Page 111 of 123
Posted: Saturday 13 January 2018 8:58
by Mozart
I don’t know if this is the best thread to make a request but if it is, maybe look in to supporting a new wireless switch from aqara as well that shows up in the logs as:
XiaomiGateway: unhandled model: sensor_switch.aq3
Posted: Sunday 14 January 2018 2:53
by corbin
xraken wrote: Saturday 13 January 2018 1:20
I have a bunch of Xiaomi sensors working fine with the latest Domoticz beta. I just bought a pair of aqara water sensors (
https://www.gearbest.com/home-smart-imp ... 68897.html) but looks like it is not yet compatible with Domoticz.
I see this in the log:
2018-01-12 19:12:58.922 XiaomiGateway: unhandled model: sensor_wleak.aq1
Any chance this device can be supported? I can help if there's anything I can further debug and report back.
I thought the water sensor was working already, see
https://github.com/domoticz/domoticz/bl ... y.cpp#L899
What beta version are you on?
Posted: Sunday 14 January 2018 5:48
by farhanito
is there a way to reboot the gateway remotely other than plugging it into a smart socket?
Posted: Sunday 14 January 2018 15:34
by xraken
corbin wrote: Sunday 14 January 2018 2:53
You are correct, I thought I was on the latest beta but it turned out I had switched to an older one. The aqara water sensor works fine with the latest beta.
Posted: Monday 15 January 2018 17:19
by DeputyNL
DeputyNL wrote: Friday 12 January 2018 15:57
Most of the time I can control the Xiaomi switches with domoticz, but some of the time I can't and see the following message in the logs:
XiaomiGateway: unable to write command - Invalid key
The funny thing is that the key is fine, if I update the device with no changes, all works well again; The other funny thing is that I can always control the switches from the MiHome app, so I know the Gateway has WiFi and can see the switches. Does anyone have a clue what I can do to solve this issue?
Problem solved by opening UDP 9898 on the firewall, so Domoticz recieves the heart beats
Posted: Monday 15 January 2018 17:28
by BarryT
Does someone know if the Xiaomi Gateway also works with the "klik aan klik uit" (coco) products with the zigbee protocol?
If not, does i need the Z1 Zigbee Control Station to get it work?
I have a lot (to much) of the (old) 433 mhz kaku switches/sensors and motion detectors.
For first i'm unhappy with its battery life, I need to replace the (eneloop) batteries every month.
i also think that the band is full with other 433 clients because sometimes the pirs were not "seen", or no "off" signal is recieved..
i need some other pirs like zwave or zigbee wich is working on another freq / protocol, or at least 2 way.
I want to use a ZPIR-8000, for example.
This is a zigbee pir, so just looking around for a universal controller wich will work with these pirs
Ofcourse, other tips are welcome as well!
Protocols i already have > RFXCom, Z-Wave, RFLink, MiLight
Posted: Friday 19 January 2018 22:30
by Mozart
Mozart wrote: Saturday 13 January 2018 8:58
I see that this is solved in the beta version 3.8833.
Posted: Saturday 20 January 2018 0:17
by vincenttor
Is it maybe a good idea to make a topic with a picture what sensor/switch/addon from xiaomi that works, also shows what kind of settings can be used with that certain part ?
like long press/click / on off etc ?
Posted: Saturday 20 January 2018 22:53
by BarryT
vincenttor wrote: Saturday 20 January 2018 0:17
That would be handy
Posted: Saturday 20 January 2018 23:39
by corbin
This information can be found from the Xiaomi documentation at
https://www.gitbook.com/book/forrestfun ... pi/details -
https://cnbj2.fds.api.xiaomi.com/lumiai ... .08.01.doc
And have started putting the details in the Wiki, but will leave for someone else to complete -
https://www.domoticz.com/wiki/Xiaomi_Ga ... OMPLETE.29
Posted: Sunday 21 January 2018 0:07
by vincenttor
O thats great Corbin,
i believe i haven't even seen that , probably with my eyes closed...
Thanks for the begin, when buying more sensors ill try to add some info as well.
takes only very long with shipping from gearbest lately, already on the move for 1.5 month or longer
Posted: Sunday 21 January 2018 1:21
by devros
Hello i have Xiaomi wall switch one button wired, after conection bulb switch on off in loop, registration in Xiaomi app works. When i switch bulb in app on i hear click sound but bulb is still only blinking, tried diferent bulbs but still same problem, any idea what coul be wrong?
maybe wiring problem but cant figure whats wrong? I have tree cables black,brown, green, old switch works only with black and brown conected....
Lamp (4 bulbs) is conected black to L and green to N, brown is unconected
Posted: Sunday 21 January 2018 19:07
by islandman
devros wrote: Sunday 21 January 2018 1:21
L is Life Wire
N is Neutral (you need it with this switch but a normal switch does not have it)
L1 should be the wire to the lamp
However you never know what color is the right. From my experience green - Ground (no need for that), Black is Life Wire brown could be the Lamp and blue is Neutral!
Maybe you can post a picture, do you still have the information how the old switch was wired?
Posted: Sunday 21 January 2018 20:19
by joebar
devros wrote:Hello i have Xiaomi wall switch one button wired, after conection bulb switch on off in loop, registration in Xiaomi app works. When i switch bulb in app on i hear click sound but bulb is still only blinking, tried diferent bulbs but still same problem, any idea what coul be wrong?
Don’t know which country you’re in, in the Netherlands brown is L (life), Black is switch wire to the lamp and green is earth
Old switch looks correct, the switch switches brown to the black wire. On the bulb end there is the blue wire (neutral)
Posted: Sunday 21 January 2018 21:39
by devros
islandman wrote: Sunday 21 January 2018 19:07
L is Life Wire
Thanks but then it looks that i have only ground and not Neutral cable...
L life wire black
L1 Wire to lamp brown
And ground cable
So N is missing
tried conection
N - green
L black
L1 brown
and
N - green
L brown
L1 black
with no response...
Posted: Sunday 21 January 2018 22:13
by islandman
devros wrote: Sunday 21 January 2018 21:39
L is Life Wire
L life wire black
And ground cable
So N is missing
tried conection
N - green
L black
L1 brown
and
N - green
L brown
L1 black
with no response...
holy sh*** bad wiring not even boxes in the wall!! And you use green/yellow for ground only not for neutral like your wiring
however you need 3 wires connected. Better you call a electrician before your house burns down
May i ask what country that is?
Posted: Sunday 21 January 2018 22:37
by devros
box was removed because xiaomi switch is bigger i have to replace it with square one...
im from Czech Republic...
Posted: Monday 22 January 2018 8:45
by RichardBokker
islandman wrote: Sunday 21 January 2018 22:13
i boy, i a'm cyring to after seeing this pictures
But indeed, you require an extra (blue!) wire.
And some Box in the wall to, now it is impossible to mount the switch.
Posted: Monday 22 January 2018 9:48
by febalci
Normally, you willv only have 2 cables in the switch box, the phase and the line going to lamp. In most countries, the light switch boxes do not have neutral line since the neutral line goes directly to the lamp. When you press the switch button, you simply close the circuit of phase line to the lamp, and the lamp already has the neutral line in place coming from a different route.
So, the green/yellow (colors refer to ground line) in your light switch box seems not to be connected to anywhere (At least it seems like that on the lamp, however it might be connected to ground in between at some junction box). But what i see is the neutral line in your lamp accessory seems also connected to another green/yellow line (or is it blue only!?), which can create a problem since it denotes neutral is in par with the ground line! However, since some unprofessional electricians discard color coding in some countries, it might simply mean also that green/yellow cables are used in neutral lines in your house. The simplest check would be to call a professional electrician to check these lines.
If you have a junction box up above the light switch box near to the ceiling, check if blue cables are there. If there are, then you can extend a new blue cable in wall from this junction box to the light switch box. If not, then most probably the electrician didn't cared about the color coding at all. It can be solved, but for the sake of safety and security, please call an electrician to check all lines. Fire risk is very important!...
Posted: Monday 22 January 2018 13:37
by RichardBokker
DAVIZINHO wrote: Sunday 07 January 2018 19:44
Hello, since i upgrade to the beta 3.8799 the my zigbee power socket can´t measure the consumption.
anyone with the same problem?
I am running 3.8153 (last stable), and i have same problem. I don't see consumption of the zigbee power socket in Domoticz.
Should it be there? Or not?
