Dashticz - Module - 112 Meldingen (Dutch) Topic is solved
PietjePuck
Post by PietjePuck »
After using Dashticz for a while now i decided to return something.
I wrote a custom js script to display the last x 112 Alarm messages on my dashboard.
To use this on yourdashboard:
Copy the alarmmeldingen.js to your /js/components directory.
alarmmeldingen.js
(3.33 KiB) Downloaded 317 times
Edit the dashtics.js file in the /js directory and add this line just before the 'secpanel' line:
 'alarmmeldingen',
Then add the configuration settings to your config.js file in the /custom folder:
var alarmmeldingen = {
  rss: 'http://www.alarmeringen.nl/feeds/region/rotterdam-rijnmond.rss',
  city: 'Poortugaal,Rhoon,Hoogvliet,Traumaheli,Pernis',
  show_lastupdate:true,
  width:12,
  interval: 180,
  results: 5}
Get the rrs link from the site http://www.alarmeringen.nl/ in this case i used my region 'Rotterdam-Rijnmond
With the city variable you can filter the messages for your town and if you want the cities around you. Use Traumaheli to get all alarms containing the support of the Trauma Heli
If you would like to have an icon in this block you can use the icon: variable
icon: 'fas fa-bullhorn',
The interval defines the refresh rate in seconds
results defines the number of resent results to show.
To use the formatting in my screenshot add these values to the custom.css file in the /custom folder.
.alarmrow{
    font-size: 14px !important;
.alarmrow a {
  color: white;
.alarmrow strong{
    display: inline-block;
Lokonli
Re: Dashticz - Module - 112 Meldingen (Dutch)
Post by Lokonli »
Thank you for your contribution!
I will merge this into the next beta version of Dashticz.
PietjePuck
May be you can send me the instructions how to do this (i am not familiar with this yet) so i can do this next time on my own (or a little help from you).
HansieNL
Post by HansieNL »
PietjePuck wrote: Wednesday 18 March 2020 15:06 May be you can send me the instructions how to do this (i am not familiar with this yet) so i can do this next time on my own (or a little help from you).
Short instructions:
Create a GitHub account (that's where the Dashticz code files can be found)
Fork Dashticz (copy for yourself to change/edit)
Edit the files from the beta branch
Send a Pull Request (request to add your changes)
Blah blah blah
EdwinK
Post by EdwinK »
Thanks.
I like this part:
Didn't really have to change anything as I happen to live there. I just deleted Hoogvliet and Pernis
HansieNL
Post by HansieNL »
I tried with your own settings with Dashticz latest beta.
I get only a message: Loading...
The page is now one long page with a scrollbar. I can't swipe to other page anymore. Someone else has the same problem?
Blah blah blah
Lokonli
Post by Lokonli »
Hi PietjePuck,
That would be great!
Most of it is documented here:
https://dashticz.readthedocs.io/en/mast ... b-workflow
Maybe you can try to do the merging yourself?
If you need help please let me know.
Boattailman
Post by Boattailman »
HansieNL wrote: Wednesday 18 March 2020 17:52 I tried with your own settings with Dashticz latest beta.
Yes, same issue here
EdwinK
Post by EdwinK »
It works here for me.
Maybe you forgot to add the attached .js file or to edit dashticz.js?
PietjePuck
Can you send me your config.js file (please remove api keys) and dashticz.js so i can check if you entered the right settings ?
HansieNL
Post by HansieNL »
PietjePuck wrote: Thursday 19 March 2020 10:33
I used the settings as in 1st post:
  width:12,
  interval: 180,
  results: 5}
Added 'alarmmeldingen' to a column. So nothing special. Will try with stripped down config and see if something is conflicting.
Blah blah blah
HansieNL
Post by HansieNL »
Tried with this default config:
var config = {}
config['domoticz_ip'] = 'http://192.168.2.14:8081';
config['login_timeout'] = '60';
config['user_name'] = '';
config['pass_word'] = '';
config['app_title'] = 'Dashticz V3';
config['room_plan'] = '0';
config['default_news_url'] = 'http://www.nu.nl/rss/algemeen';
config['news_scroll_after'] = '7';
config['default_cors_url'] = '';
config['dashticz_php_path'] = './vendor/dashticz/';
config['standby_call_url'] = '';
config['standby_call_url_on_end'] = '';
config['theme'] = 'default';
config['background_image'] = 'img/bg2.jpg';
config['standby_after'] = '0';
config['start_page'] = '1';
config['enable_swiper'] = '2';
config['vertical_scroll'] = '2';
config['auto_swipe_back_to'] = '1';
config['auto_swipe_back_after'] = '10';
config['auto_slide_pages'] = '';
config['slide_effect'] = 'slide';
config['standard_graph'] = 'hours';
config['blink_color'] = '255, 255, 255, 1';
config['language'] = 'en_US';
config['timeformat'] = 'DD-MM-YY HH:mm';
config['calendarformat'] = 'dd DD.MM HH:mm';
config['calendarlanguage'] = 'en_US';
config['calendarurl'] = '';
config['boss_stationclock'] = 'RedBoss';
config['gm_api'] = '';
config['gm_zoomlevel'] = '';
config['gm_latitude'] = '';
config['gm_longitude'] = '';
config['speak_lang'] = 'en-US';
config['wu_api'] = '';
config['wu_city'] = 'Amsterdam';
config['wu_name'] = '';
config['wu_country'] = 'NL';
config['owm_api'] = '';
config['owm_city'] = 'Mainaschaff';
config['owm_name'] = '';
config['owm_country'] = 'de';
config['owm_lang'] = '';
config['owm_cnt'] = '4';
config['idx_moonpicture'] = '';
config['longfonds_zipcode'] = '';
config['longfonds_housenumber'] = '';
config['switch_horizon'] = '';
config['host_nzbget'] = '';
config['spot_clientid'] = '';
config['sonarr_url'] = '';
config['sonarr_apikey'] = '';
config['sonarr_maxitems'] = '';
config['garbage_company'] = '';
config['garbage_icalurl'] = '';
config['google_api_key'] = '';
config['garbage_calendar_id'] = '';
config['garbage_zipcode'] = '';
config['garbage_street'] = '';
config['garbage_housenumber'] = '';
config['garbage_housenumberadd'] = '';
config['garbage_maxitems'] = '';
config['garbage_width'] = '';
config['setpoint_min'] = '5';
config['setpoint_max'] = '40';
config['evohome_status'] = 'Auto';
config['evohome_boost_zone'] = '60';
config['evohome_boost_hw'] = '15';
config['loginEnabled'] = 0;
config['disable_update_check'] = 0;
config['enable_websocket'] = 0;
config['no_rgb'] = 0;
config['auto_positioning'] = 0;
config['use_favorites'] = 1;
config['disable_googleanalytics'] = 0;
config['last_update'] = 1;
config['hide_topbar'] = 0;
config['security_button_icons'] = 0;
config['edit_mode'] = 0;
config['hide_seconds'] = 0;
config['hide_seconds_stationclock'] = 0;
config['owm_days'] = 0;
config['owm_min'] = 0;
config['use_fahrenheit'] = 0;
config['use_beaufort'] = 0;
config['translate_windspeed'] = 1;
config['static_weathericons'] = 0;
config['hide_mediaplayer'] = 0;
config['garbage_icon_use_colors'] = 1;
config['garbage_use_colors'] = 0;
config['garbage_use_names'] = 0;
config['garbage_use_cors_prefix'] = 1;
var publictransport = {}
publictransport.ovinfobus = { show_via: false, station: 'son-en-breugel/bushalte-penseelkever', provider: '9292-bus', icon: 'bus', width:5, results: 6 }
var tvguide = {}
tvguide.dutch = { key:'dutch', icon: 'fas fa-tv', width:7, channels: [1,3,4,31,46,92], maxitems: 5 }
var _STREAMPLAYER_TRACKS  	= [
	{"track":1,"name":"Q-music","file":"http://icecast-qmusic.cdp.triple-it.nl/Qmusic_nl_live_96.mp3"},
	{"track":2,"name":"538 Hitzone","file":"http://vip-icecast.538.lw.triple-it.nl/WEB11_MP3"},
	{"track":3,"name":"Slam! NonStop","file":"http://stream.radiocorp.nl/web10_mp3"},
	{"track":4,"name":"100%NL","file":"http://stream.100p.nl/100pctnl.mp3"},
var buttons = {}
buttons.nunl = {key: 'nunl',  width:12, icon: 'fa-newspaper-o', title: 'Nu.nl', newwindow:true, url: 'http://www.nu.nl'}
buttons.nos = {key: 'nos',  width:12, icon: 'fa-newspaper-o', title: 'Nos', url: 'http://www.nos.nl'}
var blocks = {}
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['key'] = 'blocktitle_1';
blocks['blocktitle_1']['title'] = 'Example';
var columns = {}
columns['bar'] = {}
columns[1] = {}
columns[1]['blocks'] = ['alarmmeldingen']
columns[1]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = ['sunrise','streamplayer',buttons.nunl,buttons.nos]
columns[3]['width'] = 2;
var columns_standby = {}
columns_standby[1] = {}
columns_standby[1]['blocks'] = ['clock','weather']
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg2.jpg';
This was working fine till I added:
  width:12,
  interval: 180,
  results: 5}
Then I get:
112 Meldingen
Loding...
And the rest of the blocks won't load anymore.
Blah blah blah
PietjePuck
And what about the first few rows of the dashticz.js ?
PietjePuck
I also see you did not define the default cors proxy. Can you define this and test ?
HansieNL
Post by HansieNL »
PietjePuck wrote: Thursday 19 March 2020 18:54 I also see you did not define the default cors proxy. Can you define this and test ?
        'tvguide',
        'trafficinfo',
        'alarmmeldingen',
        'secpanel',
		'graph'
Also tried with: http://cors-anywhere.herokuapp.com
Still same problem of loading and not showing of other blocks. If I comment 'alarmmeldingen', everything works fine.
Blah blah blah
PietjePuck
And alarmmeldingen.js is in the js/components/ folder ?
Lokonli
Post by Lokonli »
I just merged "alarmmeldingen" into beta,
All credits go to @PietjePuck.
Instructions:
Define your "alarmmeldingen" block (optional):
blocks['alarmmeldingen'] = {
    rss: 'https://alarmeringen.nl/feeds/city/venlo.rss',
    filter: 'Venlo',
Add "alarmmeldingen" to a column:
    'alarmmeldingen',
Use the site https://alarmeringen.nl to find the rss-feed of your choice (region, city)
I've renamed the 'city' parameter to 'filter', because this better describes what the parameter is doing.
Filter is not case sensitive.
If you want to remove the icon, add the following to your block definition:
	icon: '',  //This are two tick-marks
PietjePuck
Thx for your help in my first contribution to Dashticz
HansieNL
Post by HansieNL »
PietjePuck wrote: Thursday 19 March 2020 19:41 And alarmmeldingen.js is in the js/components/ folder ?
Just downloaded your GitHub version and have the same problem. Not loaded and other blocks not shown.
CONFIG.js:
var config = {}
config['default_cors_url'] = 'http://cors-anywhere.herokuapp.com';
config['language'] = 'nl_NL';
config['calendarlanguage'] = 'nl_NL';
config['enable_websocket'] = 1;
config['use_favorites'] = 0;
var tvguide = {}
var buttons = {}
var blocks = {}
  width:12,
  interval: 180,
  results: 5}
var columns = {}
columns['bar'] = {}
columns[1] = {}
columns[2] = {}
columns[2]['blocks'] = ['blocktitle_1',tvguide.dutch,publictransport.ovinfobus]
columns[2]['width'] = 5;
columns[3] = {}
var screens = {}
screens[1] = {}
Blah blah blah
PietjePuck
Change
To
columns[1]['blocks'] = [alarmmeldingen]
