Wireless RF Transceiver (Transmitter & Receiver)
Find this on AliExpress
https://www.aliexpress.com/item/SV613-N ... 2151c9fbc0
Will Domoticz see it Im user Ubuntu
Re: Wireless RF Transceiver (Transmitter & Receiver)
Works with Domoticz?
- Domoticz version: latest-1
In my opinion, most likely not. This is nothing more than a wireless serial extender. Effectively being a long copper wire pair.
Can be very useful but not as a standalone solution to connect to Domoticz.
- Stuntteam
You can use RFlink with a ser2net solution to have a wireless RF Gateway..
- Target OS: -
This transceiver is not supported by Domoticz.MYLE wrote:Find this on AliExpress
Note that 100mW (+20dBm) is not allowed to use in Europe at 433MHz. The maximum is 10mW ((+10dBm).
RF transceivers also supported by Domoticz are:
PiFace viewforum.php?f=27
And the USB or LAN RFXCOM (ser2net) RFXtrx433 and RFXtrx433E viewforum.php?f=44.
For the ser2net configuration see: viewtopic.php?f=28&t=192&p=65087&hilit=ser2net#p65087
RFX-433, RFX-433EMC, RFX-868
Great contribution!b_weijenberg wrote:This transceiver is not supported by Domoticz.MYLE wrote:Find this on AliExpress
Thanks guys look like I have more reading to do by the way I'm from New Zealand
Thanks Been reading up on the RFLink i'm leaning down that roadStuntteam wrote:You can use RFlink with a ser2net solution to have a wireless RF Gateway..
starting to read up on the ser2net also
Just one Question I have some X10 motion 433MHz. I guesting the RFLink will pick them up
http://www.nemcon.nl/blog2/devlistMYLE wrote:Thanks Been reading up on the RFLink i'm leaning down that roadStuntteam wrote:You can use RFlink with a ser2net solution to have a wireless RF Gateway..
If it is not on the supported devices list then it a) might work (using of the existing protocols) or b) could be added in some of the later releases. But there's no guarantee it works unless you find it on the supported devices list...
- Stuntteam
X10 works fine.. If you find a device that has issues we will fix it.
