Blockly examples
four2six
Re: Blockly examples
Post by four2six »
this should still work, if i understand your setup correctly
if 'skymningsrelä' = on and 'larmsensor 1' = on
set scene 'Larmsensor 1 av' = active
if 'skymningsrelä'' = off
set scene 'Larmsensor 1 av' = inactive
tjabas
Post by tjabas »
Yes its correct, but it doesnt work.
i can still aktivate the trigger that aktivates the scene when skymningningsrelä is set to off.
is it possible to make a switch inactive?
four2six
Post by four2six »
i'm not sure anymore i really understood what you want to achieve.
i understood:
switch 'larm' ist activated by your burglar alarm.
the scene 'Larmsensor 1 av' is the scene you want to be able to activated manually with the switch 'Larmsensor 1', but only after sunset and before sunrise.
you have a dummy switch "skymningsrelä" with a timer that is turned off at sunset and turned on at sunrise.
is this correct?
what is the connection between 'larm' and the rest?
tjabas
Post by tjabas »
The switch larm is irrelevant, its a fysical button that i press to turn on the burglar alarm in the house, these things dont have anything to do with Domoticz. The only connection between the burglar alarm and Domoticz is the larmsensor1 switch in Domoticz, the burglar alarm sends an on command to the larmsensor1 switch in Domoticz, but otherwise by your are right in the post above. I hope you undrerstand what i mean.
edje1205
Domoticz version: 3.5877
light won't go off
Post by edje1205 »
Hello
I'm new here but after a week a junk for domoticz !
So easy but second part wont work
doorbell is pressed
after 5 seconds light goes on
if light is on
send sms with tekst
keep light on for x minutes (here 30 seconds)
send cam snapshot
all well but light keeps on and wont go off ! :roll:
whats wrong ? :oops:
thnx in advance
doorbell light cam script vertragen.jpg (383.96 KiB) Viewed 3480 times
doorbell light cam script vertragen 2.jpg (376.4 KiB) Viewed 3480 times
StanHD
Post by StanHD »
The nested "If" Blocks are a problem. Can you redo with a single "If" and multiple "Else-If" structure?
The blocks used for seconds and minutes should be integer not time. (6) seconds, not (06:00) seconds.
Python:- Broadlink RM2, Sonos
bjacobse
Post by bjacobse »
StanHD wrote:The nested "If" Blocks are a problem. Can you redo with a single "If" and multiple "Else-If" structure?
Yes I also have problems with nested if-else/if and have done as StanHD proposed with success, to avoid the nested, take a look at mine as proposal how you can do similar blockly
edje1205
Post by edje1205 »
Thanks for reply Stan !
Now I have this (see att) :
Script: light goes on immediatly ( not after 10 seconds) and I want a relais of 10 sec :?
sms has send
camera snapshot has send
light goes off after 1 minute :)
The starting if (when light = on) is that correct ? if I do when light = off nothing happened; same for all statements so on is logic (?)
but not logic is: when light = on, set light on after 10 seconds (because it's already on). Or what ?
Wait ! I´m struggling with the ´else if´ uhhh
grtz
doorbell light cam script vertragen 2a.jpg (109.2 KiB) Viewed 3442 times
StanHD
Post by StanHD »
Yes you still have nested "If"s, try doing as @bjacobse above. A single "If" with multiple "Else if".
tjabas
Post by tjabas »
Good morning!
im trying to get some lamps not to turn on during sunrise, yeat active during sunset.
please take a look at this blockly, i cant get it to work.
[img]
[/img]
cyberclwn
Domoticz version: 2024.4
Post by cyberclwn »
I think the main issue here is that "Sunset" is a time. let's say it's "16:27".
So only when you have Kodi paused at 16:27, it will trigger.
Probably you mean "time > sunset" (after sunset)
Also the if looks a bit strange to me.
If "kodi = ( paused and (time = 16:27 ) ) then ...
look at the previous post of bjacobse to see the difference in the "if" statement.
3xPi 2B (Domoticz "live", Domoticz "sandbox", PhotoFrame)
RFXCom433(E), KaKu, Oregon Scientific, Keyes 2-relay, Logitech Media Server, MiLight, Smartwares heating controller(2x), IR Send/Receive, Keyes PIR, XH-M131 DuskSensor, DHT22/11
tjabas
Post by tjabas »
yes i mean after sunset :) so the > should be pointing towards the sunset block?
otherwise, did the setup seem to be working?
StanHD
Post by StanHD »
Try:- (Kodi=paused) and (Time = sunset)
not (Kodi=(paused and Time = sunset)
Sometimes setting the options on the "and" block to external inputs makes the logic easier to see / understand.
edje1205
Post by edje1205 »
StanHD wrote:Yes you still have nested "If"s, try doing as @bjacobse above. A single "If" with multiple "Else if". Image
Thanks StanH and of course bjacobse (ignored your suggestion :oops: )
This is working !
Easy and what I wanted !
I will read other blockly's (blocklies) to learn later.
Now time for shopping; the wife is waiting :lol: :D :mrgreen:
doorbell light cam script vertragen final.jpg (74.04 KiB) Viewed 3381 times
StanHD
Re: RE: Re: Blockly examples
Post by StanHD »
tjabas
Post by tjabas »
StanHD wrote:Try:- (Kodi=paused) and (Time = sunset)
Sometimes setting the options on the "and" block to external inputs makes the logic easier to see / understand. Image
thanks for your answer, it didnt work, i cant really tell why, i also have a dummy switch that turns on after sunset and of when sun rises.
i aslo replaced sunset timer with the dummy switch, but neither that one worked.
Is there anyone what would like to make a example blockly of how this would look like?
thank you.
StanHD
Post by StanHD »
Similar to this is worth a try:-
tjabas
Post by tjabas »
StanHD wrote:Similar to this is worth a try:-
thanks
but i dont really know how i would get that big (and) block right beside the (if do) block.
cant find it anywhere.
StanHD
Post by StanHD »
Right click the "and" block and select external inputs.
Sent from my SM-G925F using Tapatalk
tjabas
Post by tjabas »
thank you :)
