XiaomiGateway: unhandled model: sensor_switch.aq3
I thought the water sensor was working already, see https://github.com/domoticz/domoticz/bl ... y.cpp#L899xraken wrote: ↑Saturday 13 January 2018 1:20 I have a bunch of Xiaomi sensors working fine with the latest Domoticz beta. I just bought a pair of aqara water sensors (https://www.gearbest.com/home-smart-imp ... 68897.html) but looks like it is not yet compatible with Domoticz.
I see this in the log:Any chance this device can be supported? I can help if there's anything I can further debug and report back.2018-01-12 19:12:58.922 XiaomiGateway: unhandled model: sensor_wleak.aq1
You are correct, I thought I was on the latest beta but it turned out I had switched to an older one. The aqara water sensor works fine with the latest beta.corbin wrote: ↑Sunday 14 January 2018 2:53I thought the water sensor was working already, see https://github.com/domoticz/domoticz/bl ... y.cpp#L899xraken wrote: ↑Saturday 13 January 2018 1:20 I have a bunch of Xiaomi sensors working fine with the latest Domoticz beta. I just bought a pair of aqara water sensors (https://www.gearbest.com/home-smart-imp ... 68897.html) but looks like it is not yet compatible with Domoticz.
What beta version are you on?
Problem solved by opening UDP 9898 on the firewall, so Domoticz recieves the heart beatsDeputyNL wrote: ↑Friday 12 January 2018 15:57 Most of the time I can control the Xiaomi switches with domoticz, but some of the time I can't and see the following message in the logs:
XiaomiGateway: unable to write command - Invalid key
The funny thing is that the key is fine, if I update the device with no changes, all works well again; The other funny thing is that I can always control the switches from the MiHome app, so I know the Gateway has WiFi and can see the switches. Does anyone have a clue what I can do to solve this issue?
I see that this is solved in the beta version 3.8833.Mozart wrote: ↑Saturday 13 January 2018 8:58 I don’t know if this is the best thread to make a request but if it is, maybe look in to supporting a new wireless switch from aqara as well that shows up in the logs as:Code: Select all
That would be handyvincenttor wrote: ↑Saturday 20 January 2018 0:17 Is it maybe a good idea to make a topic with a picture what sensor/switch/addon from xiaomi that works, also shows what kind of settings can be used with that certain part ?
like long press/click / on off etc ?
L is Life Wiredevros wrote: ↑Sunday 21 January 2018 1:21 Hello i have Xiaomi wall switch one button wired, after conection bulb switch on off in loop, registration in Xiaomi app works. When i switch bulb in app on i hear click sound but bulb is still only blinking, tried diferent bulbs but still same problem, any idea what coul be wrong?
maybe wiring problem but cant figure whats wrong? I have tree cables black,brown, green, old switch works only with black and brown conected....
Lamp (4 bulbs) is conected black to L and green to N, brown is unconected
Don’t know which country you’re in, in the Netherlands brown is L (life), Black is switch wire to the lamp and green is earthdevros wrote:Hello i have Xiaomi wall switch one button wired, after conection bulb switch on off in loop, registration in Xiaomi app works. When i switch bulb in app on i hear click sound but bulb is still only blinking, tried diferent bulbs but still same problem, any idea what coul be wrong?
Thanks but then it looks that i have only ground and not Neutral cable...islandman wrote: ↑Sunday 21 January 2018 19:07L is Life Wiredevros wrote: ↑Sunday 21 January 2018 1:21 Hello i have Xiaomi wall switch one button wired, after conection bulb switch on off in loop, registration in Xiaomi app works. When i switch bulb in app on i hear click sound but bulb is still only blinking, tried diferent bulbs but still same problem, any idea what coul be wrong?
N is Neutral (you need it with this switch but a normal switch does not have it)
L1 should be the wire to the lamp
However you never know what color is the right. From my experience green - Ground (no need for that), Black is Life Wire brown could be the Lamp and blue is Neutral!
Maybe you can post a picture, do you still have the information how the old switch was wired?
holy sh*** bad wiring not even boxes in the wall!! And you use green/yellow for ground only not for neutral like your wiring however you need 3 wires connected. Better you call a electrician before your house burns downdevros wrote: ↑Sunday 21 January 2018 21:39Thanks but then it looks that i have only ground and not Neutral cable...islandman wrote: ↑Sunday 21 January 2018 19:07L is Life Wiredevros wrote: ↑Sunday 21 January 2018 1:21 Hello i have Xiaomi wall switch one button wired, after conection bulb switch on off in loop, registration in Xiaomi app works. When i switch bulb in app on i hear click sound but bulb is still only blinking, tried diferent bulbs but still same problem, any idea what coul be wrong?
L life wire black
L1 Wire to lamp brown
And ground cable
So N is missing
tried conection
N - green
L black
L1 brown
and
N - green
L brown
L1 black
with no response...
i boy, i a'm cyring to after seeing this pictures
I am running 3.8153 (last stable), and i have same problem. I don't see consumption of the zigbee power socket in Domoticz.
