Timers not always working. Topic is solved
SVLmarc
Post by SVLmarc »
Hi there,
I'm new here. Just started Domoticz on Pi3 with RFXtrx433E. Yesterday I started a simpel test. Lamps on at 20 min before sunset and turn off at the fixed time 23:30.
Lamp go on on time but won't go off. After experimenting with the fixed times it looks like it's not working most of the times.
Anyone else with this problem?
Manuall on/off works all the time.
Hope to hear from you.
freijn
Domoticz version: Stable
Re: Timers not always working.
Post by freijn »
Have a look in the logfile, do you see the "off" command there?
SVLmarc
Post by SVLmarc »
In the log file it sometimes says off while it schould be on at that time.
SVLmarc
Post by SVLmarc »
Seems that the problem only occurs with the 'on time' function.
SVLmarc
Post by SVLmarc »
That could be an issue, but if I turn them on and off manually with Domoticz they always turn on and off. They always respond at the first klick. Also with the original KAKU remote.
Amsterdam020
Domoticz version: 3.5629
Post by Amsterdam020 »
After a restart of my pi the timer's wont work any more is my experience.
Did you also restart?
Rp3, youlesss, rfxcom, philips hue, dsb1820
assenzuid
Post by assenzuid »
My timers are also not working anymore. (Running latest beta)
I have a few configured and all to switch on after sunset (they all failed).
All running with Z-Wave devices.
assenzuid
Post by assenzuid »
After the last update my timers are working again
brydling
Post by brydling »
I am running the latest beta (3.8799) on Windows with two Z-Wave light switches and I have the same problem. On Time does not work. Haven't tried the sunrise and sunset timers.
jvdz
Domoticz version: 4.107
Post by jvdz »
brydling wrote: Sunday 07 January 2018 19:49 I am running the latest beta (3.8799) on Windows with two Z-Wave light switches and I have the same problem. On Time does not work. Haven't tried the sunrise and sunset timers.
Forum search is your friend as this is extensively discuss and fix is awaiting to be merged and new Beta to be build:
http://www.domoticz.com/forum/viewtopic.php?f=6&t=21013
Jos
brydling
Post by brydling »
jvdz wrote: Sunday 07 January 2018 20:26 Forum search is your friend as this is extensively discuss and fix is awaiting to be merged and new Beta to be build:
Jos
Thank you! I searched but not good enough it seems :)
