Dashticz v3.8.2 beta: New weather block
Chris12
Domoticz version: 2021.1
Re: Dashticz v3.8.2 beta: New weather block
Post by Chris12 »
Lokonli wrote: Sunday 02 May 2021 21:01
Chris12 wrote: Friday 30 April 2021 19:54
Lokonli wrote: Friday 30 April 2021 16:34 And if you like colored weather icons, try latest beta.
Nice adition, just tried it and is works fine.
Maybe also get an option to add the wind in the forecast overview as well, below the rain?
Like SW 3 or NO 15m/s etc.
Something like this?
I updated to the latest beta, the wind direction add-on is great!
Is this new wind feature also implemented in the weather layout type 3? Or are there new extra options/parameters there as well?
Domoticz beta | Dashticz beta | Synology DS415+ | Wall tablet Teclast 11.6inch (Android) | TADO v3 controlled heating
jacobsentertainment
Domoticz version: 2021-1
Post by jacobsentertainment »
I got it working on three devices, my laptop, my phone, an small 10" tablet but on my 13" tablet I can only see an small icon where the weather should show up. Anybody has some toughts about this?
I did nothing with screen settings in the config, I tried it but did not had any results. Except my laptop all my other devices are Android devices.
Last edited by jacobsentertainment on Friday 14 May 2021 16:46, edited 1 time in total.
madpatrick
Domoticz version: 2026.1
Post by madpatrick »
jacobsentertainment wrote: Friday 14 May 2021 16:32 Hi all,
Try to clear the cache and reload.
I’ve the same sometime and this works for me
jacobsentertainment
madpatrick wrote: Friday 14 May 2021 16:37 Try to clear the cache and reload.
:cry: No didn't work. I even installed Chrome :o
Tested out on several browsers:
  • Old android browser: works but then my "dial" type temperature doesn't seem to be working
  • Opera: Everything except the weather works.
  • Chrome : Same as the Opera browser.
  • Firefox can't be installed (no support)
  • Edge: same problem and some silly other browser to....
Renber
Post by Renber »
Hello, I already had this problem. Try with this setting:
config['default_cors_url'] = '';
Linux Debian 12 Server: Domoticz beta + Dashticz beta + Node-Red + Homebridge
Lokonli
Post by Lokonli »
jacobsentertainment wrote: Friday 14 May 2021 17:20
Double check that you are running Dashticz 3.8.2 or higher (it's reported if you click on the Dashticz settings icon, upper right)
Can you post your CONFIG.js?
Lokonli
Post by Lokonli »
jake wrote: Saturday 08 May 2021 14:36 The 'wind' option in the weather block takes quite a bit of real estate in the screen. Therefore a feature request:
Parameter 0, 1, 2 for: icon, text, both or something similar.
The showWind block parameter can be set to true/false to show/hide the wind info.
jacobsentertainment
Lokonli wrote: Friday 14 May 2021 22:55 Double check that you are running Dashticz 3.8.2 or higher (it's reported if you click on the Dashticz settings icon, upper right)
Should be Ok
whoami
Post by whoami »
I only see v3.8.1 beta on Github, where to download the 3.8.2. version?
HansieNL
Post by HansieNL »
whoami wrote: Tuesday 25 May 2021 12:26 I only see v3.8.1 beta on Github, where to download the 3.8.2. version?
https://github.com/Dashticz/dashticz/tree/beta
Click Code and then Download zip
Blah blah blah
Dickey
Domoticz version: 2022.1
Post by Dickey »
Or go with terminal into the dasticz folder and enter the git pull command. You will automatic get the latest version.
Dz-beta | Dashticz 3.8.10 BETA | Tradfri | RF-Link | Z-Wave | Harmony | Unify | P1 |
Doudy
Post by Doudy »
I tested the thing below but nothing is showing!
var config = {}
config['domoticz_ip'] = 'http://192.168.1.xxx:xxxx';
config['app_title'] = 'Dashticz V3';
config['login_timeout'] = '60';
config['user_name'] = 'xxxxx';
config['pass_word'] = 'xxxxxx';
config['use_favorites'] = 1; //Request all Domoticz Devices, not only favorites
config['auto_positioning'] = 0; // Use 0 this if you have defined your own columns
config['owm_api'] = '5xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx2';
config['owm_city'] = 'xxxxx';
config['owm_name'] = 'Météo xxxxx';
config['owm_country'] = 'be';
config['owm_cnt'] = '4';
config['owm_days'] = 1; // Enter 1 for showing forecast in days, 0 for the OWM default 3 hour forecast
config['owm_lang'] = 'fr'; // Set language for de description of the forecast (rain, cloudy, etc.). For available languages, see https://openweathermap.org/forecast5/#multi
config['owm_min'] = 1; // Enter 1 to show min temperature on 2nd row
config['static_weathericons'] = 0; // Static or 'moving' weather icons
//Definition of blocks
blocks = {}
blocks['weather'] = {
type: 'weather',
apikey: '5xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx2', //Your OpenWeatherMap API key
city: 'xxxxx',
country: 'be',
lang: 'fr',
layout: 0, //Daily forecast
width: 12,
count: 3,
refresh: 1800,
static_weathericons: false,
decimals: 2,
showRain: true,
showDescription: true
//Definition of columns
columns = {}
columns[1] = {
 blocks : ['weather'],
 width : 8
An idea ?
Dickey
Post by Dickey »
Try favorits =0.
Btw. API key just once is oké so in the main prefs or in the block format
Doudy
Post by Doudy »
Dickey wrote: Wednesday 26 May 2021 9:56 Try favorits =0.
It's the same with favorits=0 .
Nothing is showing!
Dickey
Post by Dickey »
Try this code:
var config = {}
config['domoticz_ip'] = '192.168.1.4;
config['user_name'] = 'user';
config['pass_word'] = 'pasword';
config['use_favorites'] = 0; //Request all Domoticz Devices, not only favorites
config['owm_api'] = ''1234567890';
config['owm_city'] = 'Antwerpen';
config['owm_name'] = 'Antwerpen';
blocks = {}
blocks['weather_0'] = {
type: 'weather',
width: 12,
refresh: 1800,
decimals: 2,
showRain: true,
columns[1] = {};
columns[1]['blocks'] = ['weather_0'];
columns[1]['width'] = 8;
var screens = {}
screens[1] = {}
screens[1]['columns'] = [1];
Doudy
Post by Doudy »
@Dickey
I tried your version but nothing is showing :?
Dickey
Post by Dickey »
What is you're Dasticz version?
Go with terminal into the Dasticz folder and enter the git pull command. You will automatic get the latest version.
HansieNL
Post by HansieNL »
@Doudy
Can you add the following line with code before your columns in your config.js:
var columns = {}
And change blocks = {} to
var blocks = {}
Tried the follwing code and is working here. Can you try and change <your_own_setting> to your own settings:
var config = {}
config['domoticz_ip'] = '<your_own_setting>';
config['owm_api'] = '<your_own_setting>';
config['owm_city'] = '<your_own_setting>';
config['owm_name'] = '<your_own_setting>';
config['owm_country'] = 'nl';
config['owm_lang'] = 'nl';
var blocks = {}
type: 'weather',
width: 12,
refresh: 1800,
decimals: 2,
showRain: true,
var columns = {}
columns['bar'] = {}
columns[1] = {}
columns[1]['blocks'] = ['weather']
columns[1]['width'] = 5;
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg2.jpg';
You should get a page with a block like this:
Naamloos 1.jpg (157.81 KiB) Viewed 2024 times
Blah blah blah
Dickey
Post by Dickey »
@HansieNL:I tested the code, and did get the same result as you posted.
That's why i think he have to update Dashticz, course the weather module had a revision.
Doudy
Post by Doudy »
Dickey wrote: Wednesday 26 May 2021 16:45 What is you're Dasticz version?
See my signature : 3.8.0.2
Dickey wrote: Wednesday 26 May 2021 16:45 Go with terminal into the Dasticz folder and enter the git pull command. You will automatic get the latest version.
pi@raspberrypi-185:~/dev/dashticz $ git pull
Déjà à jour.
