Thermostat "Spirit Z-Wave Plus"
brommetje
Post by brommetje »
Hi, after searching I found a new z wave thermostat "Spirit Z-Wave Plus" https://www.eurotronic.org/en/products/ ... -plus.html
Advantage "z wave plus" and should give the current room temperature back.
Did anyone already installed this thermostat? Is it supported?
Regards, Martin
Eligos
Domoticz version: 3.8914
Re: Thermostat "Spirit Z-Wave Plus"
Post by Eligos »
I'm also interested on this device. I think it's not a problem for domoticz with a Z-Wave controller with Z-Wave Plus and OpenZwave(OZW)
Z-Wave Plus Spec: http://www.zwave-shopping.com/en/content/13-z-wave-plus
Domoticz Z-Wave integration:
https://www.domoticz.com/wiki/Zwave
brommetje
Post by brommetje »
Thanks Eligos, still waiting on a response of eurotronic what the "UK mode" really means because I have to mount the radiator 20 cm under the ceiling of a my wifes washing room and wants to know if can mount the spirit with the led display face down. (display to the floor)
skierka
Domoticz version: 3.8153
Post by skierka »
I am new to domoticz and Z-wave in general but I have decided to give it a try.
I have one StellaZ configured already and I have just purchased Sprint (eurotronic).
It seems to be recognized but apparently there is no possibility to set a set-point.
In additional when I compare specification to what I can see in domoticz it is quite messy.
Setup:
domoticz: 3.8153
controller: Aeotec Z-stick Gen5
Thermostat: Sprint z-wave plus (eurotronic)
how it looks in control panel. Set-points (when set) are going back to "0"
Screenshot-2017-10-13 OpenZWave Control Panel.png (54.75 KiB) Viewed 6279 times
micha_pr
Post by micha_pr »
can confirm... seems to be an OZW problem...
http://www.domoticz.com/forum/viewtopic.php?f=6&t=19917
Michael Pruefer
http://www.zwave-review.com (German only)
http://www.SmartHome.Work (German only)
skierka
Post by skierka »
A small update I have manually implemented changes described in...
https://github.com/OpenZWave/open-zwave/pull/1341
...re-complied open-zwave, then adjust xml files accordingly on Domoticz side and I have those thermostat supported.
Works OK with small issue that temperature reported by Thermostat seems to be inaccurate however it is shown correctly in OZW.
Anyway as you can still set a plan for Thermostat (what temperature should be set on which time) and it is handled correctly via device (only display in Domoticz seems to be wrong) I am using it.
I have no experience in GIT stuff so I have no idea how to push changes to be merged into open-zwave version.
berkens
Domoticz version: 3.8891
Post by berkens »
Here a link to the factfile with XML files for manufactur and thermostat:
http://domoticz.com/forum/viewtopic.php?f=50&t=21417
Grtn Ben
Windows 10 laptop, Synology DS214 + DSM6.1, Zwave.me USB, Neo CoolCam powerplugs & dual wall switches, Heiman gasdetector, Eurotronic Spirit heatvalve, Samsung SmartThings hub v2 UK
berkens
Post by berkens »
Hi Brommetje,
Here you can see a picture of the display "up-side-down".
http://domoticz.com/forum/viewtopic.php ... 76#p167176
Eurotronic Spirit up-side-down display
mattsjo
Post by mattsjo »
I now have tree of these thermostats. I took the latest device xml from the OZW github pull request and it almost works. I'm on the latest beta (3.8922).
The problem is that the temperature and valve position are not updated automatically even if I have set it up like that. I get values if I update manually in the OZW control panel or if I enable polling.
I also don't know what the "Furnace" set point is...
Any ideas?
Device file:
https://github.com/tobiasgraf/open-zwav ... piritz.xml
Spirit devices.png (201.13 KiB) Viewed 4910 times
/Mattias
brommetje
Post by brommetje »
@mattsjo I have the same problemen also time-outs or sometimes a dead node. I think we have to wait for an update of openzwave.
Or has someone a idea how to recompile openzwave?
ProjektC
Domoticz version: 4.10717
Post by ProjektC »
I bought a USB Gen5 Zwave Stick and German Spirit Zwave Plus devices.
The purchase was a mistaken purchase?
mattsjo
Post by mattsjo »
ProjektC wrote:I bought a USB Gen5 Zwave Stick and German Spirit Zwave Plus devices.
That's the combination I have. You need to patch the manufacturer_specific.xml and add the eur_spiritz.xml before you include the thermostat to Domoticz. Everything works fine except for the automatic temperature and valve position reports.
/Mattias
ProjektC
Post by ProjektC »
<Product type="0003" id="0001" name="EUR_SPIRITZ Wall Radiator Thermostat Valve Control" config="eurotronic/eur_spiritz.xml"/>
<Product type="0003" id="0003" name="EUR_SPIRITZ Wall Radiator Thermostat Valve Control" config="eurotronic/eur_spiritz.xml"/>
Is it enough to delete the thermostats on Device?
Do the thermostats also have to be deleted for hardware under ZWAVE?
But I miss Light/Switch for 401
Temperature 401 is present.
201 and 301 temperature and light/switch available
ProjektC
Post by ProjektC »
Pics
mattsjo
Post by mattsjo »
I don't think the devices must be deleted. It should be enough to stop Domoticz and remove (or rename) the ozw cache file (ozwcfg_0xxxxxx.xml). Then restart Domoticz again and the system should pick up the proper name of the thermostats.
/Mattias
ProjektC
Post by ProjektC »
I'm sending the Spirit back to Amazon.
I have now ordered the Popp thermostats.
Gabri
Post by Gabri »
I tried adding the two lines to the manufacturer_specific.xml and adding the eur_spirit.xml file to /Config/eurotronic. It did not help; I still have the Dry Air/Cooling devices. BTW what is the reason that Open Z-wave's current version is still not merged into Domoticz, even the beta?
Second question: does anyone else here have range issues with the Spirit? Whenever it is not in range of the main controller the node shows up as dead and only comes alive briefly when you press a button on the device itself. I had the same problems with OpenHAB. It seems the device does not route through other nodes, at least when listening to commands (maybe it has to do with the new FLiRS mode?)
Actually, with Domoticz I think the problem is much less severe. But it's difficult to test without a working thermostat. I can only change the heating mode remotely, which mostly works. But for example "Request current stored values from device" does not work well, or at all.
brommetje
Post by brommetje »
Hi still problems with my Spirit, using Domoticz v3.8989 and OpenZWave version 1.4-2888-g54682370-dirty
If have seen that if you try to compile (but this is to difficult for me) then you get "Version 1.4-2968-g30d9f38-dirty" this include path #1387 for the Spirit.
When will be this available in a new beta version of Domoticz or do I have to compile everything myself how does this work, I am not a compiling guru?
