Dashticz - Module - 112 Meldingen (Dutch) Topic is solved
Lokonli
Re: Dashticz - Module - 112 Meldingen (Dutch)
Post by Lokonli »
In latest beta I've added a timeformat parameter:
blocks[alarmmeldingen'] = {
  timeformat: 'dd HH:MM'
For a format guide see:
https://momentjscom.readthedocs.io/en/l ... 01-format/
PietjePuck
Post by PietjePuck »
There is a small error in the default timeformat in the alarmeldingen.js.
The default time format should be this in order to show two digits :
timeformat: 'ddd D MMM HH:MM'
Instead of
timeformat: 'ddd d MMM HH:MM'
Today it shows apr. 2 time alarmmelding
sschouten
Post by sschouten »
Hey,
i want to change te location to Hoofddorp
i found the rss feed for hoofddorp
blocks['alarmmeldingen'] = {
rss: 'https://www.alarmeringen.nl/feeds/regio ... erland.rss',
filter: 'hoofddorp',
show_lastupdate: true,
width:12,
icon: 'fas fa-bullhorn',
interval: 180,
results: 5,
But in dashticz he is not filtering only hoofddorp
HansieNL
Post by HansieNL »
sschouten wrote: Saturday 02 May 2020 22:42 Hey,
width:12,
interval: 180,
results: 5,
Have you tried with a capital h -> Hoofddorp ?
Blah blah blah
dorenberg
Domoticz version: 4.10982
Post by dorenberg »
PietjePuck wrote: Tuesday 28 April 2020 15:36 There is a small error in the default timeformat in the alarmeldingen.js.
Instead of
Yes, this seems to help, however all minutes are not displayed correctly too and all on 05 minutes?
So it must be this, or if you like without the ss of the seconds.:
timeformat: 'ddd D MMM hh:mm:ss'
Droid
Post by Droid »
Yesterday I've added the alarmeringen to my Dashticz:
        title: '112 meldingen Doetinchem',
        rss: 'https://alarmeringen.nl/feeds/city/doetinchem.rss',
        width: 12,
        refresh: 300,   //refresh rate in seconds
        results: 5,   //number of recent results to show
        image: '../custom/img/112meldingen.png'
It showed up nicely, but dat no recent items.
Checking it today gives the same result:
Aantekening 2020-06-20 085340.png (8.43 KiB) Viewed 2222 times
I checked the RSS file and there where some calls this night. So there should be results in here... What am I doing wrong here?
Lokonli
Post by Lokonli »
The title in the actual result ('P2000 brandweer meldingen') is not the same as in the block definition ('112 meldingen Doetinchem')
Can it be related to that? (do you maybe redefine the block somewhere?)
EdwinK
Post by EdwinK »
I also see that after some time there are no results. Could it be that some time after the last event the script just displays this message?
Droid
Post by Droid »
Lokonli wrote: Saturday 20 June 2020 10:19 The title in the actual result ('P2000 brandweer meldingen') is not the same as in the block definition ('112 meldingen Doetinchem')
No, I've changed it in between... it is the same now.
I did some further digging... in alarmmeldingen.js I've added this line:
    function dataAlarmInfo(me, data) {
      console.log(data);
      var alarmobject = me.block;
      var html = '';
Then, checking the console, it says null
So no items were retrieved...
Droid
Post by Droid »
Found it, I had to open curl and openssl on my Synology server...
Another question, is it possible to filter on only the fire department messages?
Lokonli
Post by Lokonli »
There is a parameter 'filter' which could work.
Larsoss
Post by Larsoss »
thanks for your script. I'm playing around with it, and it works ... but not as desired .. I live in berghem, village in the municipality of oss ...
But I get to see everything from the RSS feed?
var alarmmeldingen = {
  rss: 'https://alarmeringen.nl/feeds/region/brabant-noord.rss',
  city: 'Oss,Heesch,Berghem,Traumaheli',
  show_lastupdate:true,
  width:12,
  interval: 180,
  results: 5}
I copied the alarms.js into my .js folder as said, and created the block neatly
columns[2]['blocks'] = [buttons.buienradar,calendars.f1,alarmmeldingen,'garbage'];
i see the block.
so what did i wrong?
Raspberry 4 - USB boot Domoticz /|\ Raspberry 2B - Dashticz /|\ Tasmota device's /|\ Philips Hue & Yeelight
Lokonli
Post by Lokonli »
Larsoss wrote: Wednesday 16 September 2020 18:59 thanks for your script. I'm playing around with it, and it works ... but not as desired .. I live in berghem, village in the municipality of oss ...
  width:12,
  interval: 180,
  results: 5}
columns[2]['blocks'] = [buttons.buienradar,calendars.f1,'alarmmeldingen','garbage'];
i see the block.
No need to copy alarms.js I would say.
Define your block in CONFIG.js as follows:
  width:12,
  interval: 180,
  results: 5
(alarmmeldingen enclosed in tick marks)
or indeed, as an alternative, you can also define a variable. Use the following in CONFIG.js:
  width:12,
  interval: 180,
  results: 5
columns[2]['blocks'] = [buttons.buienradar,calendars.f1, alarmmeldingen,'garbage'];
(alarmmeldingen without tick marks)
I recommend the first method.
Larsoss
Post by Larsoss »
ok i took the top one because it is the best way according to you. No problem we will continue with that.
unfortunately, if I use this then I also get other places .. And that is not the intention .. Where does it go wrong?
Lokonli
Post by Lokonli »
Larsoss wrote: Thursday 17 September 2020 21:10 ok i took the top one because it is the best way according to you. No problem we will continue with that.
The parameter 'city' has been renamed to 'filter' to better reflect it's purpose.
EdwinK
Post by EdwinK »
Screen Shot 2020-09-28 at 22.48.36.png (42.19 KiB) Viewed 2005 times
I got a strange date for an alert today. Somehow the system seems to think it's Mon September 1.
EdwinK
Post by EdwinK »
Fixed. It should have been DD instead of dd
FinalX
Post by FinalX »
this is in my config.js :
title: '<string>',
rss: 'https://alarmeringen.nl/feeds/city/hoeven.rss',
filter: 'Hoeven', //filter the messages for your town and if you want the cities around you
width: 12,
results: 5 //number of recent results to show
but i keep seeing:
Lokonli
Post by Lokonli »
I can't see the image. Can you report, and indicate what's wrong?
Your block is ok, except for the title parameter. You have to remove the '<' and '>' symbols, and replace string with something more appropriate :)
EdwinK
Post by EdwinK »
When I use this, I see the following:
[attachment=0]Screen Shot 2020-12-29 at 16.41.09.png[/attachment]
Screen Shot 2020-12-29 at 16.41.09.png (86.65 KiB) Viewed 1785 times
