I'm having problems with my milight t2 wall switch adding to domoticz.
Accept new hardware, push button on wall switch, rflink/domoticz adds new device.
But when I use the new device nothing happens.
Domoticz only see the device switching off when i use the wall switch.
What goes wrong over here?
Milight t2 wall switch cct
12345caravan
- t2-switch.jpg (120.09 KiB) Viewed 1952 times
12345caravan
Re: Milight t2 wall switch cct
Nobody else using this switch?
Rflink is sending the following command when switching: 10;MiLightv1;02b2;01;0000;ON
Is this correct?
Just adding another switch T2 CCT, and thsi one isn't working either....
Rflink picks up the signal in domoticz, add device, but no response.
I can pair the bulbs in domoticz, but i want also use the switch.
Is this correct?
tontze
- Domoticz version: Beta Ch
Do you have "learn new device" enabled in domoticz settings, and enabled milight in rflink ? You need to also pair bulp with the switch.
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
12345caravan
Yes did that, domoticz can see the new switch, but the rflink is sending a total different command as the wall switch, so this is not working.
I f I give the wall switch command through the rflink command line in domoticz, it is working.
Hope this will be supported in next rflink release.....
- Stuntteam
Can you send me the commands that you logged?
tontze
Little late, but i did pair switch with bulbps, and thebn learned that switch press on domoticz.
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
