Help with ZWave Topic is solved
obrienlabs
Help with ZWave
Post by obrienlabs »
I've followed the wiki and the install.txt and the install.md. I'm missing something.
I can't get OpenZwave to show up in the hardware drop down list.
I have /root/domoticz, and /root/domoticz/open-zwave. I've done the makes in both folders, and started the program and nothing shows up.
Where does the zwave files need to be in order for it to be recognized?
jannl
Domoticz version: 2025.5.x
Re: Help with ZWave
Post by jannl »
Isn't openzwave compiled in by default? Or do you build you Domoticz completely from source?
trixwood
Re: Help with ZWave
Post by trixwood »
pluto.local:~ Trixwood$ls
domoticz		open-zwave-read-only
open-zwave
not inside the domoticz folder but one lower. That is if you compile (you use linux i think? so you probably compile).
obrienlabs
Re: Help with ZWave
I compiled from source.
I also tried to have it in /root, but that didn't work either.
trixwood
Re: Help with ZWave
Post by trixwood »
I know it's not linux, but almost the same:
https://www.domoticz.com/wiki/Mac_OS_X# ... rom_Source
and I do not see it in the linux guide but check out, after you compile in the domoticz folder run:
sudo make install
it will make a clean install in
/opt/domoticz
including all openzwave config files. (if openzwave is in the right location, same folder as domoticz, not "inside" the domoticz folder)
obrienlabs
Re: Help with ZWave
Ok let me try it
trixwood
Re: Help with ZWave
Post by trixwood »
Also check out your cmake output to make sure openzwave is used. There should be a line there:
-- Found LIBUSB: /usr/local/lib/libusb.dylib
-- LIBUSB found at: /usr/local/lib/libusb.dylib
-- /Users/Tristan/Smarthome/compile/open-zwave-read-only/libopenzwave.a        <<---- THIS ONE
-- ==== WiringPi include file (wiringPi.h) not found. GPIO support disabled.
-- ==== (Please follow http://wiringpi.com/download-and-install/ if you want to use GPIO.)
-- Not found telldus-core (telldus-core.h), not adding tellstick support
also note that i had problems with cmake cache files, still do not know which folders/files to clean:
viewtopic.php?f=6&t=11766&p=90115&hilit ... ing#p90088
so use a fresh source from git to make sure cmake does not use invalid old configuration.
obrienlabs
Re: Help with ZWave
I ended up doing this for it to work. Clone the open-zwave git to /root, then follow the make and symlink instructions.
root@ubuntu:~# ls
domoticz open-zwave open-zwave-read-only
Then, cd to domoticz and issue a custom cmake command
root@ubuntu:~/domoticz# cmake -USE_STATIC_OPENZWAVE -DCMAKE_BUILD_TYPE=Release CMakeLists.txt
then make
and now i have open-zwave USB available to me
3rd time's a charm
