Timers not always working. Topic is solved
Hi there,
I'm new here. Just started Domoticz on Pi3 with RFXtrx433E. Yesterday I started a simpel test. Lamps on at 20 min before sunset and turn off at the fixed time 23:30.
Lamp go on on time but won't go off. After experimenting with the fixed times it looks like it's not working most of the times.
Anyone else with this problem?
Manuall on/off works all the time.
Hope to hear from you.
freijn
- Domoticz version: Stable
Re: Timers not always working.
Have a look in the logfile, do you see the "off" command there?
In the log file it sometimes says off while it schould be on at that time.
Seems that the problem only occurs with the 'on time' function.
That could be an issue, but if I turn them on and off manually with Domoticz they always turn on and off. They always respond at the first klick. Also with the original KAKU remote.
Amsterdam020
- Domoticz version: 3.5629
After a restart of my pi the timer's wont work any more is my experience.
Did you also restart?
Rp3, youlesss, rfxcom, philips hue, dsb1820
assenzuid
My timers are also not working anymore. (Running latest beta)
I have a few configured and all to switch on after sunset (they all failed).
All running with Z-Wave devices.
assenzuid
After the last update my timers are working again
brydling
I am running the latest beta (3.8799) on Windows with two Z-Wave light switches and I have the same problem. On Time does not work. Haven't tried the sunrise and sunset timers.
- jvdz
- Domoticz version: 4.107
Forum search is your friend as this is extensively discuss and fix is awaiting to be merged and new Beta to be build:brydling wrote: Sunday 07 January 2018 19:49 I am running the latest beta (3.8799) on Windows with two Z-Wave light switches and I have the same problem. On Time does not work. Haven't tried the sunrise and sunset timers.
http://www.domoticz.com/forum/viewtopic.php?f=6&t=21013
Jos
brydling
Thank you! I searched but not good enough it seemsjvdz wrote: Sunday 07 January 2018 20:26 Forum search is your friend as this is extensively discuss and fix is awaiting to be merged and new Beta to be build:
Jos
Users browsing this forum: willemd and 1 guest
