my water meter.
remb0
my water meter.
Post by remb0 »
Watersensor
ordered from iPrototype.nl
https://iprototype.nl/products/componen ... e-tracking
Line tracking sensor - digitaal
Specs
Power: +5V
Operatie stroom: <10mA
3-wire output.
Output: TTL(Zwart voor LOW output, Wit voor HIGH output)
price: €5,95
Ritmeester
Re: my water meter.
Post by Ritmeester »
Thanks. This looks good.
In this article number: 82649264 ?
(P.S, the red wire goes to Output pin 7 instead of 5V on the PiFace in your schematic)
remb0
Re: my water meter.
Post by remb0 »
don't know why but I have this als my schema. but it works.
Ritmeester wrote:Thanks. This looks good.
bistoury
my water meter.
Post by bistoury »
Hi remb0 ! Can you pleade detail that piece of hardware that you connect to your piface (brand, référence, supplier cost...).
I have the same king of water meter but i do not want to invest into the official pulse module (itron cyble V2) because it cost more than 50€.
So any detail or idea is welcome.
[edit] ok, iprototype.nl - didn't see that. But how do you fix it to the water meter ? Is it in front of the metal wheel ? [/edit]
Ritmeester
Re: my water meter.
bistoury wrote:Hi remb0 ! Can you pleade detail that piece of hardware that you connect to your piface (brand, référence, supplier cost...).
Try this one: http://r.ebay.com/Ox4XvE I just ordered a couple.
Analog and Digital output. $1.75 = € 1,27 including shipping.
bistoury
Re: my water meter.
Post by bistoury »
I have also find this :
http://gobotics.com/index.php?route=pro ... duct_id=80
Remb0 : if i ordre your module, what else do i need (apart from a ip and a piface) ?
Does it work the same than the previous one ? Is it the same electrical schematic ?
On the module i have found (gobotics), i understand that it is in fact an IR sensor. Is it the case ?
I ma not sûre to understand everything here...
bistoury
Re: my water meter.
Post by bistoury »
Hummmm.... Now ebay is bloc king me due to country restrictions (i am inFrance)
Raspberry Piet
Re: my water meter.
Post by Raspberry Piet »
Yes these TCRT5000 sensors work very well (glued on my powermeter and also gasmeter).
But i bought some other type for my watermeter. (The one that is mentioned here =>http://www.domoticz.com/wiki/PiFace)
Cause i doubt this TCRT5000 sensor will work foolproof for long time when it is in a humid area under the floor where my watermeter is.
Ritmeester
Re: my water meter.
bistoury wrote:Hummmm.... Now ebay is bloc king me due to country restrictions (i am inFrance)
Try to find another seller. There are more sellers who sell this and ship to France.
http://www.ebay.com/sch/i.html?_sacat=0 ... =2&_sop=15
bistoury
Re: my water meter.
Post by bistoury »
Ok i understand that nothing has to be soldered. Good point. Now second one : how do you fix it to the water meter ? And 3rd one : is the electrical schematic the same the above ?
Ritmeester
Re: my water meter.
Raspberry Piet wrote: Cause i doubt this TCRT5000 sensor will work foolproof for long time when it is in a humid area under the floor where my watermeter is.
I will use Heatshrink (Krimpkous) to safe it. Only the LED’s not :-)
Raspberry Piet
Re: my water meter.
Still then... when the glass is moist the IR light will dissipate and the sensor couldn't work properly <= Did not test this so maybe just in theory.
Ritmeester
Re: my water meter.
remb0 wrote:don't know why but I have this als my schema. but it works.
Yes, It can work because on your 8 outputs are normally 3.9 Volt between the Input Block (0V-GND) and de Output Block (5V) You can’t use that Output port anymore for something else. I rather choose for the 5V on the Output Block.
remb0
Re: my water meter.
Post by remb0 »
edited my start post
BigDog
Domoticz version: V3.9269
Re: my water meter.
Post by BigDog »
Very interesting and good /easy to use and make :) going to order 2 :)
1X Raspberry4B : Domoticz Version 2023.1 [Linux 5.10.63-v7l+ armv7l]
1X Conbee II : 2.25.3 - 26720700
1X RFXtrx433 USB Firmware:183
1X Mysensors Gateway 1.5 -3
6X ESP8266: Tosmota firmware
Zigbee : 6 Operators, 13 Sensors
bizziebis
Domoticz version: 3.8805
my water meter.
Post by bizziebis »
Bought this sensor from Ebay: http://bit.ly/RawnMy
It's working but it is hard to position it to work right.
How/where did you guys mount the sensor?
I'll post a picture of my mounted sensor later tomorrow.
Edit: pictures
I've edited the database to match the real watermeter usage. So in a couple of days I can see how reliable the sensor is. To be continued...
Keptenkurk
Re: my water meter.
Post by Keptenkurk »
@bizziebis
I use a large hose clamp to fix my sensor (but my solution senses the half moon with lowcost proximity sensor: proved to be very reliable). But my fixing method could also be used to put your type of sensor at an angle. See pictures and more details in wiki http://www.domoticz.com/wiki/PiFace paragraph "Water Meter Sensor".
/paul
kobold
Re: my water meter.
Post by kobold »
bizziebis wrote:Bought this sensor from Ebay: http://bit.ly/RawnMy
I've got the same sensor but how did you connect it to the raspberry pi?
jadijkstra2000
Re: my water meter.
Post by jadijkstra2000 »
Output 5 volt will blow up input ports right?
Derik
Re: my water meter.
Post by Derik »
I did my:
https://imageshack.com/i/fvmdz4j
With the solarmeter, and then i import the data..
