blockly script, but the time option does not work ?
TheCub3
i'am not really handy with Blockly (yet) and i hope maybe u can help me with a blockly script But it dus not work ?, or better it works to good. becourse i dussent matter when i open the door i wil allways get a push message and e-mail
what am I doing wrong ?
Tnx
-A
Tnx
-A
- Denny64
- Domoticz version: 2023.1
Re: blockly script, but the time option does not work ?
First of all you don't need to use two IF statements.
IF voordeur = Open AND Time > 22:30 AND Time < 07:00
To prevent Domoticz sending repeating messages, with blockly you must use a user variable. Make one and call it "Door" using "Open" and "Closed" like string.
Now you can blockly in this way:
IF voordeur = Open AND Door = Closed AND Time > 22:30 AND Time < 07:00
DO Door = Open
Send camera snapshot...
Send notification with subject...
Else IF voordeur = Closed AND Door = Open AND Time > 22:30 AND Time < 07:00
Do Door = Closed
DO Door = Open
Do Door = Closed
- StanHD
Because the day ends at midnight and then resets , your time statement should contain "Or", not "And".
Example: Time >21:00 Or Time <07:00
Python:- Broadlink RM2, Sonos
- Denny64
Of course, I forget it...
But this does not solve the recursive sending message until the door is closed.
TheCub3
he Guy's
firt tnx for the time to think this over, is this what you mean ?. it seem to me a bit overdone ?, but oke iám een noob in Blockly
-A
-A
- StanHD
I have never successfully nested "If" blocks. I don't think that will work. Try re-writing as per @Denny64 above using a single "If - Else If".
Have a look at some blockly examples on the forum. You will see how to structure the blocks. Although it has its limitations I have around 40 blockly scripts running successfully for years now. You will soon get the hang of it.
TheCub3
Hi "stan",StanHD wrote: Saturday 16 June 2018 13:02 I have never successfully nested "If" blocks. I don't think that will work. Try re-writing as per @Denny64 above using a single "If - Else If".
this blockly script is working, maybe you or other got some tips or changes ?
-A
- Denny64
This is the right blockly to avoid recursive message:
Don't forget to create a user variable called "Door".
TheCub3
i really dont understand it anymore,
i made: so i tested it yesterday, change the first time to 17:30 open the door and yes i get a push message and e-mail .
so i change the time back to 22:30 and open the door again, yes no message so the time is working, so far so fine .....
at 22:30 i open the door YES again a message zo the time settings are really working (so I thought) ... next morning on 07:00 i open the door.
and again a push message and a email. I thought ok so thats working.... but today on 12:00 a clock my girlfriend get home opens the door.
and i get a message huh ?..... why thats not posible ...
so i really dont know it anymore, i made about 10 differents blockly setups and everytime as I thought yes thats the right one its not.
what i'am doing wrong ?.
cobra045
- Domoticz version: 3.4834
Hi TheCub3,
your blockly is wrong.
use < instead of >
Kind regards
Cobra045
use < instead of >
Kind regards
Cobra045
TheCub3
ooh my G#D, that cant be itcobra045 wrote: Tuesday 19 June 2018 22:46 Hi TheCub3,
use < instead of >
Kind regards
Cobra045
tnx
TheCub3
hi all,cobra045 wrote: Tuesday 19 June 2018 22:46 Hi TheCub3,
use < instead of >
Kind regards
Cobra045
Just dit a test, but still the same issue Blockly is now: and i opened the door at 19:17 and i got a push message and a e-mail, i dont know why but i cant get the time settings working.
what i'am i doing wrong, i dont know it anymore.
-A
mrf68
Try simplifying your blockly. The “if else/if” block without an else/if usualy doesn’t work. And the second “and” won’t work, because time cannot be “> 22:30 AND < 08:00”. Create a blockly for the first period (>22:30 and <23:59), then create a second blockly for the second period (>00:00 and <08:00).
TheCub3
tnx i wil try that, i just made and this works indeed, i wil made a second one voor the night tnx i wil let you know if this worksmrf68 wrote: Wednesday 20 June 2018 19:35 Try simplifying your blockly. The “if else/if” block without an else/if usualy doesn’t work. And the second “and” won’t work, because time cannot be “> 22:30 AND < 08:00”. Create a blockly for the first period (>22:30 and <23:59), then create a second blockly for the second period (>00:00 and <08:00).
