message until the door is closed.
TheCub3
Post by TheCub3 »
he Guy's
firt tnx for the time to think this over, is this what you mean ?.
it seem to me a bit overdone ?, but oke iám een noob in Blockly
-A
StanHD
Post by StanHD »
I have never successfully nested "If" blocks. I don't think that will work. Try re-writing as per @Denny64 above using a single "If - Else If".
Have a look at some blockly examples on the forum. You will see how to structure the blocks. Although it has its limitations I have around 40 blockly scripts running successfully for years now. You will soon get the hang of it.
TheCub3
Post by TheCub3 »
StanHD wrote: Saturday 16 June 2018 13:02 I have never successfully nested "If" blocks. I don't think that will work. Try re-writing as per @Denny64 above using a single "If - Else If".
Hi "stan",
this blockly script is working,
maybe you or other got some tips or changes ?
-A
Denny64
Post by Denny64 »
This is the right blockly to avoid recursive message:
Schermata a 2018-06-16 15-21-53.jpg (107.37 KiB) Viewed 3178 times
Don't forget to create a user variable called "Door".
TheCub3
Post by TheCub3 »
i really dont understand it anymore,
i made:
so i tested it yesterday, change the first time to 17:30 open the door and yes i get a push message and e-mail .
so i change the time back to 22:30 and open the door again, yes no message so the time is working, so far so fine .....
at 22:30 i open the door YES again a message zo the time settings are really working (so I thought) ... next morning on 07:00 i open the door.
and again a push message and a email. I thought ok so thats working.... but today on 12:00 a clock my girlfriend get home opens the door.
and i get a message huh ?..... why thats not posible ...
so i really dont know it anymore, i made about 10 differents blockly setups and everytime as I thought yes thats the right one its not.
what i'am doing wrong ?.
cobra045
Domoticz version: 3.4834
Post by cobra045 »
Hi TheCub3,
your blockly is wrong.
use < instead of >
Kind regards
Cobra045
TheCub3
Post by TheCub3 »
cobra045 wrote: Tuesday 19 June 2018 22:46 Hi TheCub3,
use < instead of >
Kind regards
Cobra045
ooh my G#D, that cant be it :o ... sorry Cobra045 i wil change it and test it again...
tnx
TheCub3
Post by TheCub3 »
use < instead of >
Kind regards
Cobra045
hi all,
Just dit a test, but still the same issue Blockly is now:
and i opened the door at 19:17 and i got a push message and a e-mail, i dont know why but i cant get the time settings working.
what i'am i doing wrong, i dont know it anymore.
-A
mrf68
Post by mrf68 »
Try simplifying your blockly. The “if else/if” block without an else/if usualy doesn’t work. And the second “and” won’t work, because time cannot be “> 22:30 AND < 08:00”. Create a blockly for the first period (>22:30 and <23:59), then create a second blockly for the second period (>00:00 and <08:00).
TheCub3
Post by TheCub3 »
mrf68 wrote: Wednesday 20 June 2018 19:35 Try simplifying your blockly. The “if else/if” block without an else/if usualy doesn’t work. And the second “and” won’t work, because time cannot be “> 22:30 AND < 08:00”. Create a blockly for the first period (>22:30 and <23:59), then create a second blockly for the second period (>00:00 and <08:00).
tnx i wil try that, i just made
and this works indeed, i wil made a second one voor the night tnx i wil let you know if this works
