Wireless RF Transceiver (Transmitter & Receiver)
MYLE
Post by MYLE »
Find this on AliExpress
https://www.aliexpress.com/item/SV613-N ... 2151c9fbc0
Will Domoticz see it Im user Ubuntu
i000
Re: Wireless RF Transceiver (Transmitter & Receiver)
Post by i000 »
Works with Domoticz?
gerardvs
Domoticz version: latest-1
Post by gerardvs »
In my opinion, most likely not. This is nothing more than a wireless serial extender. Effectively being a long copper wire pair.
Can be very useful but not as a standalone solution to connect to Domoticz.
Stuntteam
Post by Stuntteam »
You can use RFlink with a ser2net solution to have a wireless RF Gateway..
b_weijenberg
Post by b_weijenberg »
MYLE wrote:Find this on AliExpress
This transceiver is not supported by Domoticz.
Note that 100mW (+20dBm) is not allowed to use in Europe at 433MHz. The maximum is 10mW ((+10dBm).
RF transceivers also supported by Domoticz are:
PiFace viewforum.php?f=27
And the USB or LAN RFXCOM (ser2net) RFXtrx433 and RFXtrx433E viewforum.php?f=44.
For the ser2net configuration see: viewtopic.php?f=28&t=192&p=65087&hilit=ser2net#p65087
RFX-433, RFX-433EMC, RFX-868
i000
Post by i000 »
Great contribution! Image
MYLE
Post by MYLE »
Thanks guys look like I have more reading to do by the way I'm from New Zealand
MYLE
Post by MYLE »
Stuntteam wrote:You can use RFlink with a ser2net solution to have a wireless RF Gateway..
Thanks Been reading up on the RFLink i'm leaning down that road
starting to read up on the ser2net also
Just one Question I have some X10 motion 433MHz. I guesting the RFLink will pick them up
Nautilus
Post by Nautilus »
http://www.nemcon.nl/blog2/devlist
If it is not on the supported devices list then it a) might work (using of the existing protocols) or b) could be added in some of the later releases. But there's no guarantee it works unless you find it on the supported devices list...:)
Stuntteam
Post by Stuntteam »
X10 works fine.. If you find a device that has issues we will fix it.
