Blockly examples
four2six
Re: Blockly examples
this should still work, if i understand your setup correctly
if 'skymningsrelä' = on and 'larmsensor 1' = on
set scene 'Larmsensor 1 av' = active
if 'skymningsrelä'' = off
set scene 'Larmsensor 1 av' = inactive
tjabas
Yes its correct, but it doesnt work.
i can still aktivate the trigger that aktivates the scene when skymningningsrelä is set to off.
is it possible to make a switch inactive?
four2six
i'm not sure anymore i really understood what you want to achieve.
i understood:
switch 'larm' ist activated by your burglar alarm.
the scene 'Larmsensor 1 av' is the scene you want to be able to activated manually with the switch 'Larmsensor 1', but only after sunset and before sunrise.
you have a dummy switch "skymningsrelä" with a timer that is turned off at sunset and turned on at sunrise.
is this correct?
what is the connection between 'larm' and the rest?
i understood:
is this correct?
tjabas
The switch larm is irrelevant, its a fysical button that i press to turn on the burglar alarm in the house, these things dont have anything to do with Domoticz. The only connection between the burglar alarm and Domoticz is the larmsensor1 switch in Domoticz, the burglar alarm sends an on command to the larmsensor1 switch in Domoticz, but otherwise by your are right in the post above. I hope you undrerstand what i mean.
edje1205
- Domoticz version: 3.5877
light won't go off
Hello
I'm new here but after a week a junk for domoticz !
So easy but second part wont work
doorbell is pressed
after 5 seconds light goes on
if light is on
send sms with tekst
keep light on for x minutes (here 30 seconds)
send cam snapshot
all well but light keeps on and wont go off !
whats wrong ?
thnx in advance
doorbell is pressed
if light is on
send sms with tekst
send cam snapshot
whats wrong ?
thnx in advance
- doorbell light cam script vertragen.jpg (383.96 KiB) Viewed 3296 times
- doorbell light cam script vertragen 2.jpg (376.4 KiB) Viewed 3296 times
- StanHD
The nested "If" Blocks are a problem. Can you redo with a single "If" and multiple "Else-If" structure?
The blocks used for seconds and minutes should be integer not time. (6) seconds, not (06:00) seconds.
Python:- Broadlink RM2, Sonos
bjacobse
Yes I also have problems with nested if-else/if and have done as StanHD proposed with success, to avoid the nested, take a look at mine as proposal how you can do similar blocklyStanHD wrote:The nested "If" Blocks are a problem. Can you redo with a single "If" and multiple "Else-If" structure?
edje1205
Thanks for reply Stan !StanHD wrote:The nested "If" Blocks are a problem. Can you redo with a single "If" and multiple "Else-If" structure?
Now I have this (see att) :
Script: light goes on immediatly ( not after 10 seconds) and I want a relais of 10 sec
sms has send
camera snapshot has send
light goes off after 1 minute
The starting if (when light = on) is that correct ? if I do when light = off nothing happened; same for all statements so on is logic (?)
but not logic is: when light = on, set light on after 10 seconds (because it's already on). Or what ?
Wait ! I´m struggling with the ´else if´ uhhh
grtz
- doorbell light cam script vertragen 2a.jpg (109.2 KiB) Viewed 3258 times
- StanHD
Yes you still have nested "If"s, try doing as @bjacobse above. A single "If" with multiple "Else if".
tjabas
Good morning!
im trying to get some lamps not to turn on during sunrise, yeat active during sunset.
please take a look at this blockly, i cant get it to work.
[img][/img]
[img][/img]
- cyberclwn
- Domoticz version: 2024.4
I think the main issue here is that "Sunset" is a time. let's say it's "16:27".
So only when you have Kodi paused at 16:27, it will trigger.
Probably you mean "time > sunset" (after sunset)
Also the if looks a bit strange to me.
look at the previous post of bjacobse to see the difference in the "if" statement.
If "kodi = ( paused and (time = 16:27 ) ) then ... 3xPi 2B (Domoticz "live", Domoticz "sandbox", PhotoFrame)
RFXCom433(E), KaKu, Oregon Scientific, Keyes 2-relay, Logitech Media Server, MiLight, Smartwares heating controller(2x), IR Send/Receive, Keyes PIR, XH-M131 DuskSensor, DHT22/11
tjabas
yes i mean after sunset
so the > should be pointing towards the sunset block?
otherwise, did the setup seem to be working?
- StanHD
Try:- (Kodi=paused) and (Time = sunset)
not (Kodi=(paused and Time = sunset)
Sometimes setting the options on the "and" block to external inputs makes the logic easier to see / understand.
edje1205
Thanks StanH and of course bjacobse (ignored your suggestionStanHD wrote:Yes you still have nested "If"s, try doing as @bjacobse above. A single "If" with multiple "Else if".
This is working !
Easy and what I wanted !
I will read other blockly's (blocklies) to learn later.
Now time for shopping; the wife is waiting
- doorbell light cam script vertragen final.jpg (74.04 KiB) Viewed 3197 times
- StanHD
Re: RE: Re: Blockly examples
tjabas
StanHD wrote:Try:- (Kodi=paused) and (Time = sunset)
thanks for your answer, it didnt work, i cant really tell why, i also have a dummy switch that turns on after sunset and of when sun rises.
i aslo replaced sunset timer with the dummy switch, but neither that one worked.
Is there anyone what would like to make a example blockly of how this would look like?
thank you.
- StanHD
Similar to this is worth a try:-
tjabas
thanksStanHD wrote:Similar to this is worth a try:-
but i dont really know how i would get that big (and) block right beside the (if do) block.
cant find it anywhere.
- StanHD
Right click the "and" block and select external inputs.
tjabas
thank you
