Milight t2 wall switch cct
12345caravan
Post by 12345caravan »
I'm having problems with my milight t2 wall switch adding to domoticz.
Accept new hardware, push button on wall switch, rflink/domoticz adds new device.
But when I use the new device nothing happens.
Domoticz only see the device switching off when i use the wall switch.
What goes wrong over here?
12345caravan
Re: Milight t2 wall switch cct
Nobody else using this switch?
Rflink is sending the following command when switching: 10;MiLightv1;02b2;01;0000;ON
Is this correct?
Just adding another switch T2 CCT, and thsi one isn't working either....
Rflink picks up the signal in domoticz, add device, but no response.
I can pair the bulbs in domoticz, but i want also use the switch.
tontze
Domoticz version: Beta Ch
Post by tontze »
Do you have "learn new device" enabled in domoticz settings, and enabled milight in rflink ? You need to also pair bulp with the switch.
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
12345caravan
Yes did that, domoticz can see the new switch, but the rflink is sending a total different command as the wall switch, so this is not working.
I f I give the wall switch command through the rflink command line in domoticz, it is working.
Hope this will be supported in next rflink release.....
Stuntteam
Post by Stuntteam »
Can you send me the commands that you logged?
tontze
Post by tontze »
Little late, but i did pair switch with bulbps, and thebn learned that switch press on domoticz.
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
