KAKU specs
manjh
KAKU specs
Post by manjh »
I am getting up to speed using the Domoticz system, and am getting more enthousiastic by the day.
One thing that I am having a little trouble with, is that once I have created a switch, it is no longer possible to see the underlying specs.
For instance, I have a number of light switches for KAKU devices. But I can no longer check which KAKU addresses I used to set them up.
Am I missing something?
Hans
Hans
Derik
Re: KAKU specs
Post by Derik »
Perhaps:
This
manjh
Re: KAKU specs
Post by manjh »
That's very useful for incoming devices, but I don't think switches that I defined manually are on there, are they?
Hans
Derik
Re: KAKU specs
Post by Derik »
yes they are...
All the switches are here visible when they are green new, other bleu
manjh
Re: KAKU specs
Post by manjh »
Excellent. I had not seen that in the large list of devices. I guess some of my neighbours own weather stations... :shock:
Next question is how I can see what KAKU address was used? I can see a few switches of subtype ARC, but no address.
Hans
manjh
Re: KAKU specs
Post by manjh »
Got it. I need to learn to read a bit more before drawing conclusions. :oops:
The number under the header "ID" is the hexadecimal representation of the KAKU home address.
A simple ASCII table helps to understand.
The value under "unit" is the device address.
In my case: ID 45 Unit 4 is KAKU E4.
Hans
