Page 4 of 7
Re: Dashticz v3.8.2 beta: New weather block
Posted: Monday 10 May 2021 13:15
by Chris12
Lokonli wrote: Sunday 02 May 2021 21:01
Chris12 wrote: Friday 30 April 2021 19:54
Lokonli wrote: Friday 30 April 2021 16:34
And if you like colored weather icons, try latest beta.
Nice adition, just tried it and is works fine.
Maybe also get an option to add the wind in the forecast overview as well, below the rain?
Like SW 3 or NO 15m/s etc.
Something like this?
I updated to the latest beta, the wind direction add-on is great!
Is this new wind feature also implemented in the weather layout type 3? Or are there new extra options/parameters there as well?
Posted: Friday 14 May 2021 16:32
by jacobsentertainment
I got it working on three devices, my laptop, my phone, an small 10" tablet but on my 13" tablet I can only see an small icon where the weather should show up. Anybody has some toughts about this?
I did nothing with screen settings in the config, I tried it but did not had any results. Except my laptop all my other devices are Android devices.
Posted: Friday 14 May 2021 16:37
by madpatrick
jacobsentertainment wrote: Friday 14 May 2021 16:32
Try to clear the cache and reload.
I’ve the same sometime and this works for me
Posted: Friday 14 May 2021 17:20
madpatrick wrote: Friday 14 May 2021 16:37
No didn't work. I even installed Chrome
Tested out on several browsers:
- Old android browser: works but then my "dial" type temperature doesn't seem to be working
- Opera: Everything except the weather works.
- Chrome : Same as the Opera browser.
- Firefox can't be installed (no support)
- Edge: same problem and some silly other browser to....
Posted: Friday 14 May 2021 21:23
by Renber
Hello, I already had this problem. Try with this setting:
config['default_cors_url'] = '';
Posted: Friday 14 May 2021 22:55
by Lokonli
jacobsentertainment wrote: Friday 14 May 2021 17:20
Double check that you are running Dashticz 3.8.2 or higher (it's reported if you click on the Dashticz settings icon, upper right)
Can you post your CONFIG.js?
Posted: Friday 14 May 2021 23:02
by Lokonli
jake wrote: Saturday 08 May 2021 14:36
The 'wind' option in the weather block takes quite a bit of real estate in the screen. Therefore a feature request:
Parameter 0, 1, 2 for: icon, text, both or something similar.
The showWind block parameter can be set to true/false to show/hide the wind info.
Posted: Saturday 15 May 2021 1:03
Lokonli wrote: Friday 14 May 2021 22:55
Should be Ok
Posted: Tuesday 25 May 2021 12:26
by whoami
I only see v3.8.1 beta on Github, where to download the 3.8.2. version?
Posted: Tuesday 25 May 2021 18:18
by HansieNL
whoami wrote: Tuesday 25 May 2021 12:26
https://github.com/Dashticz/dashticz/tree/beta
Click
Code and then
Download zip
Posted: Tuesday 25 May 2021 18:43
by Dickey
Or go with terminal into the dasticz folder and enter the git pull command. You will automatic get the latest version.
Posted: Wednesday 26 May 2021 9:03
by Doudy
I tested the thing below but nothing is showing!
var config = {}
config['domoticz_ip'] = 'http://192.168.1.xxx:xxxx';
config['app_title'] = 'Dashticz V3';
config['login_timeout'] = '60';
config['user_name'] = 'xxxxx';
config['pass_word'] = 'xxxxxx';
config['use_favorites'] = 1; //Request all Domoticz Devices, not only favorites
config['auto_positioning'] = 0; // Use 0 this if you have defined your own columns
config['owm_api'] = '5xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx2';
config['owm_city'] = 'xxxxx';
config['owm_name'] = 'Météo xxxxx';
config['owm_country'] = 'be';
config['owm_cnt'] = '4';
config['owm_days'] = 1; // Enter 1 for showing forecast in days, 0 for the OWM default 3 hour forecast
config['owm_lang'] = 'fr'; // Set language for de description of the forecast (rain, cloudy, etc.). For available languages, see https://openweathermap.org/forecast5/#multi
config['owm_min'] = 1; // Enter 1 to show min temperature on 2nd row
config['static_weathericons'] = 0; // Static or 'moving' weather icons
//Definition of blocks
blocks = {}
blocks['weather'] = {
type: 'weather',
apikey: '5xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx2', //Your OpenWeatherMap API key
city: 'xxxxx',
country: 'be',
lang: 'fr',
layout: 0, //Daily forecast
width: 12,
count: 3,
refresh: 1800,
static_weathericons: false,
decimals: 2,
showRain: true,
showDescription: true
//Definition of columns
columns = {}
columns[1] = {
blocks : ['weather'],
width : 8
An idea ?
Posted: Wednesday 26 May 2021 9:56
by Dickey
Try favorits =0.
Btw. API key just once is oké so in the main prefs or in the block format
Posted: Wednesday 26 May 2021 11:16
by Doudy
Dickey wrote: Wednesday 26 May 2021 9:56
Try favorits =0.
It's the same with favorits=0 .
Nothing is showing!
Posted: Wednesday 26 May 2021 12:36
by Dickey
Try this code:
var config = {}
config['domoticz_ip'] = '192.168.1.4;
config['user_name'] = 'user';
config['pass_word'] = 'pasword';
config['use_favorites'] = 0; //Request all Domoticz Devices, not only favorites
config['owm_api'] = ''1234567890';
config['owm_city'] = 'Antwerpen';
config['owm_name'] = 'Antwerpen';
blocks = {}
blocks['weather_0'] = {
type: 'weather',
width: 12,
refresh: 1800,
decimals: 2,
showRain: true,
columns[1] = {};
columns[1]['blocks'] = ['weather_0'];
columns[1]['width'] = 8;
var screens = {}
screens[1] = {}
screens[1]['columns'] = [1];
Posted: Wednesday 26 May 2021 16:40
by Doudy
@Dickey
I tried your version but nothing is showing
- Capture.PNG (119.25 KiB) Viewed 1967 times
Posted: Wednesday 26 May 2021 16:45
by Dickey
What is you're Dasticz version?
Go with terminal into the Dasticz folder and enter the git pull command. You will automatic get the latest version.
Posted: Wednesday 26 May 2021 17:18
by HansieNL
@Doudy
Can you add the following line with code before your columns in your config.js:
And change
blocks = {} to
Tried the follwing code and is working here. Can you try and change
<your_own_setting> to your own settings:
var config = {}
config['domoticz_ip'] = '<your_own_setting>';
config['owm_api'] = '<your_own_setting>';
config['owm_city'] = '<your_own_setting>';
config['owm_name'] = '<your_own_setting>';
config['owm_country'] = 'nl';
config['owm_lang'] = 'nl';
var blocks = {}
type: 'weather',
width: 12,
refresh: 1800,
decimals: 2,
showRain: true,
var columns = {}
columns['bar'] = {}
columns[1] = {}
columns[1]['blocks'] = ['weather']
columns[1]['width'] = 5;
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg2.jpg';
You should get a page with a block like this:
- Naamloos 1.jpg (157.81 KiB) Viewed 1961 times
Posted: Wednesday 26 May 2021 18:42
by Dickey
@HansieNL:I tested the code, and did get the same result as you posted.
That's why i think he have to update Dashticz, course the weather module had a revision.
Posted: Thursday 27 May 2021 7:50
by Doudy
Dickey wrote: Wednesday 26 May 2021 16:45
See my signature : 3.8.0.2
pi@raspberrypi-185:~/dev/dashticz $ git pull
Déjà à jour.
