LCD display domoticz
BigDog
- Domoticz version: V3.9269
hi
i was wondering if someone have a Touch display on the raspberry pi to control domoticz on the wall somewhere?
i would realy love it but dont know yet what LCD or TFT screen to buy and if it is possible...
Greetz Bob
Greetz Bob
1X Raspberry4B : Domoticz Version 2023.1 [Linux 5.10.63-v7l+ armv7l]
1X Conbee II : 2.25.3 - 26720700
1X RFXtrx433 USB Firmware:183
1X Mysensors Gateway 1.5 -3
6X ESP8266: Tosmota firmware
Zigbee : 6 Operators, 13 Sensors
- mbliek
Re: LCD display domoticz
You can use an iPad connected to Domoticz via wifi and stick it to the wall.
I think it's faster then using a touch screen on a raspberry
Op zoek naar een Domoticz Start Set?
safi78
- Domoticz version: LastBeta
I agree with mbliek. I returned a cheap tablet yesterday (7" Yarvik) because it was very unresponsive / etc.
I looked into the touchscreens, found a few suppliers (try Google
) but either not responding to my inquiries nor they have something in stock.
I'd go for a bit more expensive tablet if I were you. I'm gonna mount my iPad on the wall
homebridge, rfxcom, zwave, nest, applamp, hue, debian, apple, mysensors, netatmo, fibaro, synology, foscam, otherz
BigDog
i was thinking of a little cheaper example
becose i like the security screen of domoticz and i want somewhere that i can see if all the doors are closed and all the lights are out before i go out the door
BigDog
safi78 i have the same as you but i think a ipad on the wall looks good but a little expencive
BigDog
damn i was checking a cheap tablet but for 39,99 euro you have a nice tablet that can display domoticz
thats cheaper than a LCD exp for the raspberry....
look @ the pricewatch
http://tweakers.net/categorie/822/table ... DFEouTlWoB
safi78
Again, I tried a slightly more expensive Android tablet with capacitive screen.Trust me, it sucks. (low brightness, slow, buggy (crashes) and touchy)
Looks good on pics / on the box / probably on the wall too when it's switched off but that's about it.
And I don't agree. You can buy wall mounts for iPad, on the wall is just optional, not permanent.
99% of the time that thing is just lying around doing nothing, now it has a use.
If I need to take it with me, I take it with me, otherwise it's on the wall.
- mbliek
You can get the first iPad for around 120 euro. I'm going to control my music as well with my iPad.
BigDog
thats true if you need it you pick it up from the wall and if you dont need it hang it back on the wall...
thanks for thr advice.
safi78
Yeah I use something from the Apple Store (http://store.apple.com/nl/product/H6414 ... find=vogel)
I'll post a pic tommorow because my new second hand ipad 3 will arrive tommorow
I have this on order for an arduino - it will work with the PI. You'll have to write your own driver probably:
http://www.ebay.co.uk/itm/151210041413? ... 1497.l2649
https://www.google.co.uk/search?q=raspberry+pi+spfd5408
I will be driving it wireless with logic on a VM but you get the idea.
Derik
- Domoticz version: BETA
Try the asus pad 7inch...
Ron
- Domoticz version: 2.2284
I have a Blackberry Playbook which works fine a Domoticz controller.
The only problem with it is that the icons (or however they are called) move around the sceen to easy.
Hereby sometimes the positioning of the icons are messed up.
(think I need to setup another user for this with less user rights)
- mbliek
BristolBaz
How are you guys powering your wall mounted tablets? I am still scratching my head about how to do this!
- mbliek
Well, mine is in a kitchen cabinet with a wall plug behind it.
Plugged the charger into a wireless switch and let it charge every Sunday for 2 hours.
I've been doing some work in a house recently that has an iPad mounted in the wall.
They use an iPort.
It looks very professional.
It uses a special ribbon charging cable that gets powered remotely I think by Cat5 cable.
http://www.iportmusic.com/products/CM
They use an iPort.
Slorf
I bought a 7" touchscreen on Ebay, it connects to a Raspberry using HDMI and USB ( for the touchpart )
On the Raspberry I installed IceWeasel ( Firefox ), I made it so IceWeasel starts automaticly and opens the Domoticz website.
This solution is more expensive than a cheap tablet ( you need the screen and a raspberry )
Alex
Alex
A lot of stuff :[-)
Orange PI
Evohome with HGI-80
SmartMeter USB Cable
Solar panels
RFLINK 433 MHz
AeonLabs usb z-wave plus
My Sensors ( Lan Gateway )
Wemos sensors
Arduino sensors
Orange PI
Evohome with HGI-80
Solar panels
RFLINK 433 MHz
Wemos sensors
Arduino sensors
BristolBaz
These are seriously pricey! But I guess they look good. Cheers, but I think I will stick with my PadTab idea and bury a usb cable in the wall!!fisics wrote:I've been doing some work in a house recently that has an iPad mounted in the wall.
They use an iPort.
SEALen
I have a adafruit 2x16 char LCDplate mounted in a box on the wall. It has 5 input buttons on it. I haven't written the code to use it just yet but it will display temps and other statuses. It's RGB so I will display certain statuses using color. The buttons will be used to arm/disarm and to change status screens. At least that is the plan. We'll see how my phyton coding goes.
