Cheap 433MHz door sensor (with open and close)
JelteV
Post by JelteV »
So I don't know if this is special or not but I found these cheap Door sensor that look great, are really cheap (<€ 5,-) and send an open and close signal.
https://www.aliexpress.com/item/433MHz- ... 91010.html
I thought I would share how to set them up in Domoticz.
So first this sensor has to be picked up by Domoticz. If you have an RFXCOM you need to enable the Lightning 4 mode.
As soon as this is enabled your sensor will show up in your list of (unused) devices as 2 devices with the same ID.
One device will be triggered when the door is opened, one will be triggered when the door is closed.
You need to find out which device is triggered when. You can find out by triggering each event. First move the contact away from the base, this will simulate opening the door. The "last seen" time of that device will change.
Rename that device. Let's call it "Front door open (event)".
Now move the contact back to the base. If you did it correct "last seen" time of the other device will change.
Rename that device. Let's call that "Front door close (event)".
And add them both as switches in Domoticz.
Both devices will be always on, you can't switch them off. To know the state of the door we need to add a new dummy switch.
Add a new dummy door contact and call it "Front door (Virtual)".
To know the state of the door we need to add 2 small scripts.
One when the door is opened and one when closed.
Here they are:
Door open :
		devices = {
			'Front door open (event)',
	-- in case of a timer event or security event, device == nil
		if (device.changed) then
			domoticz.devices('Front door (Virtual)').open()
Door close :
		devices = {
			'Front door close (event)'
			domoticz.devices('Front door (Virtual)').close()
There you have it.
A working 433MHz door contact in Domoticz with an open and close for less then € 5,-!
Now you always know the state of your door or window.
aleph0
Domoticz version: 11838
Re: Cheap 433MHz door sensor (with open and close)
Post by aleph0 »
Thanks you very much for this info :) I've been looking for something like that for a long time :)
Rolo
Domoticz version: 3.8153
Post by Rolo »
Can you tell wich type of battery is used in this switch?
sincze
Domoticz version: 2024.4
Post by sincze »
Nice find. Even open/close. Well design looks also okay. Next stop will be their motion sensors right??
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
SweetPants
Post by SweetPants »
Rolo wrote: Sunday 10 September 2017 9:10 Can you tell wich type of battery is used in this switch?
If you follow the link in the first post it says:
Power Supply:DC 12V(12V 23A battery)
Jem101
Post by Jem101 »
SweetPants wrote: Sunday 10 September 2017 11:32
Yes it does say that but it must be a misprint somewhere - a battery that can supply 23A at 12 V is a car battery! I suspect, looking at the other similar products, that it'll be something like a CR2032 button-type cell.
I firmly believe in having an open mind - although not so open that your brain falls out!
- sometimes attributed to Carl Sagan, but the original quote is much older than that
SweetPants
23 A is the battery type http://www.toolstation.nl/shop/p92000?c ... gIvJ_D_BwE
very common type is chinese sensors. They are a little expensive in use
Jem101
Post by Jem101 »
SweetPants wrote: Sunday 10 September 2017 13:44 23 A is the battery type http://www.toolstation.nl/shop/p92000?c ... gIvJ_D_BwE
Ah I didn't know that - I stand corrected!
DzJan
Domoticz version: 2026.1
Post by DzJan »
Confirmed, the mentioned solution here is the best one found sofar.
A method using master/slave does do the open/close toggle but it is not logging the state in the switch' log.
Tips:
  • When successful implemented, set the devices "Front door open (event)" and "Front door close (event)" as hidden via Setup -> More options -> Plans -> Roomplan. Select the line $Hidden Devices and Add the two devices.
Ubuntu 24.04.4 LTS
Mega 2560 PRO, Mini RFLink R47, TinyTUYA (Cloud), P1
BartSr
Domoticz version: V2024.7
Post by BartSr »
Maybe this might be helpfull.
I found this instruction which clearly explains how to.
https://www.youtube.com/watch?v=Oq-hN-RJ2sA
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Milifax
Post by Milifax »
BartSr wrote: Thursday 12 October 2017 7:48 Maybe this might be helpfull.
My advice: don't use the master/slave option. It will save you a lot of trouble if you skip that part. Just add then as on or off devices.
See my struggle in a previous post:
viewtopic.php?f=59&t=18654
BartSr
Post by BartSr »
@Milifax: Thanks for pointing me to the unwanted side effect.
I just started with Domoticz and have (not yet) experience with the scripts which drove you crazy using this solution.
-Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
BartSr
Post by BartSr »
In addition: Is it normal that it takes (variable) 2 - 5 seconds before a change of the status is reflected in the GUI?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
MarnixO
Domoticz version: V4.10199
Post by MarnixO »
Hi all
i have received the door sensors yesterday
With 1.5 volt battery included
they are recognized like a X10 security sensor by rfxcom
it has 3 states Alarm, Motion and Normal
the state normal can be trigered by the dashboard but not by actuating the sensor itself
so i wrote a dzvents script to change the state of the dummy doorsensor
json output:
ActTime: 1509176885,
ServerTime: "2017-10-28 09:48:05",
Sunrise: "08:31",
Sunset: "18:25",
result: [
AddjMulti: 1,
AddjMulti2: 1,
AddjValue: 0,
AddjValue2: 0,
BatteryLevel: 0,
CustomImage: 0,
Data: "Motion",
Description: "",
Favorite: 0,
HardwareID: 3,
HardwareName: "RFX",
HardwareType: "RFXCOM - RFXtrx433 USB 433.92MHz Transceiver",
HardwareTypeVal: 1,
HaveDimmer: false,
HaveGroupCmd: false,
HaveTimeout: false,
LastUpdate: "2017-10-28 09:29:07",
MaxDimLevel: 0,
Notifications: "false",
PlanID: "1",
PlanIDs: [
1
Protected: false,
ShowNotifications: true,
SignalLevel: 7,
Status: "Motion",
StrParam1: "",
StrParam2: "",
SubType: "X10 security",
SwitchType: "Security",
SwitchTypeVal: 0,
Timers: "false",
Type: "Security",
TypeImg: "security",
Unit: 0,
Used: 1,
XOffset: "0",
YOffset: "0",
idx: "103"
status: "OK",
title: "Devices"
Is there also an other way ?
miremi
Post by miremi »
If i follow link from the first post item is not available anymore.
Ubuntu 16.04.3, Core i5 8GB RAM 120GB SSD, RFlink, ESPeasy, Z-Stick Gen5, 8 FIbaro, 17 Neo Coolcam
BartSr
Post by BartSr »
Similar (or maybe slightly differrent) type are availbale on other chinese web-shops.
e.g. https://www.banggood.com/GS-WDS07-Wirel ... mds=search
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
miremi
Post by miremi »
BartSr wrote: Saturday 28 October 2017 12:24 Similar (or maybe slightly differrent) type are availbale on other chinese web-shops.
Thank you
Jordy
Post by Jordy »
These sensor are giving my quite a headache. Trying to figure them out via lua scripts. But as said, the status of the sensor stays ON. I'm not quite sure why it's like this.
I've followed the video linked above and once added, the dashboard shows the status correctly (Open or Closed, configured as Door Contact). But if you check the logs, it's always ON. I guess internally it's keeping the correct value. I just wonder why I can't get that internal value. It seems a bit vague to use a virtual sensor just to track the open & close status of the sensor.
The ones I ordered are: https://aliexpress.com/item/5pcs-lot-43 ... 22065.html
I guess I'll also implement a virtual sensor just to track the state.
JelteV
Post by JelteV »
You have to create a virtual doorsensor. For some reason they are always on..
Just follow the steps in the fp.
bassie127
Post by bassie127 »
JelteV wrote: Sunday 03 September 2017 20:12 Hi,
Here they are:
Door open :
		devices = {
Door close :
		devices = {
There you have it.
Sorry, but can you tell me where and how to add these scripts?
I tried to place them in the /opt/domoticz/script/lua directory, but then I got the error 'No commandArray returned'.
