I've followed the wiki and the install.txt and the install.md. I'm missing something.
I can't get OpenZwave to show up in the hardware drop down list.
I have /root/domoticz, and /root/domoticz/open-zwave. I've done the makes in both folders, and started the program and nothing shows up.
Where does the zwave files need to be in order for it to be recognized?
Help with ZWave Topic is solved
- Domoticz version: 2022.2
Re: Help with ZWave
Isn't openzwave compiled in by default? Or do you build you Domoticz completely from source?
Re: Help with ZWave
pluto.local:~ Trixwood$ls
domoticz open-zwave-read-only
open-zwave
Re: Help with ZWave
I compiled from source.
I also tried to have it in /root, but that didn't work either.
Re: Help with ZWave
I know it's not linux, but almost the same:
https://www.domoticz.com/wiki/Mac_OS_X# ... rom_Source
and I do not see it in the linux guide but check out, after you compile in the domoticz folder run:
it will make a clean install in
including all openzwave config files. (if openzwave is in the right location, same folder as domoticz, not "inside" the domoticz folder)
sudo make install
/opt/domoticz
Re: Help with ZWave
Ok let me try it
Re: Help with ZWave
Also check out your cmake output to make sure openzwave is used. There should be a line there:
also note that i had problems with cmake cache files, still do not know which folders/files to clean:
viewtopic.php?f=6&t=11766&p=90115&hilit ... ing#p90088
so use a fresh source from git to make sure cmake does not use invalid old configuration.
-- Found LIBUSB: /usr/local/lib/libusb.dylib
-- LIBUSB found at: /usr/local/lib/libusb.dylib
-- /Users/Tristan/Smarthome/compile/open-zwave-read-only/libopenzwave.a <<---- THIS ONE
-- ==== WiringPi include file (wiringPi.h) not found. GPIO support disabled.
-- ==== (Please follow http://wiringpi.com/download-and-install/ if you want to use GPIO.)
-- Not found telldus-core (telldus-core.h), not adding tellstick support
Re: Help with ZWave
I ended up doing this for it to work. Clone the open-zwave git to /root, then follow the make and symlink instructions.
root@ubuntu:~# ls
domoticz open-zwave open-zwave-read-only
Then, cd to domoticz and issue a custom cmake command
root@ubuntu:~/domoticz# cmake -USE_STATIC_OPENZWAVE -DCMAKE_BUILD_TYPE=Release CMakeLists.txt
then make
and now i have open-zwave USB available to me
3rd time's a charm
root@ubuntu:~# ls
then make
3rd time's a charm
