LCD display domoticz
BigDog
Domoticz version: V3.9269
Post by BigDog »
hi
i was wondering if someone have a Touch display on the raspberry pi to control domoticz on the wall somewhere?
i would realy love it but dont know yet what LCD or TFT screen to buy and if it is possible...
Greetz Bob
1X Raspberry4B : Domoticz Version 2023.1 [Linux 5.10.63-v7l+ armv7l]
1X Conbee II : 2.25.3 - 26720700
1X RFXtrx433 USB Firmware:183
1X Mysensors Gateway 1.5 -3
6X ESP8266: Tosmota firmware
Zigbee : 6 Operators, 13 Sensors
mbliek
Re: LCD display domoticz
Post by mbliek »
You can use an iPad connected to Domoticz via wifi and stick it to the wall.
I think it's faster then using a touch screen on a raspberry
safi78
Domoticz version: LastBeta
Post by safi78 »
I agree with mbliek. I returned a cheap tablet yesterday (7" Yarvik) because it was very unresponsive / etc.
I looked into the touchscreens, found a few suppliers (try Google ;) ) but either not responding to my inquiries nor they have something in stock.
I'd go for a bit more expensive tablet if I were you. I'm gonna mount my iPad on the wall ;)
homebridge, rfxcom, zwave, nest, applamp, hue, debian, apple, mysensors, netatmo, fibaro, synology, foscam, otherz
BigDog
Post by BigDog »
i was thinking of a little cheaper example :roll: :roll:
becose i like the security screen of domoticz and i want somewhere that i can see if all the doors are closed and all the lights are out before i go out the door :D
BigDog
Post by BigDog »
safi78 i have the same as you but i think a ipad on the wall looks good but a little expencive :)
BigDog
Post by BigDog »
damn i was checking a cheap tablet but for 39,99 euro you have a nice tablet that can display domoticz :shock: :shock:
thats cheaper than a LCD exp for the raspberry....
look @ the pricewatch :shock:
http://tweakers.net/categorie/822/table ... DFEouTlWoB
safi78
Post by safi78 »
Again, I tried a slightly more expensive Android tablet with capacitive screen.Trust me, it sucks. (low brightness, slow, buggy (crashes) and touchy)
Looks good on pics / on the box / probably on the wall too when it's switched off but that's about it.
And I don't agree. You can buy wall mounts for iPad, on the wall is just optional, not permanent.
99% of the time that thing is just lying around doing nothing, now it has a use.
If I need to take it with me, I take it with me, otherwise it's on the wall.
mbliek
Post by mbliek »
You can get the first iPad for around 120 euro. I'm going to control my music as well with my iPad.
BigDog
Post by BigDog »
thats true if you need it you pick it up from the wall and if you dont need it hang it back on the wall...
thanks for thr advice.
safi78
Post by safi78 »
Yeah I use something from the Apple Store (http://store.apple.com/nl/product/H6414 ... find=vogel)
I'll post a pic tommorow because my new second hand ipad 3 will arrive tommorow ;)
albal
Post by albal »
I have this on order for an arduino - it will work with the PI. You'll have to write your own driver probably:
http://www.ebay.co.uk/itm/151210041413? ... 1497.l2649
https://www.google.co.uk/search?q=raspberry+pi+spfd5408
I will be driving it wireless with logic on a VM but you get the idea.
Derik
Post by Derik »
Try the asus pad 7inch...
Ron
Domoticz version: 2.2284
Post by Ron »
I have a Blackberry Playbook which works fine a Domoticz controller.
The only problem with it is that the icons (or however they are called) move around the sceen to easy.
Hereby sometimes the positioning of the icons are messed up.
(think I need to setup another user for this with less user rights)
mbliek
Post by mbliek »
I have my iPad mounted.
BristolBaz
Post by BristolBaz »
How are you guys powering your wall mounted tablets? I am still scratching my head about how to do this!
mbliek
Post by mbliek »
Well, mine is in a kitchen cabinet with a wall plug behind it.
Plugged the charger into a wireless switch and let it charge every Sunday for 2 hours.
fisics
Post by fisics »
I've been doing some work in a house recently that has an iPad mounted in the wall.
They use an iPort.
It looks very professional.
It uses a special ribbon charging cable that gets powered remotely I think by Cat5 cable.
http://www.iportmusic.com/products/CM
Slorf
Post by Slorf »
I bought a 7" touchscreen on Ebay, it connects to a Raspberry using HDMI and USB ( for the touchpart )
On the Raspberry I installed IceWeasel ( Firefox ), I made it so IceWeasel starts automaticly and opens the Domoticz website.
This solution is more expensive than a cheap tablet ( you need the screen and a raspberry )
Alex
A lot of stuff :[-)
Orange PI
Evohome with HGI-80
SmartMeter USB Cable
Solar panels
RFLINK 433 MHz
AeonLabs usb z-wave plus
My Sensors ( Lan Gateway )
Wemos sensors
Arduino sensors
BristolBaz
fisics wrote:I've been doing some work in a house recently that has an iPad mounted in the wall.
They use an iPort.
These are seriously pricey! But I guess they look good. Cheers, but I think I will stick with my PadTab idea and bury a usb cable in the wall!!
SEALen
Post by SEALen »
I have a adafruit 2x16 char LCDplate mounted in a box on the wall. It has 5 input buttons on it. I haven't written the code to use it just yet but it will display temps and other statuses. It's RGB so I will display certain statuses using color. The buttons will be used to arm/disarm and to change status screens. At least that is the plan. We'll see how my phyton coding goes.
